Author Topic: [IC] Acrylic Case for Phantom & Filco & QFR (Confirmed!!)  (Read 78279 times)
Offline takaki
Re: [IC] Acrylic Case for Phantom & Filco & QFR (Confirmed!!)
« Reply #100 on: Thu, 23 May 2013, 01:18:43 »
I just realised not long ago that the 7bit layout refers to the design on prf/wfd's plate.
Offline Badwrench
  • ummmm.....I forgot
« Reply #101 on: Thu, 23 May 2013, 01:31:06 »
Do you have any pictures to give me an idea of how the USB cable will work with a Filco or QFR?
It works exactly the same as how it would work on the filco.. the final phase of this prototyping is only anchoring on the design of the bottom layer to accommodate teensy, filco and QFR cabling issues. And yes also about the colour combinations.  I'll post pictures after I'm done with work today.
Anxious to see this.
Offline jabar
« Reply #102 on: Thu, 23 May 2013, 01:31:26 »
cool, definitely need one for my 7bit phantom! any conservative color matte top would be fine (grey, black, brown, maybe white).
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline WhiteFireDragon
    • youtube
« Reply #103 on: Thu, 23 May 2013, 02:31:45 »
takaki, do you have pics of the inside without the keyboard mounted? I'm asking because if it fits a quickfire TKL, then it might not work for phantom because the edges of the plates are different. Stock Filco and CM plates have a small right-angle bend on the front and back, my Phantom plates are just flat. I don't think you mentioned standoffs, so mounting phantom may not work.
You should get my plates soon. It was one of the first ones I shipped out  ;)
Offline Rendom
« Reply #104 on: Thu, 23 May 2013, 02:41:06 »
Did you get my PM regarding the stab yet?
QFR - MX Blue
Offline BimboBB
« Reply #105 on: Thu, 23 May 2013, 02:44:03 »
Interested in 1.5 WKL Layout and standoffs would be great as well.
Offline takaki
« Reply #106 on: Thu, 23 May 2013, 03:05:36 »
I get what you mean, thus I am waiting for the plate to come before I actually accept orders. Basically there is a inner layer that would be big enough for the PCB to slide through but too small for the plate, thus the plate sits on that layer. Gonna test with the phantom plate to see if it fits. Thanks for shipping it out earlier :)
The items are in hongkong already, tomorrow should be in singapore. Everything seems to be going according to schedule.
« Last Edit: Thu, 23 May 2013, 03:12:53 by takaki »
Offline phinix
« Reply #107 on: Thu, 23 May 2013, 05:29:32 »
How high is it? Is it higher than original QFR case?
I would like to see shorter case...
Offline takaki
« Reply #108 on: Thu, 23 May 2013, 07:50:50 »
The current casing height is measured at 18mm then you add the height of your keycaps. I am going to add another 10mm tall rubber feet to act as feets which is totally optional if you don't like feets.
Colour samples in my bag.. Must say that neon green + white centre with orange bottom layer reminds me of gummy burgers.
Offline Latin00032
« Reply #109 on: Thu, 23 May 2013, 08:19:20 »
Those are good. Yum!
Offline Rendom
« Reply #110 on: Thu, 23 May 2013, 08:21:47 »
Would you be able to make the feet removable? That would sound better.
QFR - MX Blue
Offline takaki
« Reply #111 on: Thu, 23 May 2013, 09:29:50 »
the feet will be stick on, removable of course.
Offline Rendom
« Reply #112 on: Thu, 23 May 2013, 10:42:06 »
Awesome! Can't wait then! ^_^
QFR - MX Blue
Offline takaki
« Reply #113 on: Thu, 23 May 2013, 21:39:36 »
Smoked Black ?  :D Over Opague white to see smoked colour and transparency.
Over black
Bring on the sexy red.
Matt Toxic Green, clear-->white-->Black
Matt Blue,
Translucent Green
Offline Latin00032
« Reply #114 on: Thu, 23 May 2013, 21:48:40 »
There are some good color combinations. You might need to make at least one prototype to see how the colors work all together.
I don't know which to pick.
Offline whiskytango
  • Don't touch the trim
« Reply #115 on: Thu, 23 May 2013, 21:50:18 »
That smoked black, that is what I want. Looks great!
Offline keymaster
  • Topre Revolution Theorist
« Reply #116 on: Thu, 23 May 2013, 22:10:08 »
Smoked on black!! These will be awesome
Offline nebo
« Reply #117 on: Thu, 23 May 2013, 22:14:43 »
Black on white!
Offline Rayne
  • For Science!
« Reply #118 on: Thu, 23 May 2013, 22:37:37 »
that matt toxic green <<<333
want so bad!!!!
Offline takaki
« Reply #119 on: Thu, 23 May 2013, 23:16:58 »
Basically, the centre portion can only be either opaque black, opaque white or clear.
The top layer and bottom layer can be customized
Offline Rayne
  • For Science!
« Reply #120 on: Thu, 23 May 2013, 23:28:47 »
well im definitely in for  matt toxic green/opaque white/matt toxic green
and as i said earlier i will probably want two, not sure what color for the second one yet.
Offline takaki
« Reply #121 on: Fri, 24 May 2013, 01:24:12 »
Translucent Orange
Matt light blue
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #122 on: Fri, 24 May 2013, 03:09:09 »
Matte Toxic and clear all the way!!!
Offline Latin00032
Re: [IC] Acrylic Case for Phantom &amp; Filco &amp; QFR (Confirmed!!)
