Author Topic: What Keyboard Are You Using Now?  (Read 5187416 times)
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: What Keyboard Are You Using Now?
« Reply #4450 on: Thu, 02 June 2016, 16:02:15 »
My new "main driver" is a WASD v2 with MX Greens and the two rightmost modifier keys swapped out for MX Locks. I'm also practicing with a Kinesis Advantage with Gateron Blues in the keywells and Greens in the thumb clusters, with two of the small left-thumb keys again swapped for MX Locks.
The Kinesis is hard to get used to, but I think it's repairing some bad typing habits of mine
Greens.
Sounds loud and fun.
Yeah, I have to be careful to type softly on calls because the mic picks it up and it's obnoxious. The WASD has O-rings which helps, but the Kinesis doesn't and it's like an automatic rifle going off.
I've been meaning to spring swap my greens with 135g springs but the guy that was suppose to send me a sample never got around to it.
135g?! Holy guacamole! :eek:
Offline Floody
  • Formerly Flood
  • But is it?
« Reply #4451 on: Thu, 02 June 2016, 16:03:28 »
Greens.
I feel like greens are to light for me but I haven't used them in about a month so I need to switch back
Offline zombiegristle
« Reply #4452 on: Thu, 02 June 2016, 16:13:50 »
Greens.
Yeah, I'm the same; I beat my keys like an underpaid nanny.
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #4453 on: Thu, 02 June 2016, 18:04:05 »
Using my new 1800 Leeku in a weird position as I've not cut a hole in my 1800 case yet.
But now everything down from End, Page Down and Scroll lock doesn't work. Including delete. It all works at home but not at work...
Offline 27
  • The Maple Man
« Reply #4454 on: Thu, 02 June 2016, 18:23:47 »
I'm using an RS78 with 62g MX Blacks.  I'm a big fan of them, and even unlubed they're pretty smooth. I'm excited to try out lubed Gat Blacks in my next build, whatever it may be.
IG: https://www.instagram.com/27mechs/                                        Website: http://www.mech27.com/
Offline kiwi99
  • that's a gnarly dookie
« Reply #4455 on: Thu, 02 June 2016, 18:40:26 »
alps clueboard & tmk64
« Reply #4456 on: Thu, 02 June 2016, 19:43:31 »
My phone's.
« Reply #4457 on: Thu, 02 June 2016, 19:44:04 »
« Reply #4458 on: Thu, 02 June 2016, 20:05:29 »
My phone's.
then who was phone?
Why can't I post the thinking emoji?!
Offline alienman82
« Reply #4459 on: Thu, 02 June 2016, 20:17:39 »
removed.
« Last Edit: Thu, 01 March 2018, 15:05:40 by alienman82 »
« Reply #4460 on: Thu, 02 June 2016, 20:20:52 »
Offline Otesanek
« Reply #4461 on: Thu, 02 June 2016, 21:20:07 »
HHKB. But I wish I was using rm-rf's modded 170g HHKB.  :'( :eek: :thumb:
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Commercial Vendor
  • The 00verseer of Vault 77
    • Mechanical Keyboards
« Reply #4462 on: Fri, 03 June 2016, 07:46:23 »
If a person has to put their keyboard in a choke hold in order to force it to actuate, it kind of defeats the purpose.
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
« Reply #4463 on: Fri, 03 June 2016, 07:48:05 »
This needs more explanation :eek:
Offline LiquidEvilGaming
    • LiquidEvilGaming Youtube
« Reply #4464 on: Fri, 03 June 2016, 16:32:33 »
Using my KBP V60 with Cherry MX blacks more and more to get accustomed to the switch, will be adding O-Rings this weekend to cut the travel down a bit since my fingers are much better trained on Clears than linear blacks.
Current Daily Driver/s
White Leopold 750R MX Reds
Head of LiquidEvilGaming on Youtube
i7 4790k/16GB DDR3/GTX 1060 6GB SSC/256GB Samsung SSD/2TB SSHD/W10
Offline Floody
  • Formerly Flood
  • But is it?
« Reply #4465 on: Fri, 03 June 2016, 20:01:00 »
Brought the Planck with greens to the computer lab since no one is there on Fridays. Took forever for the driver's to install but it was well worth it.
Offline Otesanek
« Reply #4466 on: Sat, 04 June 2016, 00:17:37 »
I'm not sure if he wants me releasing his super secret modding method. You will have to ask him.
