Author Topic: Introducing "Watches" - the new "New"  (Read 20979 times)
Offline E TwentyNine
    • Some of My Keyboards
Re: Introducing "Watches" - the new "New"
« Reply #50 on: Fri, 24 May 2013, 11:31:15 »
Threads where I've posted are now in my watch list, but ones I just marked "notify" without posting are not.    Should they be?
Could there be a one-time migration of the "notify" flag to "watch" flag for threads where we set notify but did not post?
I'll look into this...I was wondering if anyone would want to do that.
Thanks.  I probably have too much stuff in my notify list, this would be useful.
Offline Soarer
« Reply #51 on: Fri, 24 May 2013, 11:41:31 »
edit: no joy :( Both 'ISO layout supporters: Defend it' and the milestone posts thread won't unwatch either.
:confused:
Is the same code deployed for moderators and other users now? Since I'm a mini-mod...
edit: just did another test of 'watch'ing a thread that I haven't posted in (which worked) and then trying to 'unwatch' it (which didn't). So it would appear to be independant of whether I've posted in a thread, since for the others I mentioned, I have posted in them.
« Last Edit: Fri, 24 May 2013, 12:32:16 by Soarer »
Offline rknize
    • metaruss
« Reply #52 on: Fri, 24 May 2013, 13:01:11 »
The only difference between mods and non-mods is whether or not Notifications appears in the menu bar.  All the other checks were removed.
What you just described is even more bizarre, but may be helpful.  Thanks.
Russ
Offline rknize
    • metaruss
« Reply #53 on: Fri, 24 May 2013, 16:11:04 »
Do you use the "Mark Read" feature on forums?
Russ
Offline Soarer
« Reply #54 on: Fri, 24 May 2013, 16:12:43 »
Tend to just use the 'mark all messages read' button on the unread posts page.
Offline rknize
    • metaruss
« Reply #55 on: Fri, 24 May 2013, 17:09:25 »
Fixed?
Russ
Offline Soarer
« Reply #56 on: Fri, 24 May 2013, 17:54:50 »
I think so! Thanks!
Offline alaricljs
  • I be WOT'ing all day...
« Reply #57 on: Sat, 25 May 2013, 19:17:45 »
So... feature request?
Can we get an unwatch button column in the list view?
Filco w/ Imsto thick PBT
Offline rknize
    • metaruss
« Reply #58 on: Sat, 25 May 2013, 21:10:13 »
In the watch list?
Russ
Offline alaricljs
« Reply #59 on: Sat, 25 May 2013, 21:28:24 »
Yes there.  Need more sleep.
ed: Oh f... 46 pages of threads I've posted in.
« Last Edit: Sat, 25 May 2013, 21:31:23 by alaricljs »
Offline aggiejy
« Reply #60 on: Sun, 26 May 2013, 10:17:59 »
Any chance we can make the "Participated" feed to Tapatalk match the Watched feed?
Offline rknize
    • metaruss
« Reply #61 on: Sun, 26 May 2013, 14:24:08 »
The thought has crossed my mind.
Russ
Offline aggiejy
« Reply #62 on: Thu, 30 May 2013, 10:11:09 »
In the header, if you expand it, there is "Show new replies to your posts."
That still points to http://geekhack.org/index.php?action=unreadreplies
Not sure if this is by design, or if it should match "Watched" since it previously matched "New".  If so, then perhaps the wording should be changed to "Show watched posts" or something to that effect.
Offline rknize
    • metaruss
« Reply #63 on: Thu, 30 May 2013, 11:00:46 »
I left the link up there to the old query, in case someone came at me with pitchforks and torches.  Interestingly, the complaining has been minimal.  I guess that means it's mostly-working.
Russ
Offline Soarer
« Reply #64 on: Thu, 30 May 2013, 11:20:00 »
Really nice being able to add and remove threads from the watch list... 'just works'™, TYVM!
Offline calavera
« Reply #65 on: Tue, 11 June 2013, 17:41:30 »
How do I unwatch something if the OP locks the thread? I see no option to unwatch.
Offline rknize
    • metaruss
« Reply #66 on: Tue, 11 June 2013, 19:11:27 »
If the thread is locked, it's not going to change.  Just mark it read.
Russ
