Author Topic: Alien Language Layout  (Read 3400 times)
Offline YMSNoms
« on: Thu, 09 May 2013, 07:44:46 »
Guys would it be possible for these to be put on a set of keycaps?
Thanks
Nick
Leopold FC700R
Filco Majestouch-2 Multicamo
Korean FR4-87 Lambo Orange Custom
Re: Alien Language Layout
« Reply #1 on: Thu, 09 May 2013, 07:45:44 »
Thanks
Nick
If you want a 1-off set, WASD can do it anything you want
Offline RickyJ
« Reply #2 on: Fri, 10 May 2013, 21:08:55 »
WASD will also be the cheapest option by far. :)
Currently GMMK Pro: lubed 68g U4T, FR4 plate, extra gaskets, etc
Offline Jagriff
« Reply #3 on: Sun, 12 May 2013, 10:18:04 »
Well the cheapest option (per unit) would probably be to run a group buy if there is sufficient interest. I think those caps would look cool and definitely generate some interest. Running a group buy is a lot of work though.
