Author Topic: not for buying - cool but expensive. just wow the photos  (Read 2294 times)
Offline berserkfan
« on: Fri, 03 May 2013, 07:19:02 »
Offline esoomenona
  • Gnillort?
Re: not for buying - cool but expensive. just wow the photos
« Reply #1 on: Fri, 03 May 2013, 08:08:43 »
A Dremel could probably mod those caps to fit MX switches. The stem seems like it might work, you'd just have to remove the support beams from the stem to the side of the cap. MAYBE, thin the thickness of the stem a bit.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Fri, 03 May 2013, 08:22:08 »
Stuff like these really are rare items, and collector pieces. Most of these stuff went into the trash heaps in 1990's after socialist times ended and of course none of it was exported outside to western countries during its production. These have Bulgarian made copy of Cherry M7 type switch. It's a very cool item, best left as a historical display piece.
« Reply #3 on: Fri, 03 May 2013, 08:26:58 »
Those look like the typewriter caps I sold recently. The crossbars of the "+" on mine were almost 5mm long instead of something like 3.5mm for Cherry, and the actual legs were about 1.5mm thick vs about 1mm.
- Plato
Offline eth0s
  • Peace & Love
« Reply #4 on: Fri, 03 May 2013, 12:56:07 »
^ +1.  I absolutely agree.  This is a living relic from the cold war and should not be modded or changed.  Hopefully a rich colllector will buy it and keep it as it should be kept.
Offline rarar
  • moist booty seepage
« Reply #5 on: Fri, 03 May 2013, 14:34:06 »
I like the look of it! It looks really cool :) Should I get it and keep it in a safe place?
Ỏ̷͖͈̞̩͎̻̫̫̜͉̠̫͕̭̭̫̫̹̗̹͈̼̠̖͍͚̥͈̮̼͕̠̤̯̻̥̬̗̼̳̤̳̬̪̹͚̞̼̠͕̼̠̦͚̫͔̯̹͉͉̘͎͕̼̣̝͙̱̟̹̩̟̳̦̭͉̮̖̭̣̣̞̙̗̜̺̭̻̥͚͙̝̦̲̱͉͖͉̰̦͎̫̣̼͎͍̠̮͓̹̹͉̤̰̗̙͕͇͔̱͕̭͈̳̗̭͔̘̖̺̮̜̠͖̘͓̳͕̟̠̱̫̤͓͔̘̰̲͙͍͇̙͎̣̼̗̖͙̯͉̠̟͈͍͕̪͓̝̩̦̖̹̼̠̘̮͚̟͉̺̜͍͓̯̳̱̻͕̣̳͉̻̭̭̱͍̪̩̭̺͕̺̼̥̪͖̦̟͎̻̰_Ỏ̷͖͈̞̩͎̻̫̫̜͉̠̫͕̭̭̫̫̹̗̹͈̼̠̖͍͚̥͈̮̼͕̠̤̯̻̥̬̗̼̳̤̳̬̪̹͚̞̼̠͕̼̠̦͚̫͔̯̹͉͉̘͎͕̼̣̝͙̱̟̹̩̟̳̦̭͉̮̖̭̣̣̞̙̗̜̺̭̻̥͚͙̝̦̲̱͉͖͉̰̦͎̫̣̼͎͍̠̮͓̹̹͉̤̰̗̙͕͇͔̱͕̭͈̳̗̭͔̘̖̺̮̜̠͖̘͓̳͕̟̠̱̫̤͓͔̘̰̲͙͍͇̙͎̣̼̗̖͙̯͉̠̟͈͍͕̪͓̝̩̦̖̹̼̠̘̮͚̟͉̺̜͍͓̯̳̱̻͕̣̳͉̻̭̭̱͍̪̩̭̺͕̺̼̥̪͖̦̟͎̻̰ ด้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็_ด้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็
