Author Topic: Spacebar for Leopold FC660C?  (Read 4569 times)
Offline Kaysa
« on: Sun, 16 June 2013, 09:01:36 »
as title, I would like to ask those who knew, about the spacebar key for Leopold FC660C, is it made of PBT?
and is it compatible with Realforce 87U?
And if the answer of the above is both positive,
is there any place on earth they sell it as a single key?
Currently Using:
HHKB Pro2 Black with Pink blank keycaps
Topre Realforce 10th Anniversary 2nd Batch "Silent" Varied Weight force.
Offline Sniping
Re: Spacebar for Leopold FC660C?
« Reply #1 on: Sun, 16 June 2013, 09:58:31 »
No, it's ABS, and I think the FC660C spacebar is shorter than an RF spacebar.
I don't think they sell it separately either, but I think Leopold will come out with sets of aftermarket keycaps soon, I'm just hoping I can get some of those red keys you see on the RF boards, those look sweet.
Offline leochen
« Reply #2 on: Tue, 30 July 2013, 23:58:02 »
Just got my FC660C, on the case it says All PBT. Am I missing something?
Offline Sniping
« Reply #3 on: Wed, 31 July 2013, 00:11:26 »
Spacebar has been tested to be ABS with acetone I believe.
Offline AuRinBei
« Reply #4 on: Wed, 31 July 2013, 01:26:40 »
They really need to come out with a dye-sub set for it.
87u || Poker 2
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #5 on: Wed, 31 July 2013, 08:35:12 »
Let's put it this way... If RF isn't doing PBT Spacebars, neither is Leo.
TOO BAD FOR YOU
              Phantom 62g MX Whites