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #4467 on: Sat, 04 June 2016, 10:09:57 »
Right now I am using a MK Disco TKL with KBT (I believe they are manufactured by Greetech) Browns & 40a o-rings for dampeners. So far I am absolutely loving this board, it blow my previous MKB (Rosewill Apollo with MX Browns) out of the water on build quality & I think the KBT browns have a better feel than the MX browns on my Apollo. Currently waiting on a set of red Shine 3 ABS keycaps & few ABS customs I ordered from keypop.net to truly make the board my own but I think the addiction has started for me... :D I am already looking into building my own TKL board, but am in no rush since I am happy with the Disco for now.  :thumb:
Offline ANightOnCloudNine
« Reply #4468 on: Sat, 04 June 2016, 11:01:26 »
a ****ty mac keyboard
Offline 00zeRO
« Reply #4469 on: Sat, 04 June 2016, 11:37:10 »
I'm not sure if he wants me releasing his super secret modding method. You will have to arsk him.
Probably involves Cheetos and chicken fingers and a Coke drizzle.
Offline TeeBaginDragon
« Reply #4470 on: Sat, 04 June 2016, 22:57:21 »
Work: CODE 87 with MX clears
Home: CM Storm TKL with MX reds
Joined the R3 Zealios drop so I'll probably figure out a way to swap them into the CODE..
CODE Clears 87
« Reply #4471 on: Sun, 05 June 2016, 00:59:44 »
Either means each switch is weighted at 170g, or the HHKB itself has been lightened to only 170g.
Agreed that either possibility requires explanation.
« Reply #4472 on: Mon, 06 June 2016, 15:51:42 »
Actually back to my HHKB Pro 2 again,the tendinitis and carpal issues have been horrid lately and the HHKB feels more forgiving to type on.   And i love the sound of the thocky matt3o PBT spacebar.
Offline Wazazaby
« Reply #4473 on: Mon, 06 June 2016, 17:10:44 »
A B.87 with Gat greens and tuned stabs, my 2nd favorite board behind mt JD40!
Offline Brammm87
« Reply #4474 on: Tue, 07 June 2016, 04:28:19 »
Currently a Varmilo VB87M with Gateron Browns. Pleasantly surprised by it. Put o-rings on it to spare my coworkers a bit. I'm used to greens so I'm bottoming out hard :p
pls gief bbv2
Offline E3E
« Reply #4475 on: Fri, 10 June 2016, 11:23:09 »
Finally have cases for both of my Alps Eagles, aww yeah :D
Here's the other one:
That was before I changed my Lightpad to Alps. :P
And they are all hot swappable (switches, LEDs), including the Lightpad.  :thumb:
« Last Edit: Fri, 10 June 2016, 11:25:11 by E3E »
« Reply #4476 on: Fri, 10 June 2016, 17:41:54 »
I think I'm in the process of phasing out my WASD v2 for this TeamWolf one I just got. Using them both right now to decide.
« Reply #4477 on: Fri, 10 June 2016, 17:57:23 »
Right this moment KBP V60 W/ Cherry Blues with Midnight DCS Keycaps from Signature plastics.   Really love the DCS profile and Blues unlike most switches i actually prefer with thinner ABS not thicker PBT like most of my boards.
Offline UnFocused
« Reply #4478 on: Mon, 13 June 2016, 18:13:05 »
I am using a Phantom which I finished building a few days ago. Phantom PCB, blue aluminum plate, grey TEX aluminum case, a Pexon cable and DSA Dolch keycaps. The switches are Cherry MX blacks that I harvested from a Wyse terminal board with a date code from 1986.
I was disappointed after getting everything together that there was a good bit of flex with the PCB / plate inside of the case. axtran recommended a sheet of Sorbothane which has worked wonders and eliminated all of the flex.
I really, really, really like these vintage MX blacks. I like them much more than the KUL with MX clears I have had.
Here's a bad photo of the keyboard.
And here's part of the Wyse donor board.
I'm not saying this is endgame, but this build is wonderful and I don't think I'll be acquiring any more keyboards for a while unless I come across a killer deal on an IBM beam spring or whatnot. I've got this Phantom, a few Model M's (I started collecting those in the late 90s and have recently sold a few), a Model F, a 55g Realforce and an Apple M0116 with orange Alps that's been in the family since the 80s.
