Author Topic: Keyboard Case Painting Tips  (Read 622185 times)
Offline mapple
Re: Keyboard Case Painting Tips
« Reply #250 on: Thu, 13 March 2014, 08:18:21 »
hey your job ...... well looking good;)
do you have any tips to put out covers? cause last time i did try i was able to unscrew without any problems but when i did try to take upper cover i broke 3 of 5 plastics which should "lock" in lower one.......
In God We Trust
Offline Photoelectric
« Reply #251 on: Thu, 13 March 2014, 17:32:03 »
Yes, there are a few plastic tabs on the top cover to pop out of the bottom try before you can lift the cover off.  Some people use old credit cards to insert gently between the top and bottom along the front or back of the case and slide them along gently until the tabs open up.  It's the same with Filcos.  Here's a video someone made on how to open one of those cases:
« Last Edit: Thu, 13 March 2014, 17:33:42 by Photoelectric »
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #252 on: Mon, 30 June 2014, 17:40:14 »
With the GH60 plates now complete and the GB coming to a close (hopefully), I'm toying with the idea of painting some, or all of the plates. They are made from stainless steel, non-coated and I was wondering what tips you might have on how to go about painting them?
« Reply #253 on: Mon, 30 June 2014, 18:51:21 »
Why paint stainless steel?
Stainless resists primers like other materials such as aluminum and other odd metals.
I bet Melvang has the best advice.
Otherwise, clean very well, and use Rustoleum. Many very light coats, and follow the directions to the letter.
- D Trump 2026-10-24
Offline mashby
    • Mashby
« Reply #254 on: Wed, 02 July 2014, 11:37:08 »
Thanks fohat.digs.
It's something that I've been debating about, because I do like the look of steel, but I have KBT Pure with WYSE key cap set that I want to add a plate to and I think a dark blue color would offset nice since the plate would be flush with the case.
The case is the low-profile Vortex aluminum case that came with the Pure LE in 2012. You can see an example of what I'm talking about here. In those pictures, he has an anodized silver IMSTO universal 60%.
« Reply #255 on: Wed, 02 July 2014, 13:08:36 »
For metal, I've used Duplicolor's Adhesion Promoter (link to post), after reading about painting bare metal.  It goes on clear in a fine mist, and you can use translucent paint on your plate afterwards (or regular paint)--it's the primer recommended for their MetalCast line, but you can use it with other oil paints just as well (including by RustOleum).  I've painted a sanded Filco plate (steel) with Duplicolor's translucent red color and that primer underneath, and the result was very hard and scratch proof.  That primer is my general favorite to use in general now, because it goes on thinly, evenly, and is basically invisible.
« Last Edit: Wed, 02 July 2014, 13:10:31 by Photoelectric »
Offline exitfire401
  • The Force is Re/\l
« Reply #256 on: Wed, 02 July 2014, 13:16:29 »
Thanks fohat.digs.
I was actually about to come in here with the same question. I'm getting my fiance a qfr since I won a case for one, and I'm wanting to paint the plate purple since I also picked up the bro set for her. This is gonna be a fun project =D
Offline mashby
    • Mashby
« Reply #257 on: Wed, 02 July 2014, 15:11:27 »
@photoelectric -- Thank you. As always, you are a fountain of information.  :thumb:
« Reply #258 on: Wed, 02 July 2014, 15:31:01 »
Just keep in mind that painted surfaces will need more care when cleaning them.  I.e. don't use swabs dipped in alcohol, for example.  Anything that could be a paint thinner.  I used gentle surface / glass cleaners for my painted surfaces, followed by buffing with a flannel cloth or similar.
