Author Topic: HHKB Pro 2 is here!  (Read 18469 times)
Offline Bluemercury
HHKB Pro 2 is here!
« Reply #50 on: Fri, 12 September 2008, 04:07:09 »
Anyone had problems like this?
Collection:
Das Keyboard II
Model M5-2
Model M5-1(considering selling this one)
Cherry G80-3000LCMPO with black switches
Cherry G80-5000HAMPO (Brown switches)
McAlly96
HHKP2 BNx2
Offline jemkeys
HHKB Pro 2 is here!
« Reply #51 on: Fri, 12 September 2008, 05:27:42 »
My flash drive won't work through the keyboard USB ports either.  Only the ones with slower transfer speeds.
Offline vils
HHKB Pro 2 is here!
« Reply #52 on: Fri, 12 September 2008, 05:46:26 »
My flash drive work's flawlessly through the keyboard...
/Vils
It\'s the glass pipe fallacy. You can only believe that if you\'re on crack.
Offline Bluemercury
HHKB Pro 2 is here!
« Reply #53 on: Fri, 12 September 2008, 06:10:12 »
Quote from: jemkeys;8686
Yes i tried a sandisk card pen the fastest one, and it gives the power not enough for the device. Strangely both external HDD i tried didnt gave the message, but didnt work either.
Collection:
Das Keyboard II
Model M5-2
McAlly96
HHKP2 BNx2
Offline Bluemercury
HHKB Pro 2 is here!
« Reply #54 on: Fri, 12 September 2008, 07:12:25 »
Quote from: vils;8687
/Vils
Its probably a slower one......
Collection:
Das Keyboard II
Model M5-2
McAlly96
HHKP2 BNx2
Offline vils
HHKB Pro 2 is here!
« Reply #55 on: Fri, 12 September 2008, 08:00:17 »
Quote from: Bluemercury;8690
Yes it is.
/Vils
Offline lowpoly
HHKB Pro 2 is here!
« Reply #56 on: Fri, 12 September 2008, 11:43:22 »
The keyboard has a passive hub. So the original usb is already running a hub and a keyboard. If a device needs full usb power it won't work.
Offline megarat
  • (Not My Real Name)
    • http://www.megarat.com
HHKB Pro 2 is here!
« Reply #57 on: Fri, 12 September 2008, 23:26:53 »
If you have an HHKB-P2 (or any other keyboard that doesn't use a hardwired cable), you can buy a two-channel cable.  This is a cable that plugs into two USB ports on the computer, and provides one USB port's worth of power to the hub.
Home/Work:  Custom Filco FKBN87Z/EB and SGI 041-0136-001 chimera (original white ALPS, not simplified, rubber-dampened)
Gaming:  Wolfking Warrior with custom-colored layout, HHKB Lite 2 (Rubber dome)
Offline Bluemercury
HHKB Pro 2 is here!
« Reply #58 on: Sun, 14 September 2008, 17:20:28 »
Quote from: megarat;8707
Well, i have a HHK professional 2, tried my external HDD with the extra usb cable that plugs in the hard drive DC-in with both usb cable parts plugged in the keyboard but that didnt work either. It worked with one plugged on the keyboard(the main one that's used to tranfers) and the power one on the laptod.......but both on the keyboard wont work. its really a matter of power....
Collection:
Das Keyboard II
Model M5-2
McAlly96
HHKP2 BNx2
Offline victheslik
HHKB Pro 2 is here!
« Reply #59 on: Thu, 18 September 2008, 00:09:54 »
« Last Edit: Sun, 26 November 2023, 22:23:56 by victheslik »
"The only antidote to mental suffering is physical pain. " Karl Marx
A wiseman once said, "If Bible proves the existence of God, then comic books prove the existence of Superheros."
Offline xsphat
  • Enlightened
    • Dan Newman, Writer
HHKB Pro 2 is here!
« Reply #60 on: Thu, 18 September 2008, 00:14:30 »
Congrats! Good time to be a keyboard junky, huh?
Offline victheslik
HHKB Pro 2 is here!
« Reply #61 on: Thu, 18 September 2008, 00:44:32 »
« Last Edit: Sun, 26 November 2023, 22:23:50 by victheslik »
Offline Bluemercury
HHKB Pro 2 is here!
