Author Topic: Atrox - mod friendly arcade stick from Razer  (Read 5003 times)
Offline daerid
    • Rossipedia
« on: Tue, 21 May 2013, 13:06:44 »
Re: Atrox - mod friendly arcade stick from Razer
« Reply #1 on: Tue, 21 May 2013, 13:12:41 »
How is that thing worth $200?
Offline daerid
    • Rossipedia
« Reply #2 on: Tue, 21 May 2013, 13:32:12 »
As far as I understand it, any quality fighting stick will run you about the same.
Offline SmallFry
« Reply #3 on: Tue, 21 May 2013, 13:34:42 »
Interesting, but indeed expensive. Not sure I'd get one, but then again, I'm not playing Street Fighter etc. :D
Offline Dubsgalore
« Reply #4 on: Tue, 21 May 2013, 13:36:07 »
« Reply #5 on: Tue, 21 May 2013, 13:50:32 »
The Hori Fightstick is $150 and I know there are quite a few decent ones for under $100.  I just don't generally equate Razer with quality.  $200 for it is as absurd as the Madcatz Fightstick SE at $200.
