Author Topic: What's the difference between tkl and 60%  (Read 4850 times)
Offline 222lu222
« on: Wed, 12 June 2013, 23:11:45 »
Sorry guys, I'm fairly new to keyboards well If had a laptop all my life so they are always integrated but what's the difference between a tkl a 60% and a normal? Thanks for the help
Re: What's the difference between tkl and 60%
« Reply #1 on: Wed, 12 June 2013, 23:14:00 »
TKL doesn't have the num-pad
60% doesn't have the function row (F-keys), or arrows, print screen etc. It's just the keys you use to type (alphanumerics + modifiers such as enter, ctrl etc)
Example of 60% : http://i.imgur.com/70ZuA.jpg
Example of TKL : http://cdn.overclock.net/3/3e/3ef84c90_image_171.jpeg
Offline 222lu222
« Reply #2 on: Wed, 12 June 2013, 23:16:07 »
Hey man thanks a lot for the quick response too!  ;D
« Reply #3 on: Wed, 12 June 2013, 23:16:31 »
No problem. Any time  ;D
Offline davkol
  •  Post Editing Timeout
« Reply #4 on: Wed, 12 June 2013, 23:24:17 »
tl;dr about 26 keys
Offline Jack Karneval
  • I'm gunna pop some keys, only got $20 in my pocket
« Reply #5 on: Fri, 14 June 2013, 10:53:51 »
Ah, glad someone had a thread up just to clear up this difference for me thanks.
To ask another question, what would this be considered
Is this still considered TKL? Or is it what you call a 75% keyboard?
: CM Storm Trigger (MX Green) : KBT Pure Pro (MX Blue) :
« Reply #6 on: Fri, 14 June 2013, 10:56:12 »
Jack, we call that a 75% board.
« Reply #7 on: Fri, 14 June 2013, 11:18:08 »
Ah, thanks for clarifying that!