« Reply #62 on: Thu, 18 September 2008, 04:00:40 »
Quote from: xsphat;8867
How's that topre 86k of yours?you're enjoying it? :P
Collection:
Das Keyboard II
Model M5-2
McAlly96
HHKP2 BNx2
Offline xsphat
  • Enlightened
HHKB Pro 2 is here!
« Reply #63 on: Thu, 18 September 2008, 04:06:08 »
Quote from: Bluemercury;8872
It's an 86U (86UK is black), and it's great. It's heavy and small, the build quality is on par with the Filco and Model M 1391401, and it does feel better than the HHKB Pro 2. So yeah, I'm pretty happy with it.
Check out my unboxing post in reviews.
Offline JulienC
  • Esc Artist
HHKB Pro 2 is here!
« Reply #64 on: Mon, 22 September 2008, 11:21:58 »
I did it, my HHKBP2 is in the mail ! The grey one with blank keys.
I can't wait until it arrives, because right now I'm suffering the symptoms of the Online Package Tracking Syndrome.
« Last Edit: Wed, 09 October 2013, 11:51:09 by JulienC »
HHKB
Offline kyamei
HHKB Pro 2 is here!
« Reply #65 on: Fri, 28 November 2008, 17:23:41 »
So I just got my HHKB in and I'm trying to set the Fn key to the left side, but I must be doing something wrong.  I got the Delete --> Backspace to work fine by turning on switch 3, but when I turn on switch 4, left diamond + ;'[/ does not equal arrow keys.  Am I mistaken in that left diamond + ;'[/ with switch 4 on is supposed to be arrow keys or is this keyboard simply defective. (blank keyboard....left diamond is the key directly to the left of the spacebar right?)
Topre:  Realforce 101, Realforce 87U, HHKB Pro 2
Cherry Brown:  Compaq MX11800
Cherry Blue:  Filco FKBN87MC/EB
Cherry Black:  K-202 numerical keypad
Alps Black:  AT101W, ABS M1
Alps White:  Focus FK-2001
Buckling Springs:  Model M 1391401, Lexmark Model M 82G2383, Model M2
Buckling Sleeves:  Unicomp Model M4
Futaba:  Sejin EAT-1010
Offline iMav
  • geekhack creator/founder
HHKB Pro 2 is here!
« Reply #66 on: Fri, 28 November 2008, 17:47:53 »
I didn't think it was possible to make another key act as the function key.  (which is located to the right of the right shift key)
Offline kyamei
HHKB Pro 2 is here!
« Reply #67 on: Fri, 28 November 2008, 17:52:45 »
Oh, I just got the idea it was possible by looking at the sticker on the back of the keyboard that said "SW4:  ON:  Left <> = Fn"  Did I just misunderstand that?
Offline iMav
HHKB Pro 2 is here!
« Reply #68 on: Fri, 28 November 2008, 17:56:37 »
Quote from: kyamei;12778
What "mode" do you have it in?  Could be that it has to be in HHKB mode.
Offline kyamei
HHKB Pro 2 is here!
« Reply #69 on: Fri, 28 November 2008, 18:01:20 »
I have switch 1 and 2 off, which should mean HHKB mode.
Offline iMav
HHKB Pro 2 is here!
« Reply #70 on: Fri, 28 November 2008, 18:47:00 »
Quote from: kyamei;12781
I'd try the combination with every mode setting...including both 1 and 2 on.
Offline lowpoly
HHKB Pro 2 is here!
« Reply #71 on: Sat, 29 November 2008, 04:57:28 »
We've seen it more than once that the dip switches didn't work immediately.
Offline bigpook
HHKB Pro 2 is here!
« Reply #72 on: Sat, 29 November 2008, 05:23:40 »
IIRC, I am using linux and I had to log out and log back in for the dip switch changes to be effective.
Offline kyamei
HHKB Pro 2 is here!
« Reply #73 on: Sat, 29 November 2008, 13:40:35 »
Thanks for the help, works now.  Started working after I plugged it into another computer.  Strange that it didn't work when I tried re-plugging it into this computer earlier.
Need to get used to having the backspace key 1 row lower than normal, but I'm loving this board so far.
Offline xsphat
  • Enlightened
HHKB Pro 2 is here!
« Reply #74 on: Sat, 29 November 2008, 14:26:15 »
It takes a restart for my Topre in Mac OSX.
