Author Topic: Little help finding the right connector  (Read 2532 times)
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« on: Fri, 07 June 2013, 04:20:44 »
alright guys I need a touch of help finding some connectors I need for a project.  I am wanting to build a cable for between my PC and my keyboard case that I am going to be building.  The problem is I need way more than 4 connectors that USB uses.  I have decided on using the old Centronics 36 connector used for printer cables that used the bail lock.  However, the first cable that was male to male had a review that said not all the pins are used.  I can find the panel mount receptacles that I would need from digi key but need a little assistance in finding male plugs for this that I can deal with the looks of.  The only ones that I can find have this ugly screw clamp deal for the wires that come out of the shroud.  This is something I do not want.  If someone could point me in the direction on where to find blank plugs with solder connections and good looking shell it would be greatly appreciated.  If I have to buy a cable that has plugs that can be disassembled that would be fine as well.  Any help in this would be awesome.
Melvang
Here is a pic of what I do not want in the shell
ugly shell
Re: Little help finding the right connector
« Reply #1 on: Fri, 07 June 2013, 07:58:52 »
Why not buy a ready-made cable of the type you want, and only cut one end? At least the visible end would be clean and strong, and you could connect what you wanted at the back.
"you've got to cheat like hell"
- D Trump - 2026-09-10 Dallas, Texas
"The pure products of America go crazy"
- William Carlos Williams - "For Elsie" 1942
Offline Melvang
« Reply #2 on: Fri, 07 June 2013, 08:21:29 »
Because of what I want to do with the cable sleeving and in a way both ends are visible due to the computer case I have.  I have one of the Silverstone cases that have the motherboard rotated 90 degrees so all my I/O connections are on top of the case under a mesh panel
