Author Topic: Realforce 87U: elitekeyboards vs keyboardco  (Read 1843 times)
Offline odyssomay
« on: Fri, 10 May 2013, 06:03:33 »
Hi,
I have fairly simple, but maybe weird question: Is this (keyboardco) keyboard the same as this (elitekeyboards)?
The keyboardco one is listed as "beige", while the elitekeyboards one is listed
as "white". So I would like to know if there is a difference. Also, if anyone has
better pictures than the keyboardco official, I would love to see them!
Regards
Jonathan
Offline elitekeyboards
  • * Commercial Vendor
    • http://elitekeyboards.com
Re: Realforce 87U: elitekeyboards vs keyboardco
« Reply #1 on: Fri, 10 May 2013, 06:18:39 »
It's the same board. Curiously, this same question came up once before. It's an off-white board with beige modifiers and accent keys. The actual color is lighter than the keyboardco photo and while the elitekeyboards photos are a little washed out, I think they're closer to the true color.
Offline therecorder
« Reply #2 on: Fri, 10 May 2013, 06:34:23 »
http://geekhack.org/index.php?topic=34863.msg645122#msg645122
It was me, Brian.  Have sent you numerous messages about purchasing another keyboard from you, but you haven't replied.  But, I'm a patient guy.
Offline odyssomay
« Reply #3 on: Fri, 10 May 2013, 06:34:40 »
Thanks for the quick response! :D
I'll order from keyboardco then - Swedish customs and taxes when ordering from the US is not something I want to deal with...
« Reply #4 on: Fri, 10 May 2013, 06:37:59 »
Oh? Where are you sending messages?
Offline therecorder
« Reply #5 on: Fri, 10 May 2013, 06:41:07 »
Over the past year I have sent several to your sales@elitekeyboards.com address.  The last on 6-APR-13.
« Reply #6 on: Fri, 10 May 2013, 06:44:14 »
That's odd...unless you're asking for the same thing 10 other people are asking;) PM me with what you're looking for.
