Author Topic: PEXON PCs - Custom USB, PC and Audio Cables  (Read 717724 times)
Offline Frenir
  • HHKB Viking
Little update before I go to bed, managed to get a few new things up... Mini USB angled adapters and PS/2 to USB
Check them out here:-
http://pexonpcs.co.uk/PS2toUSB
http://pexonpcs.co.uk/AngledMiniUSB
Neat :O
Offline pexon
  • * Moderator
  • El Jefe of Sleeving
    • Pexon PCs
Neat :O
Thanks man, if you ever need anything else from me, I'll pop you a few adapters in too  :thumb:
Offline Frenir
  • HHKB Viking
Neat :O
You sure know how to keep a customer, thanks man :)
Offline pexon
  • * Moderator
    • Pexon PCs
Neat :O
No probs brother. I aim to please  :cool:
Offline Zentaaa
  • Safe Bois
Blue Snake Dog Collar!
Offline pexon
  • * Moderator
    • Pexon PCs
That is just so epic!  :))
Offline zeroni13
Do you think the premium 1/8" plug would fit the Beyerdynamic Custom One Pro? It would be really stupid if I order a £82 cable that doesn't fit.
Also do you have a picture of a litz braided black cable with white/clear techflex sleeving?
Phantom with Silver Vortex Case   Keychron Q6 Pro ISO Knob
Offline pexon
  • * Moderator
    • Pexon PCs
Do you have a photo of the socket so I can see if it fits? I will get a photo of the black litz and white/clear techflex for you  :thumb:
Offline zeroni13
The notch there is really stupid, but I'll remove it if I have to.
Offline pexon
  • * Moderator
    • Pexon PCs
Our standard and premium jacks are all made by Neutrik, so they should fit in there with no problems I think  :thumb:
Offline zeroni13
I sure hope so, if it doesn't Ill find something else to use the cable on. Did you find the picture I asked for?
Offline pexon
  • * Moderator
    • Pexon PCs
I've had a look through my imgur album but I can't see anything with black litz and white braid. I will try and take a photo tomorrow if that's ok?
Offline zeroni13
Sure! Thanks for bothering to take a picture. I'll postpone my order until then :P
Offline pexon
  • * Moderator
    • Pexon PCs
OK no worries man, I do have a cable waiting to be dispatched with 4 way litz braid and carbon techflex, so I'll show you that too, it looks siiiiiick!  8)
Offline pexon
  • * Moderator
    • Pexon PCs
Zeroni, pics incoming in form a PM :)
Not a lot to post today, I've just been finishing up final testing and QC on stock update @ TechKeys.
Offline Justintoxicated
Can you still make cables in MDPC VANILLA SANDS N.17?  I'm wanting a 5-6 foot USB-A to mini USB.  How much would it cost if you can?
Offline pexon
  • * Moderator
    • Pexon PCs
I do have some in my personal stash that is actually going to be used for sleeving my PSU, but you can have some  8)
Sweet! Whats the best way to order it with that custom color?
Offline pexon
  • * Moderator
    • Pexon PCs
Order the cable you are after, choose any matte colour and make a note in the dialogue box noted, 'other' that you want MDPC-X Vanilla Sands  :thumb:
Offline cmadrid
Getting a custom cable is definitely on my to-do list!
Offline pexon
  • * Moderator
    • Pexon PCs
I'm here for you man  ;D Will be uploading some pics later too  8)
Well ordered this cable.  My Water cooled PC and blackbird at home have strict black/red theme (PC looks quite bad ass even though I just used braided extensions cause I was too lazy to do my own sleeving).  I wonder if I should have gone with a red cable to match.  But I was thinking to use the nicer cable at work for the keyboard anyways I guess and vanilla sands looked like a good color to go with the gray FC660C that I intend to mostly use at work.
Pretty expensive for a braided USB Mini Cable but if it comes out nice I might buy a really long one with a coil for my UE Boom (Bluetooth speaker) I hate having a short cable for that thing but the price is certainly up there for me for a cable, it would make that Bluetooth speaker look pretty sweet though!
Offline pexon
  • * Moderator
    • Pexon PCs
Vanilla sands is a great choice man, I don't get many requests for it, so you'll be pretty exclusive with it  8)
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
Usually when someone goes to the maximum in creating these cables for anyone wanting custom lengths, colours and connectors - then where else would someone do what Pexon does for less money?
