Author Topic: Colemak  (Read 17230 times)
Offline Linkbane
Re: Colemak
« Reply #50 on: Sat, 03 August 2013, 04:18:07 »
A bit different from what you've experienced, I also started with QWERTY and went about 80-90, but it was inconsistent, jumping from seventies to around a hundred. Instead of Colemak, however, I learned Dvorak, which apparently is supposed to take longer to transition from QWERTY than Colemak given that there was no effort to correlate them at all, and nearly all of the symbols are in different places.
It took me about a month, practicing from 45-75 minutes pretty much daily, to become equally proficient. By five months, I was pushing upper-110 and after a broken-laptop break of about two months, at eight months (six really) I'm at mid-120's top and mid-110 normally. I mostly went cold turkey straight conversion, made easier by the fact that I'm not of age to hold a job, and I would go back to QWERTY for intensive tasks but after a three weeks or so I couldn't really use either, it took me until I was proficient at Dvorak to have a usable format.
If you learn these sorts of things quickly and you practice regularly (even more importantly than for a long time) you should be able to get back to your old speed in two months or less.
Best of luck, and don't give up!
« Last Edit: Sat, 03 August 2013, 04:30:23 by Linkbane »
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline nesiax
    • key64 libre keyboard
Re: Colemak
« Reply #51 on: Sun, 04 August 2013, 07:21:11 »
Thanks for post/link. Took brief look, am bookmarking to review later.
I was searching for a language like this to learn for years, I am very excited now that I have found it !! I didn't know such thing exist, I though Esperanto was the only alternative when I realize I was searching at the wrong place; English is my second language because of work and communication with the outside world but as with Spanish (my tongue language) have a lot of exceptions and ambiguities which make it difficult to learn and take years to master which I didn't yet.
I printed the 'What is lojban' level0 manual and hope to read it next week.  I will tell you how things evolve.
now: key64.org with cherry blue keys and dsa keys |  before: noppoo choc mini with cherry brown keys
Check out the key64.org project , A Libre * Design, Minimalist, Ergonomic, Splittable, Symmetric, Compact 64 Keys, Eco-Friendly, Durable, Native Colemak Keyboard, Embedded Mouse and Firmware Programmable USB Keyboard.  * Free as in Freedom.
The key64 need a case, if you want to design it please contact us
