Author Topic: Leopold FC700R Keycaps  (Read 2027 times)
Offline MAFAKINGAME
« on: Tue, 04 June 2013, 23:53:32 »
Hey guys,
Just got my new Leopold FC700R in the mail today.
Is it normal for the keycaps to have some sort of reflection where the letters are at?
It's as if there is some sort of thin transparent tape on some of the letters.
I'll include pictures when I get home.
« Last Edit: Tue, 04 June 2013, 23:57:42 by MAFAKINGAME »
Offline flacman
  • I have oneness with cup rubber
Re: Leopold FC700R Keycaps
« Reply #1 on: Wed, 05 June 2013, 05:26:35 »
Hey guys,
Yes, this is perfectly normal. The keycaps have a coating on them.
Source: PC Case Gear, Australia
HHKB Pro 2 | Realforce 87U 55g | Realforce RGB | RAMA Kara
« Reply #2 on: Wed, 05 June 2013, 06:48:18 »
If you look at my signature, I have an FC700R review. I believe someone posted there why there's the coating. PCCaseGear explained that the caps were having wear issues and the coating your referring to fights the wear.
Offline MAFAKINGAME
« Reply #3 on: Wed, 05 June 2013, 10:33:28 »
Hey guys,
Thanks for your answer!
I'm still going to try to return it to PCCG. Unfortunately, I found a small dent on the body of the keyboard.
Hopefully PCCG agrees to send me a new set.