His cables are worth the investment because they will still be around and working whilst all the cheapo $2.00 versions have dissolved into broken plastic rubbish for landfill sites around the globe.
Be conscientious and buy custom made cables for all your electronic trinkets  :thumb: .
« Last Edit: Thu, 03 July 2014, 07:02:53 by Elrick »
Offline pexon
  • * Moderator
    • Pexon PCs
Thanks for the kind words as always Elrick  :thumb:
Offline pexon
  • * Moderator
    • Pexon PCs
I've been working on a set of adapters in double sleeving and double shrink, more pics over the weekend, but here is a potato teaser:-
First up, 5ft Mini USB and Filco cables in Digital Camo paracord
http://imgur.com/rZP61WY
http://imgur.com/MwiYmKy
http://imgur.com/OJ0zyiy
http://imgur.com/4kxtbWN
3ft Mini USB Illuminated blue with mate carbon sleeving
http://imgur.com/PYbUaSG
http://imgur.com/ER6vTlU
3ft Mini USB in pink and teal paracord with white heatshrink
http://imgur.com/xrJ19yi
http://imgur.com/FyebYIZ
http://imgur.com/U9WSCIj
5ft Mini USB in black reflective paracord
http://imgur.com/Pkgmdjz
http://imgur.com/iY2AtAV
3ft Mini USB in Marpatt Camo
http://imgur.com/g0UFcNa
http://imgur.com/7ZQbcug
10ft Mini USB (with angled fitment) in purple paracord
that marpatt camo is pretty nice
Offline pexon
  • * Moderator
    • Pexon PCs
Marpatt is a really nice colour, it suits most boards too, particularly Filco camos
speaking of Filcos
what do you think I should get for my Olivetti set black Filco?
the cable is starting to go, so I need a new one for that too
Offline pexon
  • * Moderator
    • Pexon PCs
speaking of Filcos
Perhaps a double sleeve black with grey or carbon as the second layer?
speaking of Filcos
oooh maybe
I'll think about it and submit an order in a  few days
Offline pexon
  • * Moderator
    • Pexon PCs
speaking of Filcos
oooh maybe
OK no rush brother, I will be adding Techflex in all colours as a second layer option in the next few days too, so possibly a good idea to wait for that.
I'm also stacked out at the moment so give me a chance to catch up  :)) Made 4 sets of PSU cables this week, my fingers KILL
Offline pexon
  • * Moderator
    • Pexon PCs
Little teaser of an awesome set of adapters to be used with a coiled Male to Female USB
Offline pexon
  • * Moderator
    • Pexon PCs
Sorry for the lack of updates, I will be back to form tomorrow, had a really fragmented weekend, back to regular schedule tomorrow I promise.
I've got pics of the 2x Corsair AX1200i cable sets, SuperFlower 1000W Platinum cable set, coiled USB cables and regular USB cables to get sorted tomorrow, so it will be a big update, hope you all had a good weekend.  :thumb:
Offline pexon
  • * Moderator
    • Pexon PCs
Largeish update as promised. Some really cool cables in this one, so take a look and let me know what you guys think! :)
8ft Mini USB to USB in Galaxy Paracord
http://imgur.com/ZGUwD4c
http://imgur.com/Uy5s0Uy
5ft Mini USB to USB in Black Paracord
http://imgur.com/JAPXlS3
http://imgur.com/yw9c0QH
http://imgur.com/wZpbEAj
4ft Mini USB to USB in White Paracord
http://imgur.com/E1GbOsq
http://imgur.com/xe9P2R2
Coiled Mini USB to USB in Pink Paracord with Techflex in Carbon as the second layer
http://imgur.com/Y1Z7CNc
http://imgur.com/t1klQQT
http://imgur.com/Asugo03
http://imgur.com/MG2IhjM
http://imgur.com/98H5BHN
http://imgur.com/ElVhaPH
http://imgur.com/g01rzTo
http://imgur.com/AQ72RtC
3ft Mini USB to USB in Explode! Paracord with Matte Red as the second layer
http://imgur.com/dj3T2iL
http://imgur.com/S31hEeA
http://imgur.com/v7fsFeu
http://imgur.com/uNPlxFZ
http://imgur.com/XtSuDYM
http://imgur.com/GnHbuzP
http://imgur.com/TZS4VxG
Coiled Male to Female USB A in Gold Paracord with Techflex in Carbon as a second layer- Includes following adapters:-
USB A to PS/2 (gold plated)
USB to Mini USB
USB to Micro USB
USB to Filco
I must admit, I think this set is absolutely epic
http://imgur.com/4hDUaPK
http://imgur.com/xL4Qmjx
http://imgur.com/zyqDc3Z
http://imgur.com/8DpszMn
http://imgur.com/aDVeP7P
http://imgur.com/dYCdXY6
http://imgur.com/hD2BeL5
http://imgur.com/LrLnxjl
http://imgur.com/6bKiFDH
http://imgur.com/YBYYMpD
http://imgur.com/MRf1Ysj
http://imgur.com/aFkxuAj
http://imgur.com/bVNJbzw
http://imgur.com/4NpgXMq
http://imgur.com/xzsBz6W
http://imgur.com/e5sWsRH
http://imgur.com/ZCzl8yZ
http://imgur.com/MaV52Fu
I've got some pics to post of the 2x AX1200i cable sets, but I'm gonna do that tomorrow as I'm beat today... well I'll post a few as a teaser :)
Offline katushkin
  • Too Keycool for School
  • Just the guy
Dayyyyuuuummm.
