Author Topic: Containers for your switches, springs, keycaps...  (Read 2885 times)
Offline TheQsanity
  • SmallFry Lovin'
« on: Wed, 08 May 2013, 14:13:32 »
What type of containers do you guys use to hold your small commodities?
SmallFry! <3
Offline BunnyLake
  • The OG HHKB Master
  • X
Re: Containers for your switches, springs, keycaps...
« Reply #1 on: Wed, 08 May 2013, 14:20:53 »
there are like 3 threads currently active about this in the keycaps sub forum good sir
Offline keymaster
  • Topre Revolution Theorist
« Reply #3 on: Wed, 08 May 2013, 14:44:58 »
I usually just store my switches/springs in small boxes I have laying around...nothing fancy.
Offline cgbuen
    • cgbuen.io
« Reply #4 on: Wed, 08 May 2013, 15:21:44 »
http://www.containerstore.com/shop?productId=10003027&N=&Ntt=ring+box
I like these a whole lot - I have about 15 of these in different sizes that I use for stems, springs, stabilizer parts, and switch tops. I believe #162071 is the one that holds 87 MX stems perfectly.
« Last Edit: Wed, 08 May 2013, 15:24:53 by cgbuen »
Offline baldgye
  • Will Smith Disciple
« Reply #5 on: Wed, 08 May 2013, 16:34:12 »
I've seriously been thinking about using either old VHS tape boxes or finding the clear new cartridge plastic snap cases you can get on ebay for housing all my bags of keycaps in some sort of order, rather than just all together in a big random box... but can't find where my VHS taps are...
« Reply #6 on: Wed, 08 May 2013, 17:11:14 »
here ya go
http://www.bagsunlimited.com/c-525-no-hub.aspx
21533-0
then you put those in one of these
http://www.bagsunlimited.com/c-10-vhs-storage-boxes.aspx
21531-1
Offline baldgye
« Reply #7 on: Wed, 08 May 2013, 17:12:09 »
here ya go
Yes...yes... and then to make custom sleeves for them....
Offline TheQsanity
  • SmallFry Lovin'
« Reply #8 on: Wed, 08 May 2013, 17:15:41 »
I was thinking about using a plastic bits drawer for tools for mine but they cost around 40 usd. That would be the best way to organize everything.
SmallFry! <3