Offline NumberTwoinQQ
« Reply #259 on: Mon, 07 July 2014, 14:02:19 »
hello!
i recently got a filco tkl which is currently stock and was planning on painting it a glossy white using rustoleum ultra cover 2x gloss spray.  as this will be my first time, i want to be very thorough with the process.  ive read through your keyboard painting tips and have made a rough plan on what im going to do, so please correct me if im missing a step, one of them is needlessly redundant, or one of them are incorrect.
sand with 200 grit, then 800, then 100 to smooth out the case
lightly spray dupli-color adhesion promoter with 2 light coats 5 minutes apart
wait 5 minutes between last coat of adhesion promoter and first color coat
lightly spray rustoleum ultra cover 2x gloss spray with 5 light coats 5 minutes apart
wait 2 days for paint to cure
use clear coat rustoleum ultra cover 2x clear spray 3 light coats 5 minutes apart
wait a day for paint to dry
sand with 2000 grit paper lightly with water
questions about the process:
do i need water when i sand for the first step?
in one of your posts, you said that my paint has a primer already, so i dont need an adhesion promoter; however, as i want this to last a long time, will the adhesion promoter help the longevity of my paint or will it be redundant?
also, the reason i plan to use this one is because i saw in your past posts that you use it on mostly everything; however, there is a rustoleum ultra cover 2x primer spray from the ultra cover 2x line which comes in white (http://www.rustoleum.com/product-catalog/consumer-brands/painters-touch-ultra-cover-2x/primer).  should i use that or stick with the dupli-color, if i use it at all?
are my intervals between coats good?
since the paint will add thickness to the case and potentially cause the case not to fit, do i have to cover the insides with painters tape?  if not do i paint the insides as evenly/well as the outside?
thanks in advance
« Reply #260 on: Mon, 07 July 2014, 14:23:47 »
hello!
thanks in advance
I would modify that process as follows:
wet-sand with 800 or 1000 grit.  You just need to scuff that Filco cover a bit--200-grit was just for removing the rubber coating on QFR covers.  Rinse and dry very thoroughly.  Wipe with a microfiber cloth or anything that can remove as much dust and lint as possible.
lightly spray dupli-color adhesion promoter with 1 light coat.
You need to use the base paint within 5 minutes of spraying the adhesion promoter, as per instructions--I usually only wait a minute or two--it dries extremely quickly.
lightly spray rustoleum ultra cover 2x gloss spray with 3-4 light coats 5+ minutes apart--longer if it's a gloss variety (those have more thinner in them and tend to be more runny/dry slower).  I'd actually recommend a satin finish instead for much better curing and following with gloss clear afterwards, if gloss is what you want.  In high humidity, you will need to wait a good while, maybe even 10 minutes.  Best not to paint in high humidity, as paint can turn pretty dull and not cure properly.
use clear coat rustoleum ultra cover 2x clear spray 2-3 light coats 5 minutes apart
wait a day or two for paint to dry
sand with 2000 grit paper lightly with water--this is only if you also get a rubbing compound, because even 2000-grit sandpaper will leave your painted surface dull.  A rubbing compound is a micro-polisher--it will further "sand" the dulled surface to glossy smoothness.  You can just use large cotton balls with a rubbing compound and then a polish if desired.  Be careful--it may seem like that wet 2000-grit sandpaper is not doing much, but you can definitely sand through the clear coat in places that are easier to sand.
Regarding primers: I really don't know how each particular paint is going to last vs. alternatives.  There are significant variations in composition and ingredient proportions between different paint types, and I've had some paint decide to melt off after a couple weeks (one specific metallic paint type and one metallic acrylic paint) and the rest have been holding up very well.  One of my computer cases painted with "Aqua" satin Rust-Oleum Painter's Touch 2x was painted over 2 years ago and still looks like new.  I used Rust-Oleum's plastic primer on the plastic parts, but I'm not sure it was really necessary--and I'm not a big fan of the Plastic Primer--mine goes on kind of flaky, giving some texture.  I like the Duplicolor Adhesion Promoter for going on in a fine mist and drying very smoothly.