That PS2 connector is incredible. I wants one.
I think the heat shrink and colour co-ordinated PS2 connector just make that set. Good job man.
Offline pexon
  • * Moderator
    • Pexon PCs
Thanks man, I'm really proud of that set, the colour combos in regards to the shrink and double sleeving were left completely to me, I think I've done the guy proud  8)
Offline pexon
  • * Moderator
    • Pexon PCs
Right, here are some pics of the 2 sets of MDPC-X replacement cable set (1 short and 1 regular) for Corsair AX1200i power supplies. These are going to QATAR!  :o
To say that I am happy with these is an understatement, I've used black wire under the black and white under the red sleeve, it makes such a big difference, yet is rarely done. MDPC-X can he hard to sleeve with, I still personally think its THE best sleeving on the market and it takes time to pull all the sleeving nice and tight to ensure the cables hold their shape and make sure the wire underneath doesn't show through; I hope you can see from the pics that the sleeving is lovely and tight.
Check out the full gallery of images (of both the short and the long sets) here:- http://imgur.com/a/Q1Gj0 / http://imgur.com/a/1He06
I've got the pics of the SuperFlower 1000W unit (24 pin, 2x CPU and 3x GPU cables) to get up, as well as photo the SATA and Molex cables, there are also pics of the AX1200 in pink and black to get online, I'll get those up tomorrow  8)
As always, thanks for looking
No arguing that I suppose.  Looking forward to getting my cable :)  The excitement alone is worth it haha.  I love opening mail that contains cool stuff :)
I bought some decent extensions (shrinkless) for my 900D watercooled PC, but really wanted a custom job.  Just couldn't justify it this time around since I am re-using an old 1200 watt Thermal take PSU.  Maybe if it ever goes bad or I upgrade it, then I'll know where to go for a real custom job.  Actually I was going to it myself so I could do custom length cables, but the good tools etc are always out of stock and it certainly is time consuming to do it right.
« Last Edit: Sat, 12 July 2014, 13:45:35 by Justintoxicated »
Offline pexon
  • * Moderator
    • Pexon PCs
Pics will be uploaded tomorrow. I've got photos of last weeks cables that I need to upload too  :thumb:
Offline pexon
  • * Moderator
    • Pexon PCs
Sorry for the delay in uploading pics, I've had a crazy busy weekend, including a sudden influx of orders on friday night. Here are pics of completed orders from last week that I've not uploaded yet.
In other news, my camera has a blob of dust on the sensor, I've tried different lenses, but no difference, so please excuse the grey dot on some photos.
