Author Topic: What Keyboard Are You Using Now?  (Read 4204048 times)
0 Members and 20 Guests are viewing this topic.
Offline morpheus
« on: Fri, 05 July 2013, 06:43:49 »
I don't know if this thread will be relevant, but here goes...
I decided to switch to my Model M for now...loving the crunchiness.
Re: What Keyboard Are You Using Now?
« Reply #1 on: Fri, 05 July 2013, 06:50:11 »
Work: Filco MJ2 104 with MX Blues
Home: Pure with MX Whites, Orbweaver with MX Blues
I rotate through A LOT of boards though. Yesterday while I was typing my review, I typed on my Leopold with Blues, the QFR with Greens that I still haven't disassembled, and a QuickFire TK with Blues I'm borrowing for a later review.
« Last Edit: Fri, 05 July 2013, 09:02:24 by CPTBadAss »
Offline ksm123
« Reply #2 on: Fri, 05 July 2013, 06:51:02 »
I'm using my ErgoDox since the day I built it. It feels awesome.
My BlackWidow is connected to my PC, my fiancé uses it.
My previous daily driver, blank Das Keyboard lays nearby, I convinced my wife to be, to learn to touch type, blank keyboard is ideally suited to this.
Noppoo Choc Mini waits for better days.
Offline ImperfectLink
« Reply #3 on: Fri, 05 July 2013, 06:51:22 »
Until my Ducky 9087G2 pro arrives, I'm using an Apple aluminum board   :-[
Offline Danule
« Reply #4 on: Fri, 05 July 2013, 07:05:47 »
Work: Realforce 87U 45g
Home: Filco TKL mx brown with PBT keycaps.
45g Brown Brown Blue
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #5 on: Fri, 05 July 2013, 07:23:49 »
Home: Quickfire TK (while I wait for my Filco TKL to arrive)
Work: Truly Ergo (probably swap this for a 60% soon, not sure I like it)
Offline daerid
    • Rossipedia
« Reply #6 on: Fri, 05 July 2013, 07:31:33 »
ErgoDox w/ 65g ergo clears. I tried my 660c a little while ago but got tripped up by the layout.
Offline Tym
« Reply #7 on: Fri, 05 July 2013, 07:33:12 »
Steelseries 6gv2 while I wait for my new filco to get its arse here.
« Last Edit: Fri, 05 July 2013, 09:28:11 by Tym »
Offline nsrexler
« Reply #8 on: Fri, 05 July 2013, 08:51:26 »
Ducky Shine II with Clear switches and thick PBT dyesub caps borrowed from my G2 Pro. I liked the Greens for a while, but in the end I couldn't stay away from those Clears.
Offline JPG
  • Model F is my new passion!
« Reply #9 on: Fri, 05 July 2013, 09:00:40 »
Work: FM2 TKL camo with browns
Home: Same  ;D
Offline keymaster
  • Topre Revolution Theorist
« Reply #10 on: Fri, 05 July 2013, 09:02:03 »
Home: QFR w/ 65g Clears
Work: G84-4100 or IBM Rubberdome
Offline Rafen
« Reply #11 on: Fri, 05 July 2013, 09:04:51 »
Desktop: Ducky Zero w/reds
Laptop: QFR w/reds
Offline AKIMbO
  • HHKBro
« Reply #12 on: Fri, 05 July 2013, 09:22:17 »
Work: Rosewill 104 with mx reds.
Home: Realforce 87UW with 55g topres & mkawa's beta ssk.
| KBD75 (box reds)
Offline affect656
« Reply #13 on: Fri, 05 July 2013, 09:26:13 »
Filco MJ2 TKL with reds
I like linear.
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #14 on: Fri, 05 July 2013, 09:53:56 »
Work: QFR w/ Blues (Vintage Browns to be installed when the switches clears customs)
Home: Shine II w/ Browns
Offline jkercado
  • Green XM clickclacker
« Reply #15 on: Fri, 05 July 2013, 09:55:06 »
Work: Ducky 1087XM blacks
Home: Ducky 1087XM greens
Carry-on: Cherry G84-4100
Ducky 1087XM Green | Unicomp Ultra Classic Black | IBM M4 | 1989 IBM Model M | Genius i200 | Cherry G84-4100 | Microsoft Arc Keyboard
Offline Larken
« Reply #16 on: Fri, 05 July 2013, 10:55:39 »
ergodox with 55g clears. only box I use nowadays.
| Ergodox #1 | Ergodox #2 |
« Reply #17 on: Fri, 05 July 2013, 11:00:03 »
Broken rubber dome.
« Reply #18 on: Fri, 05 July 2013, 11:01:45 »
Poor Photekq. I told you this before but I'd send you a board if Royal Mail didn't hate me.
