Author Topic: [WTB] Alps Keyboards  (Read 3032 times)
Offline morpheus
  • Trade Count: (0)
« on: Thu, 06 June 2013, 20:46:17 »
Basically just looking for some Alps Keyboards that are in good to new condition, meaning no sticky substances in the keys, or broken keys.
If you could upload a pic on this thread, I'd appreciate it  ;D
Also, I have EBAY account so if you've got one there, please direct me to your item.
Thanks.
Offline AKIMbO
  • HHKBro
  • Trade Count: (0)
Re: [WTB] Alps Keyboards
« Reply #1 on: Thu, 06 June 2013, 21:01:31 »
What kind of alps switches are you looking for broski?
| KBD75 (box reds)
Offline morpheus
  • Trade Count: (0)
« Reply #2 on: Thu, 06 June 2013, 21:07:20 »
Any type.
But preferably something similar to the ones in the Dell AT101W. I have one but I had to shelve it because the keyboard was D.O.A. (dirty on arrival), as well as the space bar was FUBAR.
Also, looking for light switches, similar to Cherry MX Brown or Red (45g).
Offline alaricljs
  • I be WOT'ing all day...
  • Trade Count: (0)
« Reply #3 on: Thu, 06 June 2013, 21:13:05 »
Ducky 1087XM w/ greens... those springs are comparable.  I stuck mine in Matias' Quiet Click switches.
PS - The board itself is fairly crap.  Decent key caps tho.
« Last Edit: Thu, 06 June 2013, 21:28:04 by alaricljs »
Filco w/ Imsto thick PBT
Offline ekw808
  • Trade Count: (0)
  • Ekw
« Reply #4 on: Thu, 06 June 2013, 22:06:51 »
I have a ducky 1087xm it is a little dusty, but everything works and is still in pretty good condition.
[One Keyboard at a time]
Offline morpheus
  • Trade Count: (0)
« Reply #5 on: Fri, 07 June 2013, 05:47:21 »
Does it feel similar to the Dell AT101W? Also, why is the board crap? Sort of makes me want to pursue older vintage boards instead.
Offline kmiller8
  •  Post Reporting Timeout
  • Trade Count: (0)
  • Who is that kmiller8 guy?
« Reply #6 on: Fri, 07 June 2013, 07:24:04 »
imo, I have the opposite opinion of alaricljs, the board is decent, and the caps are crap, I think one of my XM duckies has like  4-5 broken caps from day to day use :x
Offline alaricljs
  • Trade Count: (0)
« Reply #7 on: Fri, 07 June 2013, 08:59:13 »
I have never used another Alps board so have only Filcos and Koreans to compare to.
The caps feel nice, but yes they can be fragile I broke 2 removing them from switches.  The entire board is pretty fragile.  The plate is flimsy and the switches aren't fully against the PCB in a lot of places.  Replacing the switches helped, but I don't have a complete board to feel the overall effect since my case is quite dead.
My point behind recommending it which I didn't state explicitly but did mention... you wanted something near browns force level, XM Greens are what you are looking for.
Offline kmiller8
  • Trade Count: (0)
« Reply #8 on: Fri, 07 June 2013, 09:13:09 »
Yeah, I guess $45 mech board doesn't scream quality :))
I don't think I removed the case to look at the PCB and switches build quality. I've been using one of the 1000 XM boards at home for the past week or so, it's definitely a much lower quality, with the caps having a lot of wobble. Maybe I should try putting another one of my alps compatible cap sets to see if it's the caps or the switches causing the wobble (probably both tbh)