« Reply #123 on: Fri, 24 May 2013, 04:28:17 »
Is that smoke over transparent red? That might be the one.
Offline takaki
« Reply #124 on: Fri, 24 May 2013, 07:50:33 »
That is actually red over opaque black.
Offline Badwrench
« Reply #125 on: Fri, 24 May 2013, 13:44:19 »
Can you do the plp 3010 over smoke?
Offline nebo
« Reply #126 on: Fri, 24 May 2013, 15:07:58 »
Stop giving me more choices! I'm tempted to get white/blue now so that I can through on my red alerts and have a 'Murica keyboard.
Offline BornEvil
« Reply #127 on: Fri, 24 May 2013, 20:21:11 »
Smoke black on black looks cool.
Maybe even custom print some artwork (on paper) to slip between the layers. Possiblities are endless!
9087 Shine 2 Brown ISO | Quickfire Pro Red ISO | Quickfire Rapid Brown ANSI
Offline esoomenona
  • Gnillort?
« Reply #128 on: Fri, 24 May 2013, 20:27:34 »
Could you make a black top with the piece between the arrows and cluster above it cut out? Just the top sheet.
Offline KuhnTang
  • Game of Thrones
« Reply #129 on: Sat, 25 May 2013, 00:00:01 »
I know this has likely been covered, but how much is this case going to cost?
Offline Permeability
« Reply #130 on: Sat, 25 May 2013, 00:01:49 »
In the OP it says 50-60 USD before shipping
Keyboards:
'The Cheat' - lubed 62g Clears
Ducky Shine 3 TKL lubed 45g Reds (Work)
Offline Rendom
« Reply #131 on: Sat, 25 May 2013, 00:39:04 »
What was confirmed? : o
QFR - MX Blue
Offline takaki
« Reply #132 on: Sat, 25 May 2013, 01:26:46 »
QFR confirmed. 50-60 for clear acrylic, getting the quotes for all the coloured sheets.
Offline Moomoo
« Reply #133 on: Sat, 25 May 2013, 03:40:12 »
Where's the pink at?
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #134 on: Sat, 25 May 2013, 16:14:25 »
down for one in orange or red if with extra phantom keys (numpad)
will see where this goes....
« Last Edit: Sat, 25 May 2013, 16:17:26 by Glod »
Offline takaki
« Reply #135 on: Sun, 26 May 2013, 00:56:24 »
the local most bang for buck acrylic sheet manufacturers don't have pink and purple sheets, gonna source elsewhere.
Just submit the interest check form, I'll mass email / pm when it is ready to go.
Offline nebo
« Reply #136 on: Sun, 26 May 2013, 02:22:48 »
What if we didn't fill out an IC? I wasn't sure what to choose since I think I'm one of the few that wants winkeyless w/ numpad.
Offline Dsan
« Reply #137 on: Sun, 26 May 2013, 04:58:22 »
I'm not sure if I'll be ready to pay when the invoices'll come out.Can I fill the form and then eventually cancel it?
Offline takaki
« Reply #138 on: Sun, 26 May 2013, 05:58:15 »
Sure, this is just an interest check form. for me to gauge the interest of colours and get suggestion instead of just coming out with something BAM! and it is not the same as what everyone actually wants.
Offline takaki
« Reply #139 on: Sun, 26 May 2013, 05:59:18 »
No problem, like i said just an IC, not the actual order form don't worry. Will post on the group buy thread eventually, the different colours will have tier levels pricing just like keycaps, trying my best to make it as affordable as possible.
Offline jabar
« Reply #140 on: Mon, 27 May 2013, 19:32:09 »
I'm not going to add to your IC form since the GB is confirmed... but I am definitely buying one because I don't want to dremel a poor Plu or Filco case to fit the 7bit layout. I like the matte blue on white! All the options actually look great!
Phantom 7bit
Offline Tisca
« Reply #141 on: Tue, 28 May 2013, 04:21:33 »
So I watched a comparison video and concluded Filco and QFR boards are made by Costar but the Filco has a few more screws in the assembly. I don't know how the attachment to this acrylic case is but is there any chance if it would fit a Ducky TKL (US ANSI) model?
Offline Moosecraft
  • HHKB Pro
« Reply #142 on: Tue, 28 May 2013, 04:48:54 »
What about 86 key layout?
Offline gnubag
« Reply #143 on: Tue, 28 May 2013, 15:26:02 »
86 and 87 are the same (just the bottom row is different)
Offline takaki
« Reply #144 on: Tue, 28 May 2013, 20:51:34 »
Do note all the screws are screwed to the casings. wont be using those screws. the only trouble with Qfr is the removable cable port. Need to find a place for it.
I not have the ducky TKL to try. You can take a picture of the inlets meaning the top, front, side and bottom photo for an estimated gauge.
Offline Sai
« Reply #145 on: Tue, 28 May 2013, 20:53:35 »
may i know the progress on the case ? :)
Offline Rayne
  • For Science!
« Reply #146 on: Tue, 28 May 2013, 20:58:20 »
im quite curious as well, i want these so bad!
Offline Rendom
« Reply #147 on: Wed, 29 May 2013, 03:52:13 »
You guys will be very happy soon. : p
QFR - MX Blue
Offline baldgye
  • Will Smith Disciple
« Reply #148 on: Wed, 29 May 2013, 04:11:13 »
Totally up for a pink one!! ...long as it's hot
Offline BimboBB
« Reply #149 on: Wed, 29 May 2013, 06:16:05 »
@takaki
did you received already yr phantom plates? would be good to hear if they fit the case.  :)
