Author Topic: FS: Korean Customs (KMAC Mini/356) + Cherry Dyesub/DS Keycaps  (Read 34198 times)
Offline tjcaustin
  • King Klaxon
  • Trade Count: (0)
    • Buy stuff
Re: FS: Korean Customs (Cheat/LZMX/KMAC/356/Keycaps)
« Reply #100 on: Fri, 24 May 2013, 02:03:10 »
I am pretty sure I'll be getting "THE CHEAT" for sure.
Good, it's not you I must now despise.
So you weren't the one that bought that LZ MX? I guess I just assumed you had
Nope, he told me he had *just* got money for it when I PMed him.
Offline Rendom
  • Trade Count: (0)
« Reply #101 on: Fri, 24 May 2013, 02:10:50 »
Another Cheat going to Australia? Damn. Represent!
QFR - MX Blue
Offline Moomoo
  • Trade Count: (0)
« Reply #102 on: Fri, 24 May 2013, 02:17:35 »
Nothing done yet still have to talk about the formalities and insurance and all. GH will have to move down under soon enough
Edit: Yay 100th post
« Last Edit: Fri, 24 May 2013, 02:20:43 by Moomoo »
Offline okooko
  • Trade Count: (0)
  • afk.
« Reply #103 on: Fri, 24 May 2013, 02:29:26 »
GLWB that would make 2 cheats down under? unless someone else has one that I don't know about?
(i know one went to MY)
Offline Kayliss
  • Trade Count: (0)
« Reply #104 on: Fri, 24 May 2013, 02:34:20 »
3 in the next week or two  :)) Good luck with the rest of your sales. I would have gone after this Cheat if I didn't buy one yesterday -...-
Offline Patchwrks
  • Trade Count: (0)
« Reply #105 on: Fri, 24 May 2013, 17:49:57 »
Is the cheat still available?
(´・ω・`)denko-chan~~~내 스레드
Offline tsangan
  • Trade Count: (0)
  • 1000/600
« Reply #106 on: Fri, 24 May 2013, 18:00:31 »
No one has paid for it yet but there is like 4 people wanting it, I think one is transferring money to his PP but I'm not sure
Keyboardless
Offline weasle425
  • Trade Count: (0)
« Reply #107 on: Fri, 24 May 2013, 18:43:34 »
Do you realize what you're doing to my bank account Tsangan? Also what other switches are you throwing in?
Offline BunnyLake
  • The OG HHKB Master
  • Trade Count: (3)
  • X
« Reply #108 on: Fri, 24 May 2013, 18:45:57 »
im beginning to think rent may be a luxury i may have to put to one side, it is getting in the way of me and that titan, and im pretty sure i dont need THREE meals a day
Offline calavera
  • Trade Count: (0)
« Reply #109 on: Fri, 24 May 2013, 19:37:43 »
pfffft food is overrated.
  • Trade Count: (0)
« Reply #110 on: Fri, 24 May 2013, 19:44:46 »
food just makes you fat, which makes you die quicker.
therefor food is bad for you.
Offline tsangan
  • Trade Count: (0)
  • 1000/600
« Reply #111 on: Sat, 25 May 2013, 14:51:12 »
still no solid deals yet on the rest of the boards, so feel free to PM me :)
Keyboardless
Offline gameaholic
  • Trade Count: (0)
« Reply #112 on: Sat, 25 May 2013, 22:01:19 »
How hard is it to customize/change the led lighting on a Kmac?
IBM Model M SSK, Filco MJ2 Ninja TKL with Reds ergo-clears, CM Storm QFR 55g Whites, Poker II with Reds
  • Trade Count: (0)
« Reply #113 on: Sat, 25 May 2013, 22:04:47 »
How hard is it to customize the led lighting on a Kmac?
Anyone who can work a soldering iron could swap out LEDs if they wanted.  If you have zero experience, it would probably be better to have someone do it for you. Theres a bunch of us around that can do those things jobs
Offline kaiserreich
  • HHKB Elite
  • Trade Count: (0)
« Reply #114 on: Sun, 26 May 2013, 00:40:06 »
Needs some practice with LEDs.
Basically form a solder bridge, heat it, and pull out the LED.
Then lots of flux and wick/suck out the solder on the pad.
Offline gameaholic
  • Trade Count: (0)
« Reply #115 on: Sun, 26 May 2013, 09:58:24 »
Some other questions:
Does the KMAC LE match the KPAD?
What is the difference between the KMAC and the KMAC LE?
Does the KMAC LE support stepped caps lock?
