Author Topic: Cooler Master 25% off Father's Day Promo  (Read 5096 times)
Offline missalaire
  • Great Finder of Great Finds
« on: Fri, 14 June 2013, 20:38:27 »
We've got an awesome Father's Day promo code for the CM Store that gives 25% off on all gaming items. Treat your dad (or yourself) to a new Stealth mechanical keyboard, Inferno gaming mouse, Sirus S headset, or Control-RX surface with promo code "thanksdad13" (offer for US residents only).
http://www.cmstore-usa.com/
Offline alaricljs
  • I be WOT'ing all day...
Re: Cooler Master 25% off Father's Day Promo
« Reply #1 on: Fri, 14 June 2013, 20:45:59 »
Another opportunity for a nice price on browns... and still they're out of stock :(
Filco w/ Imsto thick PBT
Offline dante
« Reply #2 on: Fri, 14 June 2013, 21:03:53 »
No Greens either
Offline phx
« Reply #3 on: Fri, 14 June 2013, 21:09:46 »
only blues and reds
Offline linziyi
  • The one with many questions
« Reply #4 on: Fri, 14 June 2013, 21:14:15 »
No Greens either
Ahhh.... too bad
Ducky DK9008G2 Pro
"Much to learn you still have" --Yoda
« Reply #5 on: Fri, 14 June 2013, 21:18:24 »
zzzzzzz
Offline missalaire
« Reply #6 on: Fri, 14 June 2013, 21:19:27 »
Offline Techno Trousers
  • ʘ_ಠ
« Reply #7 on: Fri, 14 June 2013, 21:39:29 »
Nice promo.  Wish the MX greens were available.  I will check out the other stuff though. I could use a new mouse.
  • ʘ_ಠ
« Reply #8 on: Fri, 14 June 2013, 21:54:49 »
Mouse and replacement black QFR case top ordered with discount! Nice.
Offline metafour
« Reply #9 on: Fri, 14 June 2013, 22:14:07 »
Shipping kind of kills it for me.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #10 on: Fri, 14 June 2013, 22:15:02 »
Too bad the tk isn't on that list of gaming equipment
Offline missalaire
« Reply #11 on: Fri, 14 June 2013, 22:32:25 »
Pretty sure the code works for anything in the CM Store.
Offline phx
« Reply #12 on: Fri, 14 June 2013, 22:59:15 »
just tried to apply it on a QFR case
nope :(
Offline missalaire
« Reply #13 on: Fri, 14 June 2013, 23:01:28 »
nope :(
Someone earlier said they used the code on a mouse + replacement QFR top o.o
« Reply #14 on: Fri, 14 June 2013, 23:06:48 »
Is there a minimum order amount?
Offline phx
« Reply #15 on: Fri, 14 June 2013, 23:07:27 »
nope :(
it only takes 25% off the mouse.
the cover is only 10 dollars tho....
tempted.
Offline missalaire
« Reply #16 on: Fri, 14 June 2013, 23:09:20 »
nope :(
tempted.
Ah, well all "gaming" items then. So it should work for all gaming peripherals, just not stuff like QFR replacement top.
Offline alxx0rz
« Reply #17 on: Sat, 15 June 2013, 00:26:27 »
Hmmm..  "The coupon code you entered couldn't be applied to any items in your order." I tried to use it on a Stealth with reds.
Guess I'll just wait and hope the amazon batch ships out soon :/
  • ʘ_ಠ
« Reply #18 on: Sat, 15 June 2013, 00:50:12 »
Shoot,  sorry everyone. I assumed my discount applied to the mouse and case top, but I just added it up and it was only the mouse. I thought it was both since missalaire said anything in gaming, and those case tops are categorized under gaming.  That kind of sucks. Anyway, the discount basically paid my tax and shipping, so I'm not unhappy.
Caveat emptor and YMMV,  as usual.
Offline raspiguy
« Reply #19 on: Sat, 15 June 2013, 12:06:07 »
This is pretty funny -- I'm trying to use this as an excuse to place an order much bigger than I can afford/justify right now, and three times now I've pulled up at the finish line because it isn't working on certain parts of my cart.  Doesn't work on case top replacements, doesn't work on either of the (two) Stealth models currently in stock, doesn't work on the TK w/ Blues.  Seems to basically work on regular QFRs, and apparently some mice.
@ missalaire -- May I ask where you got this code from?  Seems there's either some technical errors in the implementation or we're missing a 'select items' list that this was intended for.  [Can't imagine they would create a promo code and then try to make customers play guess-&-check with it. (?)]  If you got it directly from Rajiv or Carter, then maybe one of them might be willing to facilitate some kind of 'fix', or provide clarification?
Offline missalaire
« Reply #20 on: Sat, 15 June 2013, 14:09:49 »
I got it from the Cooler Master America Facebook page.
