Author Topic: Mechanical and programmable?  (Read 2333 times)
Offline brokenHaiku
« on: Wed, 22 May 2013, 14:59:25 »
Hi there,
I'm an interface designer from the UK; basically I use a gaming mouse (Razer Deathadder) for work with the additional buttons programmed for common functions, and am looking for a reasonably-priced mechanical keyboard which is similarly programmable, partly for the feel (which I prefer to a regular keyboard) and partly for more efficient working! Any recommendations?
Re: Mechanical and programmable?
« Reply #1 on: Wed, 22 May 2013, 15:01:50 »
If you could tell us what size keyboard you'd like (Full size, Tenkeyless, 60%, etc) and what you mean by "reasonably priced", that would help. Everyone has a different budget.
Offline brokenHaiku
« Reply #2 on: Wed, 22 May 2013, 15:17:23 »
Sorry chap! Full sized, will be using as a normal desk keyboard. Reasonably priced - ideally £100 or less (think that's about $135ish)
« Reply #3 on: Thu, 23 May 2013, 06:08:37 »
Hm, maybe one of the full size Ducky boards? I forget the model number...maybe 9008? You can try your luck with Rosewill RK-9000s as well. I've heard varying reports of them being fine or going bad quickly. If you can stomach how they look, the CoolerMaster Storm Trigger might be nice for your price range. And finally, its a bit more but I type on a Filco Majestouch 2 at work.
Now there's 2 catches. First? If you're looking for ISO layouts, I'm not sure if all the boards I listed have that option. I'm an ANSI user myself. Second? I'm pretty sure there isn't a daughterboard chip/firmware swap that you can do to make these boards programmable. The only chip I know of is the HID Liberation device but it only fits a Filco TenKeyLess board. However, people always recommend AutoHotKey to remap the layout. I'm not 100% as to how the HID device works so you'll want to do more research on that.
Good luck with your hunt!
Offline Sai
« Reply #4 on: Thu, 23 May 2013, 06:53:56 »
The OP can probably have this
« Reply #5 on: Thu, 23 May 2013, 07:03:24 »
Hehehe, that's one way of getting into the hobby Sai :P
Offline Sai
« Reply #6 on: Thu, 23 May 2013, 07:13:21 »
but he siad "reasonably priced" though. so, i guess he wouldn't want to spend that much at the beginning. :D
OP, you can check out this thread.
bpiphany is doing a programmable controller for filco, rosewill, etc.