6ft Mini USB to USB in Gecko MK2 Paracord
http://imgur.com/31VfaHh
http://imgur.com/ANiGkIQ
http://imgur.com/pqI8HfG
3ft USB A to USB A Female in Fireball Camo Paracord
This cable was actually ordered from someone 10 minutes down the road :O
http://imgur.com/pagDJdl
http://imgur.com/AVgYXY6
6ft Mini USB to USB in Red Paracord
http://imgur.com/IPHlDAs
http://imgur.com/vFKwVDr
http://imgur.com/9hd2HwT
Double sleeved 7ft Mini USB to USB in Miami Paracord and clear Techflex top layer topped off with purple heatshrink
http://imgur.com/fDJvlsf
http://imgur.com/dyZXR8O
http://imgur.com/DrV9Qp1
http://imgur.com/xebLcrU
6ft Filco Cable in Galaxy Paracord
http://imgur.com/eWcK105
http://imgur.com/6JVAJX3
8ft USB A to USB B in Galaxy Paracord
http://imgur.com/uxvqfZu
http://imgur.com/k4KzBKd
That is all for now, I've got some more pics to upload tomorrow, including some cool coils, double sleeving and regular paracord cables. 2 more PSU replacement cable sets are also ready to ship in the next few days so fingers crossed I'll have some pics of those tomorrow/ wednesday
I have some detailed info and photos of the techflex option that will be added for double sleeving too, Techflex is better (in my opinion) than any other matte/ plastic sleeving for double sleeving as it shows the base layer through much more. I can get Techflex in almost any colour at request too. As well as cool colours and combos, it holds a coil much better than paracord alone. There are some double sleeved cables that are going up on clearance too, so watch out for those
Thanks again for looking again guys, if you see your cable, let me know what you think.
Regards,
James
Those all look great man, guess mine didn't make it into this batch :P
Offline pexon
  • * Moderator
    • Pexon PCs
Its ready for dispatch ;) I'll get some pics tomorrow
Offline Elrick
  • Hype Master
Dear Pexon,
Say if a USB Cable has stopped working, meaning any devices you plug into it fails to show up on the desktop, would you be able to fix that cable?
I can send you one cable so that you can take it apart and possibly resolder new points onto it so that it works.  I feel that it's a good cable made by someone else here on Geekhack but would like you to take a look at it, to see what's gone wrong with it.
Please let me know........
Offline pexon
  • * Moderator
    • Pexon PCs
If its someone elses cable, I would look at it, I would feel a little weird doing it, but Elrick, if you're happy for me to do so, I will.
Offline pexon
  • * Moderator
    • Pexon PCs
Time for another decent sized update.
FREE upgrade to double sleeve
- Orange base layer (paracord) and orange techflex as the top layer. Mini USB to USB A with white shrink
http://imgur.com/NH3PBnr
http://imgur.com/FM0UaVR
http://imgur.com/aB2nX6D
Ergo-Dox kit in 4ft - FREE upgrade to matte yellow :)
http://imgur.com/vDvaEEB
http://imgur.com/TRwkw09
http://imgur.com/gTJmAPp
http://imgur.com/DSulCgl
http://imgur.com/nUgFr5U
7ft Mini USB to USB in blue paracord
http://imgur.com/1wpo4pd
http://imgur.com/aXwlMRN
http://imgur.com/I7SlIrg
Double sleeved 6ft Mini USB to USB in blue with 2nd layer of black with black shrink
http://imgur.com/gGgTcQ5
http://imgur.com/2kaJrez
http://imgur.com/hW2xuKl
http://imgur.com/78zHeFv
http://imgur.com/3QcyXIE
Coiled MDPC-X Vanilla Sands in Mini USB to USB
http://imgur.com/rhELZTo
http://imgur.com/7q8BEec
http://imgur.com/fdPgXjc
Ergo-Dox kit in HMS Grey paracord
http://imgur.com/5GMHuM0
http://imgur.com/N3onqzI
http://imgur.com/RiA5N6r
http://imgur.com/d3ViRT3
Mini USB to USB in Chanterelle
http://imgur.com/X4kU4ee
http://imgur.com/YqaFzPJ
http://imgur.com/H5JhRwB
Coiled Micro USB to USB in white paracord
http://imgur.com/9zrXAEd
http://imgur.com/gl22ZPI\
Right Angled Mini USB to USB in red paracord
http://imgur.com/W6FusrI
http://imgur.com/EpfxOqZ
http://imgur.com/73ieZDu
10ft Mini USB to USB in HMS grey paracord
http://imgur.com/Oz8ImXa
http://imgur.com/BSnmjn4
http://imgur.com/RisCgtm
That vanilla sands looks great!  But.... It's going to look even better plugged into my FC660C !
Offline pexon
  • * Moderator
    • Pexon PCs
It looks even better in person  8)
Offline Kraksx
I don't know why I feel this way but they grey is just the perfect grey.
Poker II
Offline pexon
  • * Moderator
    • Pexon PCs
HMS Grey and Spectral Grey are awesome colours.