The lighting scheme I would like is to have the Control, Shift and Alt lit in their respective RGB colors; white for the WASD cluster, and red for ESC and Backspace.  Would this be possible or are the LEDS only wired for the keys that are shown?  Can I turn the lighting on and off whenever I want?
Offline tsangan
  • Trade Count: (0)
  • 1000/600
« Reply #116 on: Sun, 26 May 2013, 17:11:17 »
Match in colour or height? colour wise sadly no they are a different shade of titanium, as for height yes and if you get both I can throw in the extra bar that can attach both together!
KMAC and KMAC LE the difference is the LE might have a slight colour difference from the top and bottom part of the housing, as you can see in the pics I have provided there is little to no colour difference.
You can have to support center stem or side stem, right now the placement of the switch is for stepped caps lock only
You won't be able to do the LED lighting scheme you had in mind as the only location for LEDs are Esc, Function row, scroll lock, caps lock, and left control, and yes you can program it to turn it on and off
Keyboardless
Offline tadbitnerdy
  • Trade Count: (0)
« Reply #117 on: Sun, 26 May 2013, 20:45:02 »
YGPM!
Offline sherryton
  • Trade Count: (0)
  • Kībōdo
    • Originative
Re: FS: Korean Customs (KMAC/KMAC Mini/356) + Cherry Dyesub/DS Keycaps
« Reply #118 on: Mon, 27 May 2013, 22:09:03 »
can i has kbds?
Offline soulfree914
  • Trade Count: (0)
« Reply #119 on: Mon, 27 May 2013, 23:25:39 »
I see some familiar stuff ;)
GLWS
A proud member of OTD & GeekHack
Offline tsangan
  • Trade Count: (0)
  • 1000/600
Re: FS: Korean Customs (KMAC Mini/356) + Cherry Dyesub/DS Keycaps
« Reply #120 on: Tue, 28 May 2013, 18:59:58 »
GLWS
Because you have the same stuff piled up in your closet still unassembled!
Keyboardless
Offline okooko
  • Trade Count: (0)
  • afk.
« Reply #121 on: Wed, 29 May 2013, 02:08:44 »
I demand to see the other 1-2 boards.
(you said 7-8 hehe)
  • Trade Count: (1)
« Reply #122 on: Wed, 29 May 2013, 13:26:46 »
I demand, also!
I demand you sell me the 356CL. C'mon, bro, do it!! ;D
Offline boost
  • BOSTMOBILE
  • Trade Count: (0)
  • NY Giants!!!
« Reply #123 on: Wed, 29 May 2013, 13:29:05 »
I demand, also!
Pretty sure no one in north america has a 356cl...unless jcrouse has one ;)
« Last Edit: Wed, 29 May 2013, 13:54:17 by boost »
-Enzo Ferrari
Offline tsangan
  • Trade Count: (0)
  • 1000/600
« Reply #124 on: Wed, 29 May 2013, 17:01:30 »
You guys are crazy, I don't own any keyboards
Keyboardless
Offline esoomenona
  • Gnillort?
  • Trade Count: (0)
« Reply #125 on: Wed, 29 May 2013, 17:03:34 »
I trade you DSA Retro for 356Pad. :D
Offline phetto
  • HHKB JP
  • Trade Count: (0)
« Reply #126 on: Wed, 29 May 2013, 17:04:05 »
356pad, perfect CC holder :D
Offline tsangan
  • Trade Count: (0)
  • 1000/600
« Reply #127 on: Wed, 29 May 2013, 17:04:31 »
;____;
DSA Retro set!!!
Time to go home and take new pics :rofl:
Keyboardless
Offline phetto
  • HHKB JP
  • Trade Count: (0)
« Reply #128 on: Wed, 29 May 2013, 17:05:34 »
Show the people what the Golden numpad can be.
Offline tsangan
  • Trade Count: (0)
  • 1000/600
« Reply #129 on: Thu, 30 May 2013, 11:31:06 »
« Last Edit: Mon, 10 June 2013, 05:04:57 by tsangan »
Keyboardless
Offline SmallFry
  • Trade Count: (0)
« Reply #130 on: Thu, 30 May 2013, 11:49:57 »
I'll take it...Clacks included, right?
:behindsofa:
Offline esoomenona
  • Gnillort?
  • Trade Count: (0)
« Reply #131 on: Thu, 30 May 2013, 11:54:53 »
I will raise SmallFry's offer with one extra plumbing visit, and I'll even throw in a hedge trimming.
Offline jcrouse
  • Trade Count: (0)
« Reply #132 on: Thu, 30 May 2013, 11:58:59 »
HOOAH
  • Trade Count: (1)
« Reply #133 on: Thu, 30 May 2013, 15:08:05 »
Sell me some of that not for sale stuff T_T
