Author Topic: Noppo Choc Mid 87 MX BLUE  (Read 2271 times)
Offline Looqz
« on: Sat, 25 May 2013, 14:51:17 »
Hey guys,
I'm new here. Tried to research this keyboard over the past 24 hours but it seems to be a phantom. The only thing I was able to find was a review in Vietnamese, which I could roughly translate with Google translate, the information I get out of it is just not really... well, informative :D.
Now I was wondering, does by chance any of you guys use this keyboard, or has seen a review on it.
It looks nice to me, and the price seems fair. But since there are so many threads around with people complaining about the Choc Mini I wanted to try to get a little bit more info on this board.
Also, since I'm already here, can you guys tell me if there is a good possibility to get custom PBT key-caps, like on wasdkeyboards.com the costumization possibilities are AWESOME, you just can't choose between ABS and PBT :(
Thanks for reading and appreciate your help very much.
Oliver
Offline Masterchief79
Re: Noppo Choc Mid 87 MX BLUE
« Reply #1 on: Sat, 25 May 2013, 15:48:44 »
Write it "noppoo" and try again. ;)
Taiwanese Fake-Model F with MX black copies (1984) | Apple Keyboard (salmon Alps 1987) | G80-1000HDD vintage blacks (1987) | G80-1000HFD vintage blues | G80-1800HFD | QPad MK50 browns | AEK II
Offline mauri
« Reply #2 on: Sat, 25 May 2013, 15:57:24 »
Most vendors in the marketplace sell key caps, wasdkeyboard caps are ABS not pbt afaik
I AM BABAR KING OF THE ELEPHANTS
Offline Looqz
« Reply #3 on: Sat, 25 May 2013, 16:09:06 »
@ Master: and what am I exactly supposed to find? Another thread where people just post how they don't know anything about that keyboard? Enlighten me please.
@Mauri: I know a lot of vendors on the net, what I'm looking for is one LIKE wasdkeyboard, that hast all the options you have there BUT offers PBT keycaps, wasd only offers ABS.
« Reply #4 on: Sat, 25 May 2013, 16:28:49 »
Mid 87 and not Mini.. Fail, forget it..
Offline Photoelectric
« Reply #5 on: Sat, 25 May 2013, 16:45:22 »
I remember looking for reviews on it recently too.  Didn't find much, but there are reviews here and there, like on Amazon:
http://www.amazon.com/Noppoo-Mechanical-Keyboard-switches-Character/product-reviews/B00A3PPJKS/ref=dp_top_cm_cr_acr_txt?ie=UTF8&showViewpoints=1
Noppoo doesn't have stock PBT caps on that model as far as I know.
For stock PBT at similar price range and TKL size, I would go with Keycool 87:
http://www.vendio.com/stores/E-sports-Gaming-equipments/item/shop-mechanical-keyboard-by-sw/key-cool-87-gaming-cherry-mx-s/lid=26561692
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=383
(White comes with PBT caps)
Or a Leopold FC700R (thick PBT) if you have access to it--but that will be more expensive.
« Last Edit: Sat, 25 May 2013, 16:49:42 by Photoelectric »
Offline mauri
« Reply #6 on: Sat, 25 May 2013, 17:56:38 »
I guess you're meaning the custom key cap thingy that lets you choose every cap individually. In that aspect wasdkeyboards, as far as I know is the only one.
You didn't think this would be easy did you : D
Offline jabar
« Reply #7 on: Sat, 25 May 2013, 18:48:31 »
No custom lasering solution for PBT yet. WASD can't figure out a supplier. Asian board makers have lots with pre-installed PBTs... and then there's dyesub groupbuys here but you won't get those sets overnight.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline GeoTang
« Reply #8 on: Sat, 25 May 2013, 18:49:16 »
You're not going to find WASD-level customization. They're pretty unique in that regard.
