Author Topic: Ducky DK9008G2 Pro PBT?  (Read 42582 times)
Offline behappy
Re: Ducky DK9008G2 Pro PBT?
« Reply #100 on: Sat, 29 June 2013, 10:19:17 »
Eww numpad...
If only there was a TKL version ...
Would buy if TKL.
Noppoo Choc Mini (Cherry MX Reds)
Offline rootwyrm
  • The Hands of Steel
    • My Website!
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline Photoelectric
Offline dante
« Reply #103 on: Sat, 29 June 2013, 14:48:19 »
« Last Edit: Sat, 29 June 2013, 19:40:41 by dante »
Offline Flyersfan1
  • Hi!
« Reply #104 on: Sat, 29 June 2013, 18:18:11 »
Have any reviews popped up for the mx dark gray ducky yet?  Reading some reviews of this switch it sounds like it is so stiff it is unusable.
Also do the dyesubs make the experience more quiet at all?
I've tried to find reviews and videos for that switch too, I was tempted to order one just for the sheer rarity of the switch, but just opted to go with my trusted mx blue switch.  I just don't think I'd be able to use a linear switch that heavy.  :'(
« Last Edit: Sat, 29 June 2013, 18:20:23 by Flyersfan1 »
Quote from: Photekq
Offline rootwyrm
    • My Website!
« Reply #105 on: Sat, 29 June 2013, 19:15:58 »
Eww numpad...
Would buy if TKL.
Your wallet now hates me.
He probably meant the dye sub PBT versions!
I might be convinced to sell one of my dark gray dye-sub PBT sets...
I'm trying to find someone to loan me a Dark Grey so I can write up a review. TBH, with the thick dye-subs, I think they're nuts if they're calling it unusably heavy. The MX Green actually feels like Blues in part due to the extreme weight of the keycaps. Seriously, these things are HEAVY. I mean REALLY heavy. Heaviest keycaps I've handled outside of Model M's. End result is that other than issues with the stabilized keys it's lighter than a Model M. (Stabilized keys, it's a spacing issue. I strike too far off center.)
If I had to make a wild guess, I'd say Dark Greys with the stock keycaps are around Classic Blacks with DSA. Give or take a little bit either way. Probably a little bit heavier. But I mean really, they're not that heavy. They're rated at 80cN and if Greens feel like Blues (55cN) then the DGs should end up just slightly north of Black (50cN.)
« Reply #106 on: Sat, 29 June 2013, 19:17:29 »
If you had the white/beige set, I would commence convincing you immediately :)
Offline rootwyrm
    • My Website!
« Reply #107 on: Sat, 29 June 2013, 19:21:32 »
The irony is that I'm actually looking for the white AND blue sets to make a mix-and-match for a project I'm working on. Unfortunately, not much hope of that - cost is just too great.
Offline sonic_the_hedgehog
  • That's a fast hedgehog...
« Reply #108 on: Sun, 30 June 2013, 17:33:42 »
Well I'll traded you your dark grey F5 - F8 for my blue F5-F8 if that's any use to you... otherwise I'm gonna have to email Ducky to see if they'll sell me the dark grey F5-F8 separately.
IBM Model M | Cherry G80-3000LXCEU-2 (Browns) | Cherry G80-3494LYCUS-2 (Reds) | Old School AT Mechs | Old School XT Mech | Old School Japanese XT Mech  (Details / Pics Coming Soon :D)
Offline NXCL
« Reply #109 on: Sun, 30 June 2013, 18:29:38 »
Just wondering, because I couldn't find it mentioned earlier, does this keyboard come with a PS/2 adapter? If not, would you recommend getting one? It says it has full N-key rollover over USB, but I remember reading the mechanical keyboard guide on OCN that interfacing via PS/2 is much more superior than interfacing via USB.
Offline linziyi
  • The one with many questions
« Reply #110 on: Sun, 30 June 2013, 18:37:06 »
No it does not come with a PS/2 adapter... nor keychain which I wanted quite badly :S
Ducky DK9008G2 Pro
"Much to learn you still have" --Yoda
Offline rootwyrm
    • My Website!
« Reply #111 on: Sun, 30 June 2013, 19:07:33 »
Haha, sadly, I need the whole set.. I may actually switch out to my white/grays from T's sale. They'll certainly make the switch feel more pronounced, which I like. The downside is that I have to fix the spacebar - Cherry stabilizers + warped spacebar = MISERY.
Offline quake4mhg
« Reply #112 on: Mon, 01 July 2013, 23:25:51 »
@sonic_the_hedgehog
Could you flip the thick pbt keycap that we can see the bottom? Thanks alot  :)
Offline rootwyrm
    • My Website!
« Reply #113 on: Tue, 02 July 2013, 00:11:25 »
@sonic_the_hedgehog
Quick phone shot. Keycap on the right is a 1988 Model M two piece, on the left a Ducky PBT dye-sub.
Yes. They are Model M thick.
Offline NXCL
« Reply #114 on: Tue, 02 July 2013, 19:41:02 »
Mine arrived today. Got the Blue/Grey MX Browns. Pretty happy with it so far. It is a bit bigger than my previous keyboard, but I'll get used to it. This is my first mechanical keyboard - been using membrane keyboards for my whole life.
I have two questions:
a) Is it possible to customise the keys? I'm not talking about the physical keys, but say the "PC" button or the "Mail" button located in the top right hand corner?
b) What is the proper typing technique for a mechanical keyboard? I've found that my typing has gotten substantially louder, indicating that I'm bottoming out. How do you learn to not bottom out? I've Googled it and searched on GeekHack, and haven't found anything.
The one thing I wish I could do would be to not have the Num Lock LED on the whole time, but still retain function of the Numpad, because the light is always on the corner of my peripheral vision, and may become a slight annoyance.
Offline rootwyrm
    • My Website!
« Reply #115 on: Tue, 02 July 2013, 19:53:03 »
These use the default application as defined by Windows - the only one you cannot customize in that fashion is the 'PC' button which will always open 'My Computer' or 'My Documents.' (And I forget how to change between the two - it's complicated.)
There is no 'proper typing technique.' Bottoming out is not an inherently bad thing. If you bottom out, you bottom out. This is not an inherently bad thing or necessarily a bad thing. There's not really any supporting research I'm aware of. (I say this as someone who bottoms out not only MX Greens but Buckling Spring and even Super Blacks.)
Offline NXCL
« Reply #116 on: Tue, 02 July 2013, 21:18:27 »
How do you go about changing the keys other than the "PC" one? Furthermore, does it apply to the "Fn" key as well? Because currently, there is nothing assigned to Fn+10 to Fn+12, and I would like to be able to customise the function of those keys as well.
Offline nsrexler
« Reply #117 on: Tue, 02 July 2013, 22:14:34 »
Actually I have a question about those miscellaneous keys too. Is there any way to get them to do anything on OS X? I'm not really sure what to search for.
Offline bail_w
« Reply #118 on: Wed, 03 July 2013, 00:18:18 »
Oh man, this color scheme is so good looking.
Offline Tom1983
« Reply #119 on: Wed, 17 July 2013, 01:37:15 »
Yesterday i recieved my grey/blue ducky and immediately noticed the sticky spacebar. I think i also have a warped spacebar wich puts pressure on the stabilizers. Also some keys on the numpad were bad quality. From the top side of the cap you could see the shape of the part that goes over the cherry switch (the round part with the cross). The surface was really bad and not smooth at al. Only with two caps though. I heard there were alot of problems manufacturing these caps and they stopped making them. So i dont really have confidence my replacement wil be any better. Would it be better to get a ducky shine?
