Author Topic: Any boards similar to this?  (Read 2399 times)
Offline NwGRich
« on: Sat, 04 May 2013, 16:25:03 »
http://s3.postimg.org/w0v8hucpf/rcboard.jpg
I need the arrow keys very close to delete, end and page down.
Offline The_Beast
  • I like wood ಠ_๏
Re: Any boards similar to this?
« Reply #1 on: Sat, 04 May 2013, 16:26:55 »
A phantom could do that, but you'd have to modify a case.
Offline Mandolin
  • Crystal Connoisseur
« Reply #2 on: Sat, 04 May 2013, 16:28:05 »
Why is the space bar splitted?
Artisan keycap Maker
Working on
- Custom keycaps
- Artkeycaps V2 sale
- Due chihuahua and demoncat orders
- Boobiecaps
- Optic fiber embedded keycaps
- Others
Offline NwGRich
« Reply #3 on: Sat, 04 May 2013, 16:31:19 »
Offline esoomenona
  • Gnillort?
« Reply #4 on: Sat, 04 May 2013, 16:35:36 »
SteelSeries has also made it possible for users to physically remove the keyboard from the Shift frame to swap it out with other keypads you can buy from SteelSeries. This standard keyset can be switched out with an MMO ($25) and Cataclysm Gaming Keyset ($25).
« Reply #5 on: Sat, 04 May 2013, 18:39:46 »
Tale
How about the CM Storm QuickFire TK?
Price is OK. Cursor and nav are on the same keys as the numpad, but in different modes so it is almost as small as a TKL. In cursor mode, there are inverted-T cursor keys and the  del/home/end/pgup/pgdown/nav keys are close. MX Blue/blue backlight, MX Red/red backlight or MX Brown/white backlight.
I remember there was a big thing a couple of years ago where people screamed that they wanted this combined layout.
« Last Edit: Sat, 04 May 2013, 19:01:57 by Findecanor »
Offline Hak Foo
  • Make America Clicky Again!
« Reply #6 on: Sat, 04 May 2013, 19:30:42 »
Program a G80-8200 accordingly?
Overton130, Box Pale Blues.
Offline Magna224
« Reply #7 on: Sun, 05 May 2013, 00:19:25 »
The wang 724 does and there is also a focus 2001 that does.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #8 on: Sun, 05 May 2013, 08:48:46 »
HCL Diamond is another choice.
Offline jabar
« Reply #9 on: Sun, 05 May 2013, 08:57:04 »
How about the PLUM 96?
e: maybe not close enough for you... why not do a soft remap (AutoHotkey) if you're in Windows? That sort of keyboard layout you want is rare.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline linziyi
  • The one with many questions
« Reply #10 on: Sun, 05 May 2013, 09:04:57 »
CM Strom Quickfire TK would do I think (Using one right no :) )
Ducky DK9008G2 Pro
"Much to learn you still have" --Yoda
Offline NwGRich
« Reply #11 on: Mon, 06 May 2013, 10:38:08 »
the layout is what I'm interested in wang724/hcl diamond look good
