Author Topic: What's the difference between the Quickfire Rapid and the stealth versions?  (Read 2458 times)
Offline KungFuPanda
Are there any differences between the two other than the top blank keycaps?
Offline Photoelectric
Should be only the keycaps, as newer Rapids come without branding on the top of the case too.
Offline Schattendolch
i think the stealth versions come with no branding? and side printed keycaps
Offline dante
The stealth version has branding on the back of the keyboard where the cable comes out.
Just incase one day you forget where your keyboard came from.
Same as the newer Rapids, right?  I believe the only difference is keycap printing, and Rapid comes with silver and black cases.
Offline domoaligato
I am typing on a newer rapid right now.
they have branding on the back only.
the stealth has ninja caps (legends printed on the front)
Offline argyakrivos
Re: What's the difference between the Quickfire Rapid and the stealth versions?
« Reply #6 on: Thu, 05 September 2013, 17:02:40 »
They seem to have different dimensions (based on their website)
QuickFire Rapid: http://www.coolermaster-usa.com/product.php?product_id=3060
QuickFire Stealth: http://www.coolermaster-usa.com/product.php?product_id=10035
Rapid
355(L)x135(W)x35(H) mm
14(L)x5(W)x1(H) inch
Stealth
14(L)x5.3(W)x1.4(H) inch
The numbers seem a bit odd. Can someone confirm that?