Offline Shadovved
  • King of Stickers (and GBs)
« Reply #19 on: Fri, 05 July 2013, 11:03:58 »
iPad with touchscreen :p
When I'm on my desktop then a '93 industrial Model M :cool:
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
« Reply #20 on: Fri, 05 July 2013, 11:07:42 »
Semi-Industrial 93' SSK
Offline Shadovved
« Reply #21 on: Fri, 05 July 2013, 11:10:27 »
Whoo! Same year, bro! :))
« Reply #22 on: Fri, 05 July 2013, 11:14:41 »
'preciate it, man  :'(
Offline Jack Karneval
  • I'm gunna pop some keys, only got $20 in my pocket
« Reply #23 on: Fri, 05 July 2013, 11:21:51 »
Home: CM Storm Trigger (MX Greens)
Work: Some Dell rubber dome keyboard. It's not half bad, but obviously I much prefer my mechanical keyboards
: CM Storm Trigger (MX Green) : KBT Pure Pro (MX Blue) :
« Reply #24 on: Fri, 05 July 2013, 11:29:58 »
Work: Ducky Shine 2 with Clears and Imsto Thick PBT Caps
Other: Rosewill with Vintage Black's (primarily for showing off key caps), Poker X with Reds NIB for future switch, spring testing. Soon to have a Phantom or two.
Offline insilica
  • Keyboard Geeza
« Reply #25 on: Fri, 05 July 2013, 11:49:44 »
Work: Filco MJ2 TKL.
Home(Mac): FC660
Home(Workstation): RF 87U silent variable
FreeBSD :: Gentoo :: Arch :: [Project Roswell] :: U2410 Eyefinity :: WC P280 :: 3930K [C2] (4.5GHz)
ASUS Maximus IV :: 64GB Vengeance :: MSI 7970 xFire ::  Seasonic 1KW :: M4 256GB
REALFORCE 87U Silent (Variable) | Filco Majestouch 2 Ninja TKL (Brown) | FC660C
Offline DaveyG
« Reply #26 on: Fri, 05 July 2013, 11:56:18 »
Home: RF 87u 55g. Work: about 5 quids worth of HP's finest  :p
   RF 87u 55g            RF 87u 45g          Filco Ninja TKL       Filco Ninja TKL       Filco Majestouch II
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #27 on: Fri, 05 July 2013, 11:56:49 »
Home: FC660C
Work: RF 103u (Hopefully going to be an 87u Silent soon!)
TOO BAD FOR YOU
              Phantom 62g MX Whites
Offline tribade
« Reply #28 on: Fri, 05 July 2013, 12:04:22 »
I'm typing on a KMAC mini with 55g blacks, and I love it!
KMAC mini w/ blacks | Realforce 87uw 55g w/ Digil0g case | KMAC w/ blacks | Duck Viper w/ clears
"Te occidere possunt sed te edere non possunt nefas est."
Offline The_Beast
  • I like wood ಠ_๏
« Reply #29 on: Fri, 05 July 2013, 12:07:15 »
Switching between my poker and SSK every couple of days
Offline Badwrench
  • ummmm.....I forgot
« Reply #30 on: Fri, 05 July 2013, 12:08:50 »
Home:  I swap between my QFR w/ Blues and thick PBT, or my Pure w/ reds.
Work:  IBM KB-0225.  Pulled this one from a storage bin on site as everyone else uses the chicklet style Dell boards (which I can't stand).  I also found an old Compaq RT-101, but it needs a cleaning before I put it in rotation.
Offline vatin
« Reply #31 on: Fri, 05 July 2013, 12:11:45 »
Work : Kinesis Advantage
I also carry it back to use at home.
HHKB Professional Classic
Offline aggiejy
« Reply #32 on: Fri, 05 July 2013, 12:13:40 »
FC660C-only for a couple months now... still phantom-type on all my other keyboards about once a day, just because I'm weird like that.
Offline badcop
  • thorpe thocking master race
« Reply #33 on: Fri, 05 July 2013, 12:15:08 »
right now i have
work: Poker w/ greens and goldtouch TK pad with whites
Home: Filco TKL with variable weight blues
QFR sits on my shelf crying itself to sleep everynight because no one touches it  :(
Offline davkol
  •  Post Editing Timeout
« Reply #34 on: Fri, 05 July 2013, 12:20:35 »
Noppoo Choc Mini (MX Red, black, Cherry keycaps) at my standing setup
thinkpad keyboard everywhere else
I have to force myself to finish my ergodox and clean the endurapro that lies in the closet.
Offline komar007
    • komar's blog
« Reply #35 on: Fri, 05 July 2013, 14:14:41 »
Cherry G80-3000 HFU with ghetto-greens. My current favourite.