The main issue for a painted plastic case is going to be 1. denting it with random objects hitting it over time and 2. cleaning properly periodically (with something like a soft flannel cloth and no alcohol) and not rubbing it with fingers too much.  That's where clear coat seems good--if you have a decent layer, you can later re-sand it lightly and recoat in clear (though I haven't had to do that yet).
« Last Edit: Mon, 07 July 2014, 14:31:15 by Photoelectric »
« Reply #261 on: Mon, 07 July 2014, 15:47:27 »
thanks for the informative reply!  it was very helpful
i have changed the steps you modified below to a potential final plan:
sand with wet 1000 grit to smooth out the case, then rinse, dry, and wipe down
wait 1-2 minute
lightly spray rustoleum ultra cover 2x satin spray with 4 light coats 5 minutes apart
wait 1 or 2 day for paint to dry
use rubbing compound w/ large cotton balls
one question, what type of rubbing compound should i use? and how should i apply it, ie in numerous coats, just once
« Reply #262 on: Mon, 07 July 2014, 18:18:39 »
You can read about different ones on-line--there are many different brands making and selling them, such as 3M, and also they come in multiple "polishing strength".  There are some fairly tough cutting compounds and those that are just gentle polish.  The one I use are pictured here:
http://geekhack.org/index.php?topic=44191.msg965353#msg965353
Just squeeze a small amount onto a cotton ball and rub the painted surface in firm circular motion.  You'll see when dull spots will begin to shine.  I then use a polish and also have carnauba wax by the same brand.  I would not wax until at least a week after painting, since there will still be curing and evaporation happening for quite some time.
By the way, the price for all this can really add up.  On the plus side, bottles of that size would last you a long long time for small painting jobs.
« Last Edit: Mon, 07 July 2014, 18:20:33 by Photoelectric »
« Reply #263 on: Mon, 07 July 2014, 18:40:39 »
ok. thanks, how does the paint look after just the clear coat and no polishing? can i be finished then?
« Reply #264 on: Mon, 07 July 2014, 22:48:48 »
If you use clear gloss, it looks like orange peel when letting light glance along the surface.  If looking straight on, it will generally be okay.  If you use clear matte, it will look a bit rough and satin-y, not really shiny.  A bit like tiny acrylic beads have been misted onto the surface (if putting a matte clear coat over medium to dark colors, you'll get that effect).  But if you do well polishing a clear coat, it will look like shiny plastic made in the color you've chosen or, if metallic, like shiny reflective metallic surface.
Offline greath
  • A waffle is like a pancake with a syrup trap.
« Reply #265 on: Mon, 16 February 2015, 13:18:10 »
Photoelectric,
Do you have experience using hammered spray paint?
Offline 3K
« Reply #266 on: Sat, 18 July 2015, 06:02:08 »
Today I tried to paint my Duckys case...
I started with sanding it, primer, then sprayed some Creme White, followed by Red Metallic. Appearantly I should have practiced more, since I got some nasty blots when spraying.
After sanding it again (too much, of course) I used the red again, and it came out like this.
(with flash on, the case isn't that glossy IRL, and the LED are barely visible here)
 I guess I'm okay with this!
Offline delatroy
Re: Painted my Keyboard :D
« Reply #267 on: Sun, 08 April 2018, 07:13:30 »
Good stuff!!
Clear, goes on in a smooth fine mist.  Using that on everything now, under paint.  Here is a Filco plate--normally powder-coated matte black--sanded down to bare steel, coated with the Adhesion Promoter, and followed with DupliColor Metal Cast in Red
It's been a few days after spraying, and the finish is very hard.
Not sure if anyone is still watching this thread but I find it very useful info in prep for a Filco rebuild that I'm working on.
Many thanks for the tips. I'm prepping an old, semi-rusty Filco and I've stripping down the metal plate as you can see here:
Couple of questions please as I'm new to this:
  • Shown in the first photo: is it possible to remove the clips (not sure what the technical term is) on the metal place that hold the stabilizers? I would like to be able to sand the entire metal frame so can they be removed? If so, what tools do I need and how they they be removed? Is it possible to buy clip replacements?
