Author Topic: [IC] ISO Addon for DSA Dolch Replica  (Read 23831 times)
Offline vorn
Re: [IC] ISO Addon for DSA Dolch Replica
« Reply #50 on: Tue, 18 June 2013, 14:21:30 »
Keen to see the pricing. I find the structuring of these kits a bit too comprehensive.
Kit 1 - I would use 3 of the 8 keys (or only 2 if I get Kit 2)
Kit 2 - I would use 6 of the 20 keys
So that's 8 out of the 28 keys being put to use. This is slightly exaggerated since not using the Yellow WIN keys is a personal preference, but even then, 10 / 28 keys. Did you base these kit structures on another GB?
Offline domoaligato
« Reply #51 on: Tue, 18 June 2013, 14:47:14 »
Kit 1 is not just the iso kit.
it is all the missing keys from druger's groupbuy to finish possible layouts.
Kit2 is ALL RGBY mods.
this includes all the RGBY mods and keys needed for cherry/phantom/7bit/gh60 layouts. I do not want to sort tsangen kits, moogle kits, winkeyless 1.5 mods, standard 1.25 mods, etc, etc.
Once you see the pricing I do not think your going to be that concerned anymore about a few extra keys that you may or may not end up using later.
Offline vorn
« Reply #52 on: Tue, 18 June 2013, 15:19:01 »
Sounds promising :) Yeah, I was going to add at the end of my post that this isn't a complaint, but just commenting on the overly comprehensive set of keys that are included. But yes, sorting individual key set requests wouldn't be any fun and I'm sure that lends itself towards errors in packaging.
Following this GB with great interest!
Offline domoaligato
