Author Topic: what are 60% keyboards?  (Read 1459 times)
Offline findingthelimit
  • Rawr
« on: Sun, 09 June 2013, 01:44:41 »
I'm wondering how one operates without the arrow keys on a 60% keyboard? seems quite hard gettnig used to. also, what are the best 60% boards? filco, ducky mini, or poker 2? where can i get one? :D
Poker 2 reds, GH60 42g ergo clears
Offline The_Beast
  • I like wood ಠ_๏
Re: what are 60% keyboards?
« Reply #1 on: Sun, 09 June 2013, 01:46:17 »
Arrow keys are the menu, windows, control and shift key on the right side of the board. Works just fine
Poker is highly recommended. Look in the classifieds or google it to find a Poker
Offline esoomenona
  • Gnillort?
« Reply #2 on: Sun, 09 June 2013, 01:46:45 »
60% keyboards operate due to math. When you have a 100%, and then you subtract 4 arrow keys, you get 40% off.
« Reply #3 on: Sun, 09 June 2013, 01:51:37 »
Or just use them in an environment where arrow keys are not necessary.
Offline FuriousGeorge
« Reply #4 on: Sun, 09 June 2013, 13:34:46 »
Or get a 60% that has arrow keys. There are a couple choices right now. The layout is a little different, so it depends on what you are looking for.