  • Should I continue sanding until it's completely clean of paint and rust or is this good enough to apply the primer / adhesion coat?
  • Finally I see that you're using adhesion instead of primer on the frame. Is surface primer and the "multi-purpose" top coat a good choice to paint the frame?
« Last Edit: Sun, 08 April 2018, 07:19:06 by delatroy »
« Reply #268 on: Sun, 08 April 2018, 09:08:33 »
Personally, I  *LOVE*  Rustoleum's hammered metallic finishes.
As far as the current question, I am not familiar with your particular plate, but if the plastic tabs can be removed and replaced after painting you will get an infinitely better result. I have broken a number (5%-10%) of various hold-down tabs, so I might do it with trepidation if I didn't have spares, but you should consider it.
Offline delatroy
« Reply #269 on: Sun, 08 April 2018, 09:13:09 »
Thanks. They are costar stabs. I removed them now with pliers.
« Reply #270 on: Sun, 08 April 2018, 09:19:12 »
Good stuff!!
Good luck with the project—looks like a fun one!
Those are Costar stabilizer clips you’re talking about?  You should be able to remove them by gently squeezing both pointy ends toward each other and pulling one end out of the plate at the same time.  The plastic should be flexible.
Offline delatroy
« Reply #271 on: Sun, 08 April 2018, 09:57:34 »
Yes thanks I got it now.
How much more sanding do you think I should do? Until it's completely bare metal?
Also do you think the primer and top coat selections are okay?
« Reply #272 on: Sun, 08 April 2018, 10:31:01 »
We have different products in the US, but those should be fine.
Offline delatroy
« Reply #273 on: Sun, 08 April 2018, 11:30:08 »
Looking more healthy now. I think I'm ready to paint  :)
« Reply #274 on: Sun, 08 April 2018, 11:34:53 »
Always follow paint directions to the letter, and never try to skimp on drying times.
« Reply #275 on: Sun, 08 April 2018, 20:36:36 »
Looks good.  Not sure if those dark dots are pitting in the metal (uneven texture) or just old paint remnants.  If the former, they will remain noticeable as uneven texture after you paint, so I’d sand more to smooth out.  If the latter—not a big deal, you’re ready to paint and can ignore the remaining black powdercoating.
Sorry I did not answer your earlier questions.  Your specific cans are different from what I’ve used but seem like a fine combination.  As the reply before mine recommends: do follow instructions.  Don’t overspray!  It’s better to do two light even coats than one very wet and runny coat.  Allow each layer to dry well before going over it.  Make sure to paint at around room temperature or warmer and in low humidity conditions.
Offline delatroy
« Reply #276 on: Mon, 09 April 2018, 12:46:59 »
Thank you. The pitting that you mention is rust indeed however I don't think it's worth continuing to sand any further given that it's cosmetic. I'd be a little wary of creating a slight dent in that area which may affect switch height a fraction.
On a side note, is it okay to spray paint in my living room haha? I have a balcony but I think I would have greater control on the environment if it's indoors :)
« Reply #277 on: Mon, 09 April 2018, 13:15:02 »
Beyond inhaling unhealthy fumes, you're going to have a cloud of tiny paint particles landing on everything in a radius of 2-3 feet around where you're spraying.  You don't want to spray too closely to the surface to reduce this overspray, as then you will lose the ability to do an even coat.  I would recommend getting a cardboard box, putting your parts on it, and going somewhere outside where it won't be a big deal to have some paint landing in the vicinity of your box.  Also wear clothes and shoes you won't mind getting covered in some tiny paint particles (can easily ruin shiny leather shoes).
Offline delatroy
« Reply #278 on: Sun, 13 May 2018, 05:13:11 »
Finished with respraying the metal frame. Used the bath as a makeshift working area  :)
Happy with the result considering the original condition:
Used 3 light coats of primer and 2 light coats of top on both sides.
Next to carefully prep the plastic cases.
