Author Topic: Keycap & Keyboard Photography  (Read 3785328 times)
Offline Photoelectric
Re: Keycap & Keyboard Photography
« Reply #50 on: Sat, 07 December 2013, 16:51:30 »
I'm loving my new tripod--should have gotten it much much earlier!
A HyPnoCaP:
47171-0
47177-1
47175-2
« Last Edit: Mon, 06 January 2014, 16:03:54 by Photoelectric »
Offline HPE1000
  • Keycap Paparazzo
« Reply #51 on: Mon, 06 January 2014, 15:26:47 »
Offline QWERTim
    • QWERKeys
« Reply #52 on: Mon, 06 January 2014, 15:34:26 »
Can I have a go?
Offline StylinGreymon
  • Keyboard Hipstar
« Reply #53 on: Mon, 06 January 2014, 19:43:00 »
I need to get a better lens, or something, because I can't take any close up shots.
I just have an Olympus micro 4/3 with a 45mm f1.2
If today had been a hippo, then you'd really have to worry about tomorrow.
« Reply #54 on: Mon, 06 January 2014, 19:48:05 »
How are you setting up your camera to do close-up photos?  Are you bringing it very close to the cases or placing it at some distance + using max optical zoom?  The photo you linked is not macro, because those objects are quite large vs. your distance from them.  Macro would be trying to take a photo of a keycap on one of those keyboards.
  • Keyboard Hipstar
« Reply #55 on: Mon, 06 January 2014, 20:05:28 »
The closest objects I can focus on with my current lens are about 2 and a half feet away, and my lens doesn't zoom, so I can't get any closer.
I'm new to photography, if you couldn't ready tell  ;D
« Reply #56 on: Mon, 06 January 2014, 20:08:06 »
Took this fairly recently. Posted it in the keycaps thread. Quite happy with it :thumb:
and one of an original Cherry dyesub (not as good though)
Offline Pacifist
  • on hiatus
« Reply #57 on: Mon, 06 January 2014, 20:09:12 »
How do you get so close?
« Reply #58 on: Mon, 06 January 2014, 20:11:58 »
50mm prime lens
Cheap macro extension tubes that allow you to focus on closer objects
A yongnuo 560 ii external flash
Offline Michael
  • Formerly Bro Caps
« Reply #59 on: Mon, 06 January 2014, 20:14:54 »
I was always fond of this photo, myself.
And this one
« Reply #60 on: Mon, 06 January 2014, 20:16:50 »
Ah, no zoom :(  Do you have a telephoto lens with zoom that you could use instead?  (looks like no, just checking).  Also, nope, can't tell! :)  Most people who are "new to photography" wouldn't even know what lens they have, and you actually listed some details.
« Reply #61 on: Mon, 06 January 2014, 20:28:56 »
The photo that originally made me desire Cherry dyesubs. Love it ;D
Offline HairyBob
  • but my name isn't Robert
« Reply #62 on: Mon, 06 January 2014, 21:04:28 »
That looks amazing. I'd say it's the best picture on the thread so far. The keyboard and the benchmade look great together.
[/quote]
« Reply #63 on: Tue, 07 January 2014, 05:41:22 »
Macro of the inside of a new tactile grey
Macro of some weird grease on the stem of an old tactile grey
Offline joneslee85
  • HHKB Scrub JP
  • Professional Rubyist programmer!
    • Ruby Journal
« Reply #64 on: Tue, 07 January 2014, 05:47:43 »
How stiff will it be if all keys are grey? Comfy at all?
TOO MANY KEYBOARDS THAT I COULD NOT COUNT! BUT I AM STILL USING MY MODEL F77
« Reply #65 on: Tue, 07 January 2014, 05:48:35 »
I wouldn't like to try it.. :))
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #66 on: Tue, 07 January 2014, 08:58:53 »
Photoshop is my favorite lens :))
Offline Dianoda
« Reply #67 on: Tue, 07 January 2014, 11:25:47 »
I think that is the same grease as is used in the new switches, just aged/dirtier (and in a greater amount than usual - but I've seen similar colored grease in new MX switches).
« Last Edit: Tue, 07 January 2014, 11:27:24 by Dianoda »
  • Keyboard Hipstar
« Reply #68 on: Tue, 07 January 2014, 17:49:16 »
Added some different caps today, while learning how to fix bad lighting in post-processing.
Offline Michael
  • Formerly Bro Caps
« Reply #69 on: Tue, 07 January 2014, 17:55:14 »
Nice macro shots, bro. I finally found me some tactile greys. Now... if I just had an MX board to put them in.....
:3
« Reply #70 on: Tue, 07 January 2014, 17:59:27 »
:3
Thanks! ;D Although, I think the photo of the stems is way out of focus. It's really hard to get the focus right with these extension tubes. They do a great job considering they cost £10, but the focusing is really tricky.
Tactile greys are cool. I'll use them in my phantom with some lighter springs once my phantom arrives.. :-X
You're probably right about it being the same lube. The amount is far, far greater than any switch I've seen before though.
« Last Edit: Tue, 07 January 2014, 18:01:44 by Photekq »
Offline Michael
  • Formerly Bro Caps
« Reply #71 on: Tue, 07 January 2014, 18:01:31 »
I would like to submit this, as well. I know my photo skills need some work :3
  • Keyboard Hipstar
« Reply #72 on: Tue, 07 January 2014, 18:19:35 »
Ballin' like King Midas over here.
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #73 on: Tue, 07 January 2014, 21:44:03 »
That picture is worth a thousand words more than a thousand dollars! :cool:
Offline audioave10
« Reply #74 on: Wed, 08 January 2014, 12:24:19 »
that is just...Golden!
DECK Legend "Toxic" - SOLD
96 IBM Model M 82G2383- 95 IBM Model M 92G7453 - SOLD
Cherry G80-3000/Blues
new: MechanicalEagle Z77 RGB/Blues
Offline Dubsgalore
« Reply #75 on: Wed, 08 January 2014, 12:26:47 »
took in a switch and keycap for my photo class..project is 'an object that means something to you'
I'm having to explain what this is to everyone lol
this is a different dslr, owned by the school, my d90 produces better photos on auto, and i would change the settings to make it look good on my d90, but the display screen is ****ed due to my little brother, so thats getting fixed. it's basically stuck on auto.
my flickr is auto shots from my d90
« Reply #76 on: Sat, 11 January 2014, 10:42:11 »
Some GH60 macro ;D
Offline jil_jil32
  • Tokyo Press <3
« Reply #77 on: Sat, 11 January 2014, 11:00:53 »
Very nice, Photekq
« Reply #78 on: Sat, 11 January 2014, 12:38:27 »
Trying to get better with my shots. Took this as a .RAW and then post processed in Photoshop.
Offline Moosecraft
  • HHKB Pro
« Reply #79 on: Sat, 11 January 2014, 12:46:37 »
2nd pic is really nice  :thumb:
« Reply #80 on: Sat, 11 January 2014, 12:46:58 »
Very nice.
Love that olivetti.
Offline ComradeSniper
  • HHKB Pro
« Reply #81 on: Sat, 11 January 2014, 13:47:07 »
Some GH60 macro ;D
Dat texture, wow.
Offline mindoculus
« Reply #82 on: Sat, 11 January 2014, 16:51:19 »
« Reply #83 on: Sat, 11 January 2014, 19:38:14 »
Just a little bit of yellow whilst I was checking my Tai Hao ...
50635-0
Offline mrdar206
  • Tickle me Pink
« Reply #84 on: Sat, 11 January 2014, 20:40:09 »
Some classy  :D
Offline YongJK
« Reply #85 on: Mon, 13 January 2014, 22:25:21 »
Shooting full size keyboard is pain in da ass.
Decided to just shoot one part of it.  :-[
Keyboard: PLU ML87 Mx Blue
Offline HPE1000
  • Keycap Paparazzo
« Reply #86 on: Wed, 15 January 2014, 22:03:43 »
Tried to mix 3 of my favorite things, futurama, coffee and keyboards :)
I might need to try this again so I can get the right shade of red, the keycap is a darker red irl but my gimp skills are lacking.
Offline HPE1000
  • Keycap Paparazzo
« Reply #87 on: Thu, 16 January 2014, 13:35:14 »
MOAR COFFEE PICS
« Reply #88 on: Thu, 16 January 2014, 18:36:58 »
Thirsty now, luckily I have iced coffee to hand.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #89 on: Thu, 16 January 2014, 19:11:16 »
MOAR COFFEE PICS
sexy..........
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline HPE1000
  • Keycap Paparazzo
« Reply #90 on: Thu, 16 January 2014, 19:14:21 »
MOAR COFFEE PICS
sexy..........
I am slightly disappointed I didn't realize coffee would make a good backdrop for pictures earlier :P
Now I need to get enough coffee to use for keyboard pictures :D
« Reply #91 on: Thu, 16 January 2014, 19:18:49 »
I like the coffee pics. Have you taken a pic of the keypop coffee caps on your coffee yet?
Offline HPE1000
  • Keycap Paparazzo
« Reply #92 on: Thu, 16 January 2014, 19:20:59 »
I don't have the coffee set sadly, they were sold out before I got into keyboards afaik. I might as well buy the single coffee cap though :)
Offline leesofi
  • super lurking
« Reply #93 on: Thu, 16 January 2014, 22:33:25 »
i like this original capslock.
« Reply #94 on: Fri, 17 January 2014, 02:38:32 »
Wow!
Much orange.
Very fruit.
Such awesome.
« Reply #95 on: Fri, 17 January 2014, 19:30:51 »
I like the whole board.
Very beautiful.
« Reply #96 on: Sat, 18 January 2014, 02:55:14 »
Alpsulator modded to Matias Clicky/Tactile Pro switches.
There's a bit of a glare but I like how it looks. The focus on the bottom left corner where it's kinda bright then fades back. Got lucky with the shot and decided to keep it 'cause it was cool to me :D.
Offline baldgye
  • Will Smith Disciple
« Reply #97 on: Sat, 18 January 2014, 13:44:41 »
such a nice set up
Offline pasph
Re: Keycap &amp; Keyboard Photography
« Reply #98 on: Sat, 18 January 2014, 18:22:13 »
What board is that? Who has made it?
« Reply #99 on: Sun, 19 January 2014, 19:10:58 »
I really like these, so I thought I'd add them here
51643-0
51645-1
51651-2
