Author Topic: Salt and Pepper shakers  (Read 8657 times)
Offline ashort
  • Hoosier Daddy
    • http://andrew.wingedwheel.net
« on: Wed, 11 June 2008, 09:18:21 »
Andrew
{ KBC Poker - brown | Filco Majestouch - brown | Dell AT101W | Cherry G84-4100 }
Offline Ulysses31
« Reply #1 on: Wed, 11 June 2008, 09:36:58 »
Just how is one supposed to use huge flat shakers like these?  Pretty silly idea but i'm sure someone will buy them.
Offline iMav
  • geekhack creator/founder
« Reply #2 on: Wed, 11 June 2008, 09:50:07 »
Where's my debit card???
Offline shadyguido
« Reply #3 on: Wed, 11 June 2008, 13:16:01 »
I'm in for two.  er. four.
If you\'re ambiguated, check out the Marco Santori homepage disambiguator.
Offline lowpoly
« Reply #4 on: Thu, 12 June 2008, 02:20:40 »
Quote from: Ulysses31;5332
I think part of the shaker is still in the cardboard. But they should have taken Model M keycaps. Much better height to footprint ratio. Those who made this can't be true geeks!
Offline IBI
« Reply #5 on: Thu, 12 June 2008, 06:29:03 »
a couple of numpad enter keys back to back would have given a more conventional shape.
Owned: Raptor-Gaming K1 (linear MX)(Broken), IBM Model M UK, Dell AT102W, Left-handed keyboard with Type 1 Simplified Alps.
Offline lowpoly
« Reply #6 on: Tue, 11 August 2009, 10:03:04 »
Found these in a shop on my way to work:
Offline wellington1869
« Reply #7 on: Tue, 11 August 2009, 10:32:00 »
oh thats cute!
actually one can envision a whole line of herb dispensers this way ;) And when not used the containers can be 'stored' in a keyboard layout tray :)
« Last Edit: Tue, 11 August 2009, 10:43:22 by wellington1869 »
using: ms 7000/Das 3
Offline o2dazone
« Reply #8 on: Tue, 11 August 2009, 19:38:17 »
Quote from: lowpoly;108853
oh dear
wheres the white keycaps on the hhk???
Offline rdjack21
« Reply #9 on: Tue, 11 August 2009, 22:04:10 »
o2dazone I was thinking the same. But I do have to say they look pretty good.
Keyboards
Topre Capacitive: Realforce 87U, Realforce 86U, HHKB Pro 2, Topre MD01B0, Topre HE0100, Sun Short Type, OEM NEO CS (x2), NISSHO Electronics KB106DE
Buckling Spring: IBM Model M Space Saver (1291472), Unicomp Customizer x 2
Cherry Brown: Filco FKBN87M/EB, Compaq MX11800
Black Alps: ABS M1
Not so great boards Rare Spring over dome OKI, Sun rack keyboard
Trackballs - Trackman Wheel (3), Trackman marble (2)
Keyboards I still want to get - Happy Hacking Keyboard Pro 2 the White version, Realforce 23U number pad in black and maybe white, μTRON ergo board with Topre switches.
Previously owned - [size=0]SiiG MiniTouch (White Alps), Scorpius M10 (Blue Cherry), IBM Model M13[/size]
Offline o2dazone
« Reply #10 on: Wed, 12 August 2009, 08:26:23 »
I love how the shakers have the same matted texture as the hhk does lol
Offline huha
« Reply #11 on: Wed, 12 August 2009, 08:29:59 »
Where did you get them from? What do they cost?
-huha
Unicomp Endurapro 105 (blank keycaps, BS) // Cherry G80-3000LSCDE-2 (blues, modded to green MX) // Cherry G80-3000LAMDE-0 (blacks, 2x) // Cherry G80-11900LTMDE-0 (blacks, 2x) // Compaq G80-11801 (browns) // Epson Q203A (Fujitsu Peerless) // IBM Model M2 (BS) // Boscom AS400 Terminal Emulator (OEM\'d Unicomp, BS, 2x) // Dell AT102DW (black Alps) // Mechanical Touch (chinese BS) Acer 6312-KW (Acer mechanics on membrane) // Cherry G84-4100 (ML) // Cherry G80-1000HAD (NKRO, blacks)
Offline lowpoly
« Reply #12 on: Wed, 12 August 2009, 12:15:29 »
Quote from: huha;109106
-huha
Got mine in a small shop here in St. Pauli. But they're available online:
keyboard shakers
Designed by James Burgess
Colin Ross Design
About 12 Euros. Top is ABS or something, bottom silicone so you can open them.
On all the pics I've seen, pepper has four holes and salt has one. This has been changed as can be seen above.
Offline itlnstln
« Reply #13 on: Wed, 12 August 2009, 12:57:55 »
Do they go shiny quickly?
Offline rdjack21
« Reply #14 on: Wed, 12 August 2009, 14:22:55 »
I might have to get a set of those if for no other reason than to see the look on my wifes face when they show up.
Keyboards
Black Alps: ABS M1
Offline rdjack21
« Reply #15 on: Wed, 12 August 2009, 14:45:01 »
Quote from: ripster;109196
She'll pepper you with punches and pour salt into the wounds.
That and not let me put them on the table either.
Keyboards
Black Alps: ABS M1