« Reply #279 on: Sun, 13 May 2018, 12:18:03 »
Great work!  I love your thorough cover-up of the walls with plastic.  The plate came out well--the texture probably helps hide surface imperfections.  Be sure to allow the paint to dry for at least a couple of days on the plate before handling it much.  The paint is dry to touch relatively soon, but it takes a few days or longer to completely harden to its toughest.  Can still accidentally make an indent with a fingernail or wrinkle the paint if not being too careful while all the layers of the paint are drying.
« Last Edit: Sun, 13 May 2018, 12:21:43 by Photoelectric »
Offline delatroy
« Reply #280 on: Sun, 13 May 2018, 12:28:45 »
Thanks for your advice on this thread - it's really helped me. You can see some pitting but I think it's fine as you'll never see it anyway. I wanted to paint it so the rust doesn't spread to preserve the keeb for the future :)
I'm doing the plastic prep now. It looks from page 3 of this thread that you took the paint off almost completely so I'm going for that. I'm not sure where it starts / finishes on the Filco. It's already well scuffed up and greyish looking but I don't know if there's anything under that or not.
« Reply #281 on: Sun, 13 May 2018, 12:40:11 »
Technically there's stuff that can fill in the pitting prior to painting, but it's mostly nasty, such as Bondo (sandable and super hard when it dries, but the fumes are horrible. It works really well with sticking to anything).
Is your Filco black to begin with?  You really don't need to do much to a stock Filco cover if it's black, just maybe sand it a bit to even out the texture.  If you like the original texture and don't mind that it will be amplified after spraypainting, sanding is not necessary.  If it's one of the painted or printed types like Camo, I would also go over the outer surface with fine grit sandpaper to roughen up the surface a little for better primer adhesion.  Wipe the surface with a big cotton ball soaked in alcohol prior to painting to remove any finger oils.
Offline delatroy
« Reply #282 on: Sun, 13 May 2018, 14:52:32 »
Yeah it's a black Filco. I've already taken it down quite a lot but not as much as your previous jobs. I don't want it to get too thick. I would have guessed that the finish would be better if I take a lot of the paint off?
« Reply #283 on: Sun, 13 May 2018, 16:49:17 »
There's no paint on the black Filco, as far as I know--just textured plastic.  Other colors might be painted or printed.  That's why I said there's no need to sand it, unless you just want to smooth the texture.  It was CoolerMaster QFR tops that you saw sanded in earlier posts--those have "soft touch" rubberized coating on the old gunmetal silver covers, for example.
Offline delatroy
« Reply #284 on: Mon, 14 May 2018, 14:11:07 »
Are you sure? I would be surprised if it didn't have some kind of clear sealant at least.
« Reply #285 on: Mon, 14 May 2018, 15:12:09 »
I'm pretty sure, yeah.  Just textured plastic if it's black to begin with. I mean I haven't looked at the newest Filcos, but the ones I have had a few years ago that were black did not require any sanding.
Offline delatroy
« Reply #286 on: Wed, 16 May 2018, 02:52:47 »
Do you have any advice on sanding the shall parts? For example the inside on the caps lock mum lock led holes and underneath the filco logo
« Reply #287 on: Wed, 16 May 2018, 07:46:53 »
You can fold sandpaper around an edge of a credit card or tip of a sharp stick, or roll it into a narrow cone shape.
Fortunately tiny spaces are less important.
« Reply #288 on: Wed, 16 May 2018, 10:47:02 »
Definitely advise against sanding inside the Filco logo if you want to preserve the neat shape of the opening (just don't overspray the paint into it, and the original logo should still fit back into the opening).  I still think your sanding of the black top is futile.
Offline delatroy
« Reply #289 on: Thu, 17 May 2018, 03:17:40 »
Okay thank you. I will give it a light sanding so that the primer bonds properly to the plastic and leave it at that.
