Author Topic: Wtb PCB mount Cherry stabilizers  (Read 2140 times)
Offline Kayliss
  • Trade Count: (0)
« on: Wed, 29 May 2013, 08:06:47 »
Found some thankyou :)
I am in need of 3-4 sets of PCB mount Cherry Stabilizers, enough for 3 TKL boards atleast. I don't need spacebar wires.
I'm located in Australia so someone who is willing to ship internationally would be appreciated.  :D
« Last Edit: Wed, 29 May 2013, 11:48:39 by Kayliss »
Offline GeorgeK
  • Trade Count: (0)
Re: Wtb PCB mount Cherry stabilizers
« Reply #1 on: Wed, 29 May 2013, 09:08:05 »
PM The_Ed - he had some for me and might ship internationally :)
Offline Kayliss
  • Trade Count: (0)
« Reply #2 on: Wed, 29 May 2013, 09:17:30 »
Thanks I did PM him a few days ago, no luck yet though. Don't really want to spam anyone!
Offline mauri
  • Trade Count: (0)
« Reply #3 on: Wed, 29 May 2013, 10:02:08 »
What determines pcb mounted cherry stabs' size? Only the wire?
I AM BABAR KING OF THE ELEPHANTS
Offline esoomenona
  • Gnillort?
  • Trade Count: (0)
« Reply #4 on: Wed, 29 May 2013, 10:04:01 »
They are built to mount into holes in the PCB versus on a plate. This is accomplished via four holes in the PCB surrounding that switch. Thus, a PCB mounted stabilizer will have four round appendages on the bottom. While a plate mounted one will just be a rectangle.
Offline tricheboars
  • Trade Count: (0)
  • Keyboards are Important!
« Reply #5 on: Wed, 29 May 2013, 10:06:26 »
i have purchased stabs off of mouser.com and onlinecomponents.com
both times it was kind of crap shoot. i wasnt sure if i was ordering exactly what i needed but everything ended up being perfect.
also **** costar. them ****s suck. keep up the good work.
Offline Kayliss
  • Trade Count: (0)
« Reply #6 on: Wed, 29 May 2013, 10:08:15 »
I believe Mouser only has plate mount in stock. :(
Offline esoomenona
  • Gnillort?
  • Trade Count: (0)
« Reply #7 on: Wed, 29 May 2013, 10:08:23 »
Now, now. Your opinion on stabilizers doesn't need to be put so harshly. There are those who love Costar stabilizers.
Offline mauri
  • Trade Count: (0)
« Reply #8 on: Wed, 29 May 2013, 10:13:45 »
I don't think you understood me, or I don't understand you. I've got 6.25 wire for gh60 but it won't fit to my planned layout (or thats what I gathered) So I'm gonna be needing 6.0 spacebar.
Now the question is do I need anything else than the wire (6.0 from a g80-1800) to get 6.0 spacebar? Or do I need specific stabilizers?
Offline esoomenona
  • Gnillort?
  • Trade Count: (0)
« Reply #9 on: Wed, 29 May 2013, 10:18:29 »
The size of the wire is what changes the size of the entire stabilizer. Whether you're using the same stabilizer with a different wire on another PCB is determined by whether that PCB accepts PCB mounted stabilizers or not, if they're PCB mount that is. If they're plate mounted, then changing the wire to an appropriate size is all you need.
Offline mauri
  • Trade Count: (0)
« Reply #10 on: Wed, 29 May 2013, 10:23:23 »
Sweet, my topre wnb bottom row WILL HAPPEN
