Author Topic: ErgoDox round 3 GB is ON at Massdrop!  (Read 25202 times)
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
Re: ErgoDox round 3 GB is ON at Massdrop!
« Reply #100 on: Tue, 16 July 2013, 12:09:01 »
The rest was made by another geekhack member as an experiment (not something for sale) and then i stained it and added varnish. The wood i think is maple or birch i forgot.
Offline mcbonz
« Reply #101 on: Tue, 16 July 2013, 13:39:18 »
Thank you. I think I'd like to do something similar one day. Since I think the classic style case looks way better.
I'm so sorry to hear about the bad quality of the aluminium case. I also don't like the acrylic look so much but in this case it sounds like the better alternative.
I hope to be able to join in round 4 on ErgoDox classics with some MX Blues as my first mechanical keyboard!  :))
Offline blissdev
    • twitter
« Reply #102 on: Fri, 30 August 2013, 22:23:11 »
I read through this and still don't see the answer, should I get classic or full hand? And which one can tent?
Leopold FC660C - Maybe Ergodox?
Offline daerid
    • Rossipedia
« Reply #103 on: Fri, 30 August 2013, 23:08:21 »
Both can tent, although the classic case is probably going to be easier to do so due to it's smaller size. And it really depends on whether you want built in palm rests.
Offline blissdev
    • twitter
« Reply #104 on: Fri, 30 August 2013, 23:11:59 »
I suppose you could always add hand rests to the classic?
Thanks for the response.
« Last Edit: Fri, 30 August 2013, 23:17:51 by blissdev »
Offline daerid
    • Rossipedia
« Reply #105 on: Sat, 31 August 2013, 01:25:25 »
Yeah, you could, but they'd have to be custom ala Glod's or kurplop's
Offline kurplop
  • THE HERO WE DON'T DESERVE
« Reply #106 on: Sat, 31 August 2013, 06:02:26 »
If anybody is interested, I could make a limited number of "Glod style" tented palm rests (Ergodock's) for a $25 donation to geekhack. They would be unfinished and would require some finish sanding. Because of shipping , CONUS only.
PM me if interested.
Offline Glod
    • YouTube Channel
« Reply #107 on: Sun, 01 September 2013, 14:12:35 »
^ worth it! and if you don't like tent the design you can remove the tent bars
