Author Topic: Leopold FC660 Traveling cases/bags  (Read 8226 times)
Offline Permeability
« on: Thu, 20 June 2013, 20:50:36 »
Has anyone found a decent padded bag for this keyboard yet? I want to get one so I can start bringing mine to work  :)
Keyboards:
'The Cheat' - lubed 62g Clears
Ducky Shine 3 TKL lubed 45g Reds (Work)
Offline Rafen
Re: Leopold FC660 Traveling cases/bags
« Reply #1 on: Thu, 20 June 2013, 21:05:52 »
You could order one of the ones from elitekeyboards.com for the HHKB if it will fit.
Offline Sniping
« Reply #2 on: Thu, 20 June 2013, 21:16:20 »
Those are $50  :eek:
Offline aggiejy
« Reply #3 on: Thu, 20 June 2013, 21:31:25 »
One alternative option would be to get a laptop bag with a big pocket. I use a Timbuk2 Messenger. Laptop and tablets go in back, but a huge pocket in front that fits my 660c.  I take it everywhere.
Offline Rafen
« Reply #4 on: Thu, 20 June 2013, 21:51:51 »
Those are $50  :eek:
I never said they were cheap, just said it was an option. For a cheap alternative, I would look at a laptop bag that is make for a mac 13" and that should be enough room to carry it.
Offline aggiejy
« Reply #5 on: Thu, 20 June 2013, 23:19:41 »
If you'd consider a new laptop bag, I can't recommend this one enough: http://www.amazon.com/Timbuk2-Commute-TSA-Friendly-Messenger-Bag/dp/B0080B834Q  Comes in a variety of sizes and colors.  It's not cheap, but it's insanely high quality, and such an awesome layout of pockets.  The front area is so big and it kind of expands to fit more stuff.  I'm amazed at what I've been able to fit in there.  Yet, it collapses if you don't have much.  If you fly much, the TSA part is the best part... don't have to take your laptop out, you just unzip the back and lean it over on the belt.  So great. :)
Offline daerid
    • Rossipedia
« Reply #6 on: Thu, 20 June 2013, 23:27:08 »
I got two of those bags from work, they are absolutely awesome. And my fc660c fits perfectly in it along with my laptop.
Offline insilica
  • Keyboard Geeza
« Reply #7 on: Fri, 21 June 2013, 07:19:02 »
My FC660 Travels in bubble wrap  :eek:
I would rather put the 50$ towards an ergo dox tbh.
FreeBSD :: Gentoo :: Arch :: [Project Roswell] :: U2410 Eyefinity :: WC P280 :: 3930K [C2] (4.5GHz)
ASUS Maximus IV :: 64GB Vengeance :: MSI 7970 xFire ::  Seasonic 1KW :: M4 256GB
REALFORCE 87U Silent (Variable) | Filco Majestouch 2 Ninja TKL (Brown) | FC660C
Offline Sniping
« Reply #8 on: Fri, 21 June 2013, 08:08:18 »
omg this
« Reply #9 on: Fri, 21 June 2013, 08:20:21 »
I had my sister sew me a carrying case. Think it cost her less than $10. Backpacks and the original box work great too.
Offline daerid
    • Rossipedia
« Reply #10 on: Fri, 21 June 2013, 09:04:10 »
omg this
In a choice between the two, I would as well
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #11 on: Fri, 21 June 2013, 12:50:25 »
Another thread turn circle jerk for ergo doxes.
Keyboard bags here: http://www.sfbags.com/products/keyboard-cases/keyboard-cases.php
« Last Edit: Fri, 21 June 2013, 12:54:00 by kenmai9 »
Offline davkol
  •  Post Editing Timeout
« Reply #12 on: Sun, 23 June 2013, 10:39:22 »
This. (Both bubble wrap and ED.)
Offline alosec
« Reply #13 on: Mon, 24 June 2013, 13:36:55 »
A bit off topic, does anyone know of any wrist-rests that fit the 660c? I'm going to be doing a LOT of typing once classes start up again in the fall and I want my hands to be comfortable.
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #14 on: Mon, 24 June 2013, 13:50:00 »
Grifiti on amazon sells nice ones. On mobile so I can't get the link. Of check out The_Beast's wood works. He has some for sale and custom order as well.
Offline daerid
    • Rossipedia
