Author Topic: SMK-88 keyboard mod - karlito  (Read 78409 times)
Offline karlito
    • http://altitudegame.com
« on: Fri, 04 July 2008, 11:12:28 »
Cherry switches...  Ever wonder???
If you could take a cherry switch from one keyboard and put it into another?
What they look like on the inside?
Now you know. I have a lot of soldering ahead of me and one big question do I make easier to press linear switches by putting the blue stem springs into the black stem switches or just stick w/ the blue stem switches...
I'll post back if and when I finish replacing all the switches on the SMK-88.
Offline graywolf
    • http://www.graywolfphoto.com/
« Reply #1 on: Sun, 17 August 2008, 16:01:43 »
Couldn't you just have swapped the stems?
Offline iMav
  • geekhack creator/founder
« Reply #2 on: Sun, 17 August 2008, 17:28:07 »
Quote from: graywolf;7456
Look at how the switches are mounted.  You can't reach the bottom side to release the top section.  They had to be de-soldered.
Offline graywolf
« Reply #3 on: Sun, 17 August 2008, 19:55:02 »
Quote from: iMav;7459
Ahh, I see.
