Author Topic: Post your Duckies!  (Read 365498 times)
Offline fabian101
  • Cardbox
Re: Post your Duckies!
« Reply #700 on: Wed, 21 January 2015, 21:08:45 »
Have not seen anyone posting a picture of a Ducky Legend recently or at all.
So here's my Ducky Legend after two month plus of owning it.
88139-0
88141-1
88143-2
[WTB] Nothing For Now
Ducky Legend + Invisible FC660C
« Reply #701 on: Wed, 21 January 2015, 21:14:46 »
How do you like the legend? I haven't heard much about that model.
Offline fabian101
  • Cardbox
« Reply #702 on: Wed, 21 January 2015, 21:23:43 »
Well considering it's my first mechanical keyboard, I like it very much.
The 5mm thick aluminum case top is nice and smooth. I guess due to that, it is heavier than what I expected it to be.
But I don't mind the heaviness, as it feels very solid. I just wish they made a clear switch variant.
« Reply #703 on: Wed, 21 January 2015, 21:24:59 »
Yeah I don't know why ducky doesn't make more boards with clears, I've got a brand new shine 3 I will probably add clear switches to some day. Thanks for the info!
Offline fabian101
  • Cardbox
« Reply #704 on: Wed, 21 January 2015, 21:30:54 »
No problem. Before I forget...
One drawback of this keyboard is that the usb cable is not removable, so no quick and easy cleaning as I need to plug it off the computer.
« Reply #705 on: Wed, 21 January 2015, 21:36:34 »
That is a little surprising on what I would have considered a high end ducky board, kind of disappointing actually.
« Reply #706 on: Wed, 21 January 2015, 21:43:24 »
All cables are removable if you pull hard enough :p
Offline hoz
  • 60% is more than enough.
« Reply #707 on: Mon, 23 February 2015, 10:07:11 »
Yoth Mini, MX Greens with a mix of duckys blank white pbt and pink engraved pbt sets
Yoth Mini, MX White with duckys yellow dyesub pbt set
one 40% and seven 60%'s
« Reply #708 on: Mon, 23 February 2015, 19:54:30 »
Since when did Ducky do a yellow set like that? :eek:
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #709 on: Mon, 23 February 2015, 20:13:57 »
I'm assuming you're looking for that set now...
« Reply #710 on: Mon, 23 February 2015, 22:22:11 »
What makes you think that? ;)
Offline hoz
« Reply #711 on: Tue, 24 February 2015, 01:44:42 »
« Reply #712 on: Tue, 24 February 2015, 03:36:25 »
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=1091 :)
:D
Tempting, as I only have 2 sets of black on yellow, 2 sets of white on yellow, and set of yellow engraved.
Needs moar yellow!
Offline DeviAchariya
« Reply #713 on: Thu, 05 March 2015, 11:49:08 »
My very first mechanical keyboard & keycap sets: Ducky Shine Mini with Cherry MX blue & blank white PBT with stock keycaps.
Ducky Shine Mini
    [my first!]
Offline GenKaan
  • Mer caps, mindre käbbel
« Reply #714 on: Fri, 06 March 2015, 03:55:24 »
Finally a pic thread I can be a part of <3
Call this: Shine 3 - Paistaa edition
All white all right
Stolen caps from G2Pro dye sub PBT
Work Keyboard (G2Pro with Mx Clears)
Different layouts over the years
|| @Home:: Shine 3 TKL (Mx Red / Deep Space)  || @Work:: G2Pro (Mx Clear / Dye Sub PBT) ||
@Reserve:: HHKB (Topre 45g / Mixed PBT) // Das v3 (Mx Brown / Blank PBT)
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #715 on: Sun, 17 May 2015, 00:57:50 »
Did some stuff to my shine 2 tkl. :D
The old picture of the stock board is somewhere in the topic :)
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #716 on: Sun, 17 May 2015, 04:13:52 »
Lovely board pichu! :thumb:
Offline Johan
« Reply #717 on: Sun, 17 May 2015, 07:09:56 »
Is that a startale pad?
Uh, stuff.
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #718 on: Sun, 17 May 2015, 16:58:16 »
Here are a few shots of my YOTH Mini with some different caps.
« Reply #719 on: Mon, 18 May 2015, 05:48:20 »
I like how that looks with the rainbow keycaps :)
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #720 on: Wed, 20 May 2015, 01:14:39 »
Heh, thanks. Good tip you gave me to remove the previous LEDs. Tweezers and pull!
Yes it is! I was a big fan of the previous ST sc2 players, Squirtle, Bomber, Life but they moved on...  :'(
Offline pizza_is_a_lie
  • ISO Master Race
« Reply #721 on: Wed, 20 May 2015, 16:56:03 »
V1.0
Offline Lain1911
  • God of the Wired
« Reply #722 on: Wed, 20 May 2015, 22:22:52 »
Nice!
Offline C5Allroad
« Reply #723 on: Tue, 02 June 2015, 19:10:29 »
Man you make me consider a mini...
  • ISO Master Race
« Reply #724 on: Wed, 03 June 2015, 01:26:22 »
They're so much fun! The only things with it are that it doesn't have any legs to angle it or prop up the base and the micro USB is on the left-hand side which you can see was a bit of a menace for me as my cable needs to run to the right. The cable supplied by Ducky is right-angled though so all is good!
