Author Topic: What type of switch is this?  (Read 3222 times)
Offline ikoma
« on: Fri, 03 May 2013, 15:17:07 »
I'm a bit new and I was wondering what this switch is.
I did a bit of searching and couldn't find anything.
« Last Edit: Fri, 03 May 2013, 15:40:06 by ikoma »
QFR x2 | HHKB Pro2 | IBM Model M2 x2 | IBM Model M | Razer Blackwidow | NeXT Keyboard (Alps)
Offline SmallFry
Re: What type of switch is this?
« Reply #1 on: Fri, 03 May 2013, 15:18:14 »
Hm. Perhaps an early Cherry switch. Does it say Cherry on it?
Offline ikoma
« Reply #2 on: Fri, 03 May 2013, 15:20:57 »
Nope, it doesn't say Cherry.
It is quite similar to Cherry switches though..
Offline BlueBär
« Reply #3 on: Fri, 03 May 2013, 17:50:38 »
Pretty sure that's a Futuba switch. This one is the closest I could find: http://deskthority.net/wiki/Futaba_linear_switch (these are close as well http://deskthority.net/wiki/Futaba_complicated_linear & http://deskthority.net/wiki/Futaba_linear_lock )
Futuba switches mostly look like vertical rectangles and have those clip thingys on the side, any more info on the keyboard itself?
« Last Edit: Fri, 03 May 2013, 17:53:38 by BlueBär »
Offline ikoma
« Reply #4 on: Sat, 04 May 2013, 15:42:06 »
It's actually from an Atari 800 XL I picked up for a couple of bucks.
Offline czarek
  • Keep the momentum going!
    • FalbaTech
« Reply #5 on: Sat, 04 May 2013, 16:35:34 »
Best Atari ever, grandaddy of Amigas (not the ST which was actually designed and made by people from Commodore).
Those switches are nice. Quite heavy and linear, similar to vintage cherry MX black or linear NMB space invaders (white ones, yellow are lighter).
Offline mr_a500
« Reply #6 on: Sat, 04 May 2013, 16:54:40 »
There were 6 versions of the 800XL keyboard. According to this AtariAge thread, it looks like that you have one of the AWC versions ("Type 2" or "Type 3"), but the 2nd picture you posted looks like the Mitsumi ("Type 5").
« Last Edit: Sat, 04 May 2013, 16:56:33 by mr_a500 »
Offline ikoma
« Reply #7 on: Sun, 05 May 2013, 02:15:50 »
I can take an actual picture of it if you want.
The one in the picture is very close but it does seem a bit different.
I felt the keys and instantly knew it was mechanical with heavy switches. It's quite hard to type on but nevertheless it's pretty cool.
« Last Edit: Sun, 05 May 2013, 02:17:35 by ikoma »
Offline mr_a500
« Reply #8 on: Sun, 05 May 2013, 08:37:34 »
I knew that second picture wasn't the same keyboard. Yes, take a picture of it and we'll see exactly which version it is. (I'm guessing "Type 2")
I have an ALPS version ("Type 1") and a couple of the "Type 4" stiff nameless ones. I put pictures of the switches in that thread.
Offline ikoma
« Reply #9 on: Sun, 05 May 2013, 13:18:32 »
Mind the dust, I have yet to clean it.
Sorry for late reply, still a bit new to GH.
« Last Edit: Sun, 05 May 2013, 13:20:11 by ikoma »
Offline mr_a500
« Reply #10 on: Sun, 05 May 2013, 14:23:02 »
Yes, that's the first AWC version ("Type 2"). I think that was the first 800XL keyboard produced because that's the one you see on the 800XL box and in the owner's guide.
