Author Topic: Brownfox, alu + acrylic custom keyboard  (Read 36573 times)
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
Re: Brownfox, alu + acrylic custom keyboard
« Reply #50 on: Mon, 08 July 2013, 06:52:36 »
This should be it, but I did it very very quickly, you should triple check it!
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #51 on: Mon, 08 July 2013, 06:55:48 »
Champion! Where do you pull all the spacing measurements from? Or are you just copy and pasting from other template files?
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #52 on: Mon, 08 July 2013, 07:27:55 »
I use 19mm distance between key holes (not 19.05) and the formula I use is:
Distance between slots:
Code: [Select]
( (19 × u1 − 14) + (19 × u2 − 14) ) ÷ 2
Where u1 is the size in units for the first key and u2 of the second.
Eg: if you want to know the distance between a 1.5 and a 1.25 key you do
Code: [Select]
( (19 × 1.5 − 14) + (19 × 1.25 − 14) ) ÷ 2 = 12.125mm
Distance is from right side of the first slot to left side of the second.
« Last Edit: Sun, 14 July 2013, 10:40:09 by Matt3o »
Offline domoaligato
« Reply #53 on: Mon, 08 July 2013, 09:33:53 »
they are omron yellow/orange switches. Loud and clicky.
the caps are from the same board (some off brand fujitsu IIRC).
I got the board from a garbage sale and it was in bad shape.
I was only going to cover the topside of the plate with carbon to cover a few rust spots in the plate.
also this was to cover my cutting of the plate with a dremel tool. :)
I did this with minimal budget. no custom plate. lego case. wire I found around my house.
The only thing I bought was the teensy 2.0 controller (16$) and the board ($15).
I built this board to play with hasu's firmware source and to relearn soldering using the lowpoly method.
I typed this whole thing on it using a modified version of hasu''s gh60 firmware with poker layout.
Offline yasuo
  • spanengan puyeng newbie
« Reply #54 on: Wed, 04 September 2013, 00:16:32 »
For WhiteFox
Where to buy keycap? it rarely :(
« Last Edit: Wed, 04 September 2013, 00:18:34 by yasuo »
Logitech MK220 Colemak DH
Offline Hellmark
« Reply #55 on: Wed, 04 September 2013, 00:43:06 »
I do have to say, that this is one of the first 60% I have seen, that would make me consider using something less than a TKL. (long time full keyboard user, and only have begrudgingly used TKLs in the past)
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #56 on: Wed, 04 September 2013, 02:53:22 »
For WhiteFox
they come from a focus fk2001
thanks! glad you liked it! a new one is coming soon :)
Offline Hellmark
« Reply #57 on: Wed, 04 September 2013, 17:25:09 »
To be honest, if I could, I'd love a steelbeauty case, and the keys you used on Steelbeauty and Brownfox. The layout on Brownfox is more to my liking, but everything is just awesome in my book.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #58 on: Thu, 05 September 2013, 07:17:32 »
I can give you the DXF files and you could laser cut it in US
Offline Hellmark
« Reply #59 on: Thu, 05 September 2013, 09:42:16 »
That would be very much appreciated.
Offline vorn
« Reply #60 on: Fri, 06 September 2013, 07:31:27 »
Could this be the perfect base for this build? http://geekhack.org/index.php?topic=47126.30
So excited to try this!!
Offline yasuo
« Reply #61 on: Sat, 07 September 2013, 06:54:18 »
Sir matte3o can your design my plate? ;D
if you not  bussy
« Last Edit: Sat, 07 September 2013, 06:57:00 by yasuo »
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #62 on: Sat, 07 September 2013, 08:11:38 »
if you not  bussy
what's your idea? what kind of kb would you like?
Offline yasuo
« Reply #63 on: Sat, 07 September 2013, 10:41:36 »
Done :eek: finally can upoload image :-X
My idea, while this
http://imgur.com/ynhSQLU
Offline yasuo
« Reply #64 on: Sat, 14 September 2013, 06:42:14 »
sorry if distrub
matte3o how to my plate? :)
« Last Edit: Sat, 14 September 2013, 07:24:15 by yasuo »
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #65 on: Sat, 14 September 2013, 09:38:03 »
sorry very busy period, but I'll work on that as soon as I get some spare time
Offline yasuo
« Reply #66 on: Sat, 14 September 2013, 17:01:23 »
Thanks ;)
Offline yasuo
« Reply #67 on: Mon, 30 September 2013, 03:34:16 »
Actually/honestly i ever make plate own ;D but not sure and looks bad :-X
This
http://i.imgur.com/cxOqUvo.png?1
in here, i ask
1.what dimesion holes square(white)
2.how much spacing (Red)
3.how to size screw regulary?
4.any idea place for teensy particular
Thanks very much
Offline sircheddar
« Reply #68 on: Sun, 13 December 2015, 01:10:45 »
Hi Matteo,
Just joined the massdrop for an aria. I am a 65 percent person, as I demand arrow keys w/out function rows! you might recognize my name from the 100000 posts on the whitefox thread haha!
I was wondering if you offered the files for the brownfox? I am interested in making more 65% boards, have a ton of gat browns and orange alps that I want to use, but using websites to create the cnc files for the aluminum is intimidating for me. I have CAD experience, and some CNC experience, but don't currently have access to the software or the machines I normally use. If I could get the files, i think i would probably be comfortable ordering milled alu plates from an online manufacturer!
" I hope that when the world comes to an end, I can breathe a sigh of relief, because there will be so much to look forward to. "
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #69 on: Sun, 13 December 2015, 02:49:03 »
I'm a bit in a frenzy now, but I'll post everything I have in the coming weeks
Offline sircheddar
« Reply #70 on: Sun, 13 December 2015, 08:33:48 »
Hahaha, thanks alot Matt3o,
I am not sure why I am even bothering you right now with all of the work you have going on w/ the massive whitefox drop haha. Congratz on the additional 1000 units by the way! I am very happy for you guys!
