Author Topic: GON's KeyboardWorks - Questions and Answers  (Read 837310 times)
Re: Questions and Answers
« Reply #1050 on: Fri, 29 April 2016, 06:34:50 »
Is it possible with the NERD60 that I only turn on the led under the ESC key when I have installed led's on all switches ?
I don't believe it's possible with the firmware.
Offline Stabilized
« Reply #1051 on: Thu, 12 May 2016, 14:41:22 »
Does anyone know if the on-board SMD LEDs are the same as the ones used for the side LEDs? If they are, should I use the same resistor values?
Offline GiveCandyy
« Reply #1052 on: Fri, 13 May 2016, 05:44:16 »
on board smd leds? you mean the ones on the top side of the pcb? if so, they do work and yes same resistor values.
I wish it wasn't soon
Offline Stabilized
« Reply #1053 on: Fri, 13 May 2016, 06:05:14 »
Yeah those are the ones. Great thanks a lot for the info!  :thumb:
Offline GiveCandyy
« Reply #1054 on: Fri, 13 May 2016, 06:11:17 »
here's a picture, good luck with your build  :thumb:
be sure to send me a picture  ;D
Offline GoatMaster
  • Formerly Franatic89
« Reply #1055 on: Sat, 28 May 2016, 04:35:14 »
Need another download link to the Nerd GUI.
The links on the website are dead ... http://www.gonskeyboardworks.com/manuals/110-nerdy-gui.html
« Reply #1056 on: Sat, 28 May 2016, 04:45:32 »
Strange they're working for me...
Here's a mirror: https://www.dropbox.com/s/qaac2ewpciis808/NerDy%20GUI%201.6.zip?dl=0
Offline GoatMaster
« Reply #1057 on: Sat, 28 May 2016, 09:45:14 »
Thank you also working for me now.
Another question:
Is it possible to add ä, ö, ü with the software to the fn layer ?
Offline kawasaki161
« Reply #1058 on: Sat, 28 May 2016, 10:03:47 »
Depends on how you want to do that. I wanted to do something similar, but it would involve a major pain in the butt if you want to keep it based on the ansi layout, but still have iso-de as the standard layout the OS uses.
You could set up macro keys that just type the corresponding alt codes as an easy alternative.
I'm not familiar with the possibilities of this PCB or software, my answer is based on machine limitations.
Offline GoatMaster
« Reply #1059 on: Sat, 28 May 2016, 10:24:22 »
Just want to add ä, ö, ü to the FN Layer.
Maybe anyone else nows if this is possible.
Offline kawasaki161
« Reply #1060 on: Sat, 28 May 2016, 11:05:29 »
You would have to set your input layout in your OS to iso-de to have native äüö support.
I'll just write down which ansi signals you would need to trigger a ä, ü and ö output if the OS is set to german layout (you cannot trigger a native ä,ü or ö without using german layout in your OS):
ansi= ' triggers a ä output
ansi= [ triggers a ü output
ansi= ; triggers a ö output
« Last Edit: Sat, 28 May 2016, 11:08:23 by kawasaki161 »
Offline GoatMaster
« Reply #1061 on: Sun, 29 May 2016, 05:58:44 »
Okay, thank you.  So I still have to use my autohotkey script.
Offline kawasaki161
« Reply #1062 on: Sun, 29 May 2016, 10:43:36 »
If you are able to set up a macro in the programming software you could set them up to the according alt-codes. That way those outputs would not be machine dependant but saved on the board.
Alt+132=ä ; Alt+129=ü ; Alt+148=ö ; Alt+142=Ä ; Alt+154=Ü ; Alt+153=Ö
Offline mad_eyes
« Reply #1063 on: Wed, 20 July 2016, 16:06:48 »
I'm considering adding an indicator LED to my NerD 60.  I only have white 2x3x4 LEDs sitting around.  What's the best way to add an indicator LED for caps lock?  Should I get an LED holder or just solder straight to the PCB?  I also have SIP sockets lying around if those would be of use.
Offline DanielT
« Reply #1064 on: Wed, 20 July 2016, 23:24:46 »
Straight on the PCB is perfect, no need for raisers or SIP.
Offline mad_eyes
« Reply #1065 on: Thu, 21 July 2016, 01:16:40 »
Perfect. Thanks.
Offline heedpantsnow
  • Old enough to know better
« Reply #1066 on: Fri, 19 August 2016, 16:57:51 »
I'm going to be installing the bluetooth kit on my NerD60 board.  I've read the instructions here: http://www.gonskeyboardworks.com/manuals/134-wireless-module-installation.html
Are there any other thoughts/instructions/best practices for working with this?  Installation?  Pairing?  Status LED's?  Thanks.
I'm back.
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #1067 on: Tue, 29 August 2017, 02:08:52 »
FYI, the GON's KeyboardWorks sub-forum was archived on 5 Sept 2017.
Kindly continue discussion in the Feedback Thread for GON's KeyboardWorks: https://geekhack.org/index.php?topic=83542.0
« Last Edit: Tue, 05 September 2017, 05:22:02 by infiniti »
