Author Topic: Apple Extended Keyboard 2 mods  (Read 86469 times)
Offline aon
« on: Sat, 02 August 2008, 09:49:25 »
Hi,
Today I ended up in a situation where I don't have a desktop machine at home, and since my laptop doesn't have a PS/2 port, the only keyboard I have that I can use it is the Apple Extended 2 I acquired a while ago, for the unbelievably steep price of 0.50EUR + shipping.
The first problem I noticed was that the blind marks are on the wrong keys, so I start typing from the wrong position and the text comes out as gibberish. This was a matter of just swapping the keycaps:
But there's more to it. I really like having Ctrl in the right place, i.e. where they usually put Caps Lock these days. On the Extended 2 the caps lock key actually locks down so I had to open up the whole thing, desolder the switch and put another switch to its place. I ended up swapping the Scroll Lock and Caps Lock switches, so now I have a locking scroll lock.
While there, I made Caps Lock a duplicate of Ctrl and swapped the command and Alt keys around, since I'm used to having my Alts next to the spacebar. Normally I would've done it in software, but since the  thing was already open, and I don't have any emotional ties to Apple hardware...
I reverted the swap on the right side a bit later, since I need to use the command key as an AltGr on this thing, because at least with the iMate the key labeled as AltGr produces the same keycode as Alt.
And here's the finished product:
It got a bit better, but there are better boards. The white Alps switches have a bit too much friction for my taste, although that might be an issue with this particular unit, and the iMate ADB->USB adapter I have seems to get confused when I type fast enough :)
I'm going to pick up my HHKB Pro2 from the customs in a few days anyway so this is just a temporary solution.
Offline iMav
  • geekhack creator/founder
« Reply #1 on: Sun, 03 August 2008, 09:04:12 »
A review from Finland!  Thanks for the contribution Aon.  We'd love to see a review of your HHKB Pro 2 once you get hands on it as well.
Offline aon
« Reply #2 on: Tue, 05 August 2008, 08:44:41 »
Hi iMav,
Yeah, Finland probably doesn't have that many keyboard enthusiasts :)
I'm typing this on my HHKB. We'll see if I can write anything objective about it, so far it's the best thing i've ever touched :)
Offline itlnstln
« Reply #3 on: Tue, 05 August 2008, 09:16:25 »
Are you sure that's not just your typing? :)
Offline aon
« Reply #4 on: Tue, 05 August 2008, 09:40:00 »
Quote from: itlnstln;7121
Quite sure :)
Offline lowpoly
« Reply #5 on: Tue, 05 August 2008, 10:26:42 »
My Ext. II has that as well. Nice mod though.
What's happening in your avatar pic?
Offline aon
« Reply #6 on: Tue, 05 August 2008, 11:59:19 »
Quote from: sofa king;7123
It's a warning against using scissor switch keyboards: they can burst in flames!
(well, with some help at least)
That one was already dead, though - it didn't play nicely after some red wine got into it. When you pressed a key, you actually got more or less all the characters in a 3x3 matrix around that key. It almost seemed like the wine had gone down my throat and not inside the keyboard :)
