Author Topic: Cherry MY: If I'm going to try it what are some of the better quality keyboards?  (Read 1888 times)
Offline dante
I'm going to give Cherry MY a try.  If I'm going to do that I want to try them in a nice quality standard ANSI layout board.
Can I hear a shout out to some models/years I should try?
Offline jabar
um
the real question is, what keyboards come with MY that aren't Cherry G81 keyboards.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline Masterchief79
... are there some at all? There's the G81-3000 of course, a G81-7908 but that one should be rather rare... Else, the only thing I know about is an electronical typewriter named "Triumph Adler Gabriele 7007L" (in fact, all models from the 7007 series should have MY with blue Cherry Dyesub caps - that's the first reason why there are interesting in my opinion ;))
As far as I know, MY hasn't been adapted by other manufacturers (by that I mean, you won't find something like a Filco Majestouch MY edition or something).
Taiwanese Fake-Model F with MX black copies (1984) | Apple Keyboard (salmon Alps 1987) | G80-1000HDD vintage blacks (1987) | G80-1000HFD vintage blues | G80-1800HFD | QPad MK50 browns | AEK II
Offline dante
Do all the G81-3000's use a steel plate?  If not, do you know which year they switched over?
Offline davkol
  •  Post Editing Timeout
For the record, different generations use different stabilizers. I believe it's explained at Deskthority wiki.
Offline therecorder
Offline Peter
You will be wanting one with the old plate-mounted black MY's :
23446-0
(vintage plate-mounted black MY-switches)
23448-1
(Those are metal-rivets !)
23450-2
(Double-shot key-caps !)
23452-3
Don't rely to much on the label for identifying key-caps,
I've seen 'H'-labeled boards with dye-subs !!
If you are lucky you may find a 'NCR'-branded board with an industrial-gray case :)
« Last Edit: Mon, 27 May 2013, 09:32:07 by Peter »