I'm waiting for the Noppoo Mid 87 to switch to tenkeyless, at least for some time, and have something to put the R4 keycaps on:)
Offline PointyFox
« Reply #36 on: Fri, 05 July 2013, 14:43:35 »
Filco Multicam TKL with MX Black and Round 3 keycaps.
Offline Dubsgalore
« Reply #37 on: Fri, 05 July 2013, 14:44:57 »
My Poker with Clears is my Daily Driver. I use it the most no doubt. every few days i use the Pure, but i don't like it as much for a few reasons.
Broken rubber dome.
hang in there m8  :'(
Offline dndlmx
« Reply #38 on: Fri, 05 July 2013, 14:56:12 »
Black HHKB, white printed keycaps.
« Reply #39 on: Fri, 05 July 2013, 14:59:57 »
My QFR is my usual beast.  That might change when I get my GH60 and Pure put together.  If I were doing more typing, it would be my RK9000 with Clears (speaking of that, I need to desolder it and lube it with Krytox since the silicone lube I used isn't cutting it.
Offline czarek
  • Keep the momentum going!
    • FalbaTech
« Reply #40 on: Fri, 05 July 2013, 15:03:52 »
Currently at desktop: I'm using Filco 104 Metallic Blue AI with MX blues and PBT blank caps. I can't say it's my best feeling board but it's definitely best looking one (my previous daily driver was Unicomp Spacesaver M and then Realforce 87UB for a short while). Don't get me wrong about the feel. It's definitely good enough to be a daily driver, at least for now.
As a portable keyboard: I will probably always use HHKB Pro 2. I used it as a daily driver but when I switched back to a keyboard with more keys on it I realized they're there for a reason.
At my wife's desktop: (well a MacBook Pro connected to Apple Thunderbolt display) she's currently got unbranded QFR with MX Reds and Filco keycaps (kinda ghetto Filco keyboard) and she actually likes it more than her previous all black EnduraPro (converted to SpaceSaver as I removed the pointing stick and replaced G, H and B keys because it got in my way when I typed on it).
« Reply #41 on: Fri, 05 July 2013, 22:51:29 »
Home (Windows - games): Ducky Shine 1 MX blues red LEDs
Home (Mac - everything else): HHKB 2 Pro
Work (Windows): alternating between QFR MX black and Filco yellow keycaps, and KeyCool MX red with PBT whites
It is amusing that most GHers have separate keyboards for home and work :))
Offline calavera
« Reply #42 on: Fri, 05 July 2013, 22:54:19 »
55g lubed blacks. Currently breaking them in. They get better the more I type. :D
Offline DuckNorris
« Reply #43 on: Fri, 05 July 2013, 23:00:23 »
I switch out between  a Razer BlackWidow Ultimate and a Coolermaster Storm Trigger( these were picked when I was a complete newbie in the keyboard world).
SOON, IBM Model M(in mail) and after that a Filco Ninja 2 or Ducky Shine 3 (still deciding).
Offline TimIsABat
  • MX Clears are life
    • Instagram
« Reply #44 on: Fri, 05 July 2013, 23:36:36 »
I rotate between a Poker X with reds and a Leopold FC7660M with reds when my "w" key decides to conk out on my Poker X (going to fix this once I get soulder equipment and mx clears and 62g or black springs).
I am also planning to use a Dell AT101 on my family's home computer when I get a PS/2 to USB (it is a combo computer...don't judge...I voted against it XD), and when I finish cleaning it up.
Leopold FC660M MX Reds | Poker X 62g  Ergoclear modded and plate modded (out of comission) | IBM Model M 1391401 | Dell AT101 | Compaq RT101 | HHKB Pro 2 | WASD CODE TKL MX Clears
Avid vape collector and advocate. I used to work at to renowned vape shops here in New Jersey. Message me for any vape related questions.
Main driver : WASD CODE TKL MX Clear
Offline The_Beast
  • I like wood ಠ_๏
« Reply #45 on: Fri, 05 July 2013, 23:39:02 »
This board right now!
I was using the SSK earlier today, but I switch to this since it has my favorite cap set and some sick purple mods so the least I can do is type on it for a bit
Offline JDrive
« Reply #46 on: Fri, 05 July 2013, 23:53:06 »
Choc Mini with MX Red
IBM SSK - IBM PC XT - Noppoo Choc Mini
Offline TimIsABat
    • Instagram
« Reply #47 on: Sat, 06 July 2013, 00:03:34 »
Purple is my favorite color. This is sex
« Reply #48 on: Sat, 06 July 2013, 00:14:58 »
I just switched to using my GON board today that I finished assembling yesterday. It's aight. Spacebar's a bit awkward since it's a 6.25 on a 7.
« Reply #49 on: Sat, 06 July 2013, 00:17:42 »
Lubed and stickered ergo-clear Filco TKL. Honestly I haven't even had the inkling to use any of my other 6 boards since this one was finished. Dat grail.
