Author Topic: Is there a difference between a Filco keyboard cable and a Filco Tenkeypad Cable  (Read 1244 times)
Offline thrashwolf
  • Freelance Illustrator / Designer
    • My Work
Long story short. through a series of very ****ty(pun intended) events my cat decided to eat, and then crap out the end of my tenkeypad cable i had on my desk.
i tried a normal filco KB cable and it did not work with the TKP ? is there a difference between them ?
thank you for the help
L
Novatouch TKL /w MT3 /DEV/TTY keycaps
Filco & Ducky TKL with browns
Yes there is a difference oh god I fried my tenkey using a regular cable. I forgot what exactly was the difference, but the wires are switched around.
Offline thrashwolf
    • My Work
i plugged it in for like two seconds, light just switched on and off and i tries using it. Didnt work so i unplugged it. Dont think i fried it thankfully. sorry for your poor tkp! D:
