Author Topic: POKER II pbt keycap set  (Read 3246 times)
Offline cdmccart
« on: Tue, 02 July 2013, 15:51:10 »
Hello,
I looked through the forums and found one slightly helpful post that related to finding replacement keycaps for the keyboard.
I just received the POKER II..it's awesome but i'm looking to customize it with something that's hopefully not as tacky as "enjoy your feeling" on the space bar.  What exactly am I looking for with key caps in regards to dimensions?  someone mentioned on another post that I would need 1.25x for certain keys and the standard space bar sign... I'm new to this, and I would like some help understanding where to order them from so that i'm not stuck wasting my time or the shippers.
Thanks in advance!
Re: POKER II pbt keycap set
« Reply #1 on: Tue, 02 July 2013, 15:52:42 »
Bottom row is standard ANSI 1.25x. So the bottom row sizing goes
1.25x - 1.25x - 1.25x - 6.25x - 1.25x - 1.25x - 1.25x - 1.25x
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #2 on: Tue, 02 July 2013, 16:05:06 »
Some additional information:
Most group buys are standard spacing so you will be fine ordering from most group buys. Current ones include the toxic set. Upcoming ones I know of are the smallfry set and bunnylake's Miami set. You can see the current ones in group buys forum. The upcoming ones will show up eventually.
Offline cdmccart
« Reply #3 on: Wed, 03 July 2013, 08:00:22 »
Hello all!
thanks again for all the good advice.
