Author Topic: Ducky Dye-Sub PBT Boards are in 06/19/13  (Read 1562 times)
Offline ARod
« on: Sat, 22 June 2013, 08:29:21 »
I posted this on OCN and TTL, didn't see a posting for it here.
The DK9008G2 Dye Sublimated PBT boards are here.  Arrived on the 19th and available for purchase on both TigerImports.Net and MechanicalKeyboards.com.  Just ordered the one in the pic below, can't wait.  ;D
Comment from the MechanicalKeyboard.com staff:
We are quite sure that this will be the only run of PBT Dye-Subs from Ducky. They are super thick and high quality compared to the other PBT Dye-Subs we've seen. Unfortunately, Ducky had a hell of a time making them (lots of production time / costs) and will likely not make them again. You've been warned.
Scroll down for the Whites, Grays & Blues:  http://www.mechanicalkeyboards.com/search.php?keyword=&switch_id=ALL&size=ALL&man=1&key_plastic=PBT&interface=ALL&cord_length=ALL&usb_kro=ALL&ps2_kro=ALL&x=33&y=16&in_stock=on
26106-0
Re: Ducky Dye-Sub PBT Boards are in 06/19/13
« Reply #1 on: Sat, 22 June 2013, 08:34:19 »
you mean like this one from mechanicalkeyboards.com in their sub-forum?  ;D
 http://geekhack.org/index.php?topic=44939.0
« Last Edit: Sat, 22 June 2013, 08:49:31 by ray4jc »
Offline ARod
« Reply #2 on: Sat, 22 June 2013, 08:47:18 »
Yup, just like that.
Would a mod please delete?
Offline ImperfectLink
« Reply #3 on: Sat, 22 June 2013, 14:08:26 »
I wish these were available in TKL and/or lefty (which should really be righty).