Offline C5Allroad
« Reply #725 on: Wed, 03 June 2015, 19:31:15 »
I like the right angle lol.
  • ISO Master Race
« Reply #726 on: Thu, 04 June 2015, 06:26:46 »
Well, there we go then - one less argument against getting one  :thumb:
Offline C5Allroad
« Reply #727 on: Thu, 04 June 2015, 17:47:58 »
Except my wallet...  :p
Offline seville57
« Reply #728 on: Thu, 09 July 2015, 15:38:11 »
My white ISO/Nordic Ducky Shine 2, Cherry MX Brown and white LEDs.
My English ISO Ducky Shine 3, Cherry MX Blue and blue LEDs with Duckys 109 ISO/Nordic PBT laser engraved Grey/Blue keycaps set.
My ANSI Ducky Shine 4 69 Edition Fire Version with Galaxy Class keycaps set from Massdrop.
My ANSI Ducky Shine 3, Cherry MX Black with red LEDS and Tai-Hao Miami keycaps set + 550 Paracord Miami sleeved USB cabel by Pexon.
My ISO/Nordic Ducky Shine 3, Cherry MX Red with Duckys 109 ISO/Nordic yellow keycaps set. The "BEER BREAK" caps don't belong to the yellow set.
My ANSI Ducky Shine 3 Cherry MX Black.
My ANSI Ducky Shine 3 Cherry MX Red with white LEDs and Varmilo Mint front printed caps.
« Last Edit: Sun, 02 August 2015, 17:08:15 by seville57 »
Offline Abolfazl
« Reply #729 on: Fri, 05 May 2017, 19:45:14 »
Ducky Shine 6 White Edition
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #730 on: Fri, 05 May 2017, 21:39:44 »
Ducky dk9008g2 pro with hydro and Invyr 'Panda' linears.
MK2016 ducky clone with cherry browns and photoshop caps.
both are basically the same board, totally awesome work horse.
-Dana
Offline ojrask
  • juuh elikkäs
« Reply #731 on: Wed, 12 July 2017, 10:58:06 »
My 4-ish years old DK9008P (Premier CCnG). Stock PBT ISO Nordic caps with MX Blues underneath.
Current:
Coming up:
IC/GB:
Offline ar_hoi
« Reply #732 on: Sat, 25 November 2017, 22:23:23 »
Hello all here are my duckies  ;D 182808-0
Ducky One TKL RGB MX Black | Ducky Pocket MXBrown
Offline Duckyreddy
  • Better skadoodle, poodle.
« Reply #733 on: Sat, 25 November 2017, 22:28:53 »
Silent reds!
Ducky One Cherry MX Silent Reds
Leopold FC660M MX Blue
Logitech G403/ Razer Naga 2014
Offline Zylkan
« Reply #734 on: Sun, 26 November 2017, 14:50:48 »
Silent reds!
Btw, how do you like them silent's ? I'm waiting on some silent blacks and I'm really curious to seem how much of a difference can there be.
Offline Duckyreddy
« Reply #735 on: Sun, 26 November 2017, 18:28:11 »
Silent reds!
Silents are IMHO better then standard reds, the silents are softer in bottoming out and really are quieter than their unsilenced counterparts, they also have a little reduction in travel due to the dampener, my batch of silent reds are smooth, very smooth.
They are very nice to use and I believe the S-blacks will be snappier and even better to type on. :)) Hope that helped.
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #736 on: Sun, 26 November 2017, 19:31:44 »
Silent reds!
The one thing I don't think I'll like about Cherry MX Silent is the travel reduction.  That's the main reason I could never use O-rings.
Still want to try them tho.
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline Duckyreddy
« Reply #737 on: Sun, 26 November 2017, 19:43:18 »
Silent reds!
O-Rings are terrible, for me at least.
But Silents are only reduced by 0.3mm if I recall correctly and they feel much more natural if you know what I mean?
The experience is very nice overall, think of it as a softer MX Red that isn't as sharp and I can't repeat this enough. It's smooothhhh
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #738 on: Sun, 26 November 2017, 20:05:57 »
Silent reds!
I do like the Matias dampened switches, so maybe I will like them.
WTB/WTS/WTT ---->
Offline Duckyreddy
« Reply #739 on: Sun, 26 November 2017, 22:04:13 »
Silent reds!
Matias quiet clicks? I've never tried them! Would love to one day!
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #740 on: Sun, 26 November 2017, 22:31:52 »
Silent reds!
Yeah, their "quiet click" switches.  I would still rather there be no travel reduction, but I do like them.   Probably my favorite Matias switch.
WTB/WTS/WTT ---->
Offline Zylkan
« Reply #741 on: Mon, 27 November 2017, 12:52:34 »
Silent reds!
Thanks a lot my friend!
Offline Duckyreddy
« Reply #742 on: Mon, 27 November 2017, 13:19:26 »
Silent reds!
You are very welcome. :))
Offline schafwax
« Reply #743 on: Mon, 18 June 2018, 15:43:06 »
SA Carbon Ducky Mini
Ducky Mini
MX Clears
SA Carbon
Offline 71
« Reply #744 on: Thu, 16 September 2021, 12:38:59 »
abit late to the party :P