Offline delatroy
« Reply #290 on: Tue, 22 May 2018, 04:23:36 »
Finished case prep. Used 180-2000. Removed the feet by pushing hard on one side and lifting up.
Should have a good surface for the primer to bond with now:
I'm not intending to paint the inside of the rubber grip holders.
On a side note, does anyone know where I could find replacement Filco rubber grips that stick to the underside of the case? I kept the old ones but I'm not sure how easily they are going to stick.
« Last Edit: Tue, 22 May 2018, 07:31:23 by delatroy »
Offline delatroy
« Reply #291 on: Thu, 24 May 2018, 14:05:02 »
I've applied the primer using thin coats which is going well. Even though I sanded the case with 2000 smooth, the primer texture is quite rough. Wondering if I should sand it with 2000 before applying the top coats?
« Reply #292 on: Thu, 24 May 2018, 17:15:10 »
Not sure what "quite rough" means but primer is intended as a undercoat that the top coat adheres to, therefore, it shouldn't be glossy smooth anyway.
« Reply #293 on: Thu, 24 May 2018, 19:41:00 »
You shouldn't sand the primer--you can sand the paint after you're done painting, after a few well dried top coats.  Textured finish is inevitable with canned spray paint.  This is another reason I like the Duplicolor Adhesion Promoter as primer--it goes on in a super fine mist and doesn't really add much visible texture.
Offline delatroy
« Reply #294 on: Sat, 26 May 2018, 11:11:16 »
Thank you. Between the primer and the top coat. How long should I wait?
Also between the top coat and final sanding, how long should I wait?
« Reply #295 on: Sat, 26 May 2018, 17:40:43 »
Strongly depends on the paint itself and your painting conditions.  In my experience gloss paints have more thinner in them or else formulated in such a way as to stay runnier for longer.  They take longer to dry vs. matte paints.  Also if you paint in warm or humid conditions, it takes longer too.  I would say that between the primer and top coat, you can just wait an hour or two (follow instructions on the can).  With the primer I mentioned that I like, I only wait about 10 minutes, as it goes on super fine and dries really fast.  As for waiting between paint coats, as long as you're doing them in very fine even layers, you can just wait about 10-15 minutes before doing the next coat, for something like 3-4 fine coats.  I would wait a full day for the top clear coat.  I would wait 2 days to begin sanding and polishing--test on a small, less conspicuous area.  If you intend to do a lot of surface smoothing from orange peel texture to glass smoothness, definitely do 2-3 layers of clear coat so that you don't sand through it when doing the final fine-grit wet sanding.
Once I used a white pearl paint over white base paint, and the pearl layers were still soft to fingernail dent test 3 days after painting.  Thankfully the surface hardened properly after a full week of curing.
« Last Edit: Sat, 26 May 2018, 18:11:47 by Photoelectric »
« Reply #296 on: Sat, 26 May 2018, 19:59:53 »
EXACTLY  AS LONG AS THE INSTRUCTIONS SAY, OR LONGER.
Offline delatroy
« Reply #297 on: Sun, 27 May 2018, 04:35:22 »
It just says when the next coat can be applied, not when you can sand etc  :)
Thank you. In this case, I think I'm ready to apply the top coats. It's been around 2 days. After this, I'll leave the top coats dry for one week before considering sanding for safety's sake.
« Last Edit: Sun, 27 May 2018, 04:37:11 by delatroy »
Offline delatroy
« Reply #298 on: Sun, 22 July 2018, 08:45:48 »
Well I finally finished!  :)
before:
after:
Full album and build log
https://imgur.com/a/shUlWbp
 Thanks everyone for the tips!  :)
« Reply #299 on: Sun, 22 July 2018, 11:35:51 »
Quite a transformation--thanks for sharing!  I always love the refurbishment stories of well-loved items getting a second chance.  Those old switches looked super bad.  Hopefully the PCB didn't suffer much from all that surrounding corrosion.
I like the new industrial color look  :thumb:  Take care with cleaning the case to avoid using any harsh chemicals.