« Last Edit: Thu, 16 June 2016, 21:53:25 by UnFocused »
Offline kyb
  • i love the smell of nopsleds in the morning
« Reply #4479 on: Thu, 16 June 2016, 16:35:38 »
For me it's now the Ergodox. After having almost spent 800 Euros on Topre stuff. I even bought a second RF as a backup in case the government takes away my keyboard. Lol @ my wallet :)
I hate the switches in my dox  but the layout is just superior. Can someone build a 55g Topre Ergodox pls?
Ergodox :o
Offline Rob27shred
« Reply #4480 on: Thu, 16 June 2016, 17:11:32 »
Got my 2 KBP V60 minis in today & am loving them! :D I got one with Cherry white switches & one with Cherry Blue switches. So for the time being I'll be switching between the V60s for typing & still rocking my MK Disco for gaming. So far I am really leaning towards the whites since I have a heavy typing style. The blues feel great but are a little loud, not sure if it is something I will get used to or not. The KBT browns are awesome, they feel very similar too but a little better than Cherry browns IMO. YMMV with that last statement though as that is my personal preference between the two.  :thumb:
KBparadise V60 mini, Red/Blue LEDs, Cherry white switches, Limited Production 96/150
139941-0139943-1
KBparadise V60 mini, Red/Green LEDs, Cherry blue switches
139945-2
MK Disco, RGB LEDs, KBT brown switches
139947-3
Offline eddof13
« Reply #4481 on: Thu, 16 June 2016, 17:39:11 »
Happy Hacking Keyboard Professional 2 at home
CODE keyboard at work
« Reply #4482 on: Fri, 17 June 2016, 11:07:55 »
At work, this monstrosity beauty.  :cool:
140010-0
Offline emdude
« Reply #4483 on: Fri, 17 June 2016, 12:43:54 »
My sweet baby: ;D
Current drivers: IBM Model M SSK
Offline 9fiftyfive
« Reply #4484 on: Fri, 17 June 2016, 17:02:59 »
HHKB Pro 2
Offline Aricil
« Reply #4485 on: Sat, 18 June 2016, 09:11:48 »
I use a Rantopad MXX w/ Gateron blues as my daily driver. I'm currently in the process of putting soft landing pads on my Novatouch so it's lying in 3 pieces on my desk. I'll get around to finishing it when I have time, it's just tedious. I really love my gateron blues, but I also liked the novatouch, and it has benefits as far as gaming goes (like side-stepping in cs go is kinda hard on blues) but that sound on the upstroke was killing it for me. So hopefully this'll help. We'll see. I'm possibly going to be getting a higher end varmillo gateron blue board, however, as I bought this rantopad mxx to try them as I didn't know if I'd like them or not (I didn't like razer greens or cherry blues) but these ended up being my favorite switch. So now I'm looking to get a keyboard with gat blues that has a better build quality.
Professional amateur.
Offline lee+
« Reply #4486 on: Sat, 18 June 2016, 13:31:30 »
brand new Omron B5GS
Someone must have stored it for 20+ years.  Does anyone know when those were made?
Offline Floody
  • Formerly Flood
  • But is it?
« Reply #4487 on: Sat, 18 June 2016, 13:49:30 »
My sweet baby: ;D
That thing looks so patriotic.
Offline Bucake
« Reply #4488 on: Sat, 18 June 2016, 13:58:18 »
i would say something about its flippedness, but it's a red pbt one.. :cool:
Offline Karura
  • Professional Canadian
  • SKidata life.
« Reply #4489 on: Sat, 18 June 2016, 14:09:51 »
Using this beauty
Offline lee+
« Reply #4490 on: Sat, 18 June 2016, 16:40:01 »
Using this beauty
Let me guess, it fell off the desk?
« Reply #4491 on: Sat, 18 June 2016, 16:59:09 »
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #4492 on: Sat, 18 June 2016, 17:13:01 »
hhkb
« Reply #4493 on: Sat, 18 June 2016, 17:29:14 »
I just can't get away from it. I have 3 in cases but they just feel suffocating and I keep coming back to this one:
- D Trump 2026-10-24
Offline y11971alex
  • Looking for Toronto meetup
« Reply #4494 on: Sat, 18 June 2016, 18:26:22 »
What's that?  :eek:
Offline Bucake
« Reply #4495 on: Sat, 18 June 2016, 18:31:22 »
ibm model f122 without its case
(picture name = F-122 + date)
and a WMO, steelseries I-2 i think, vertical anker mouse
sweet setup
edit: haha, taken the badge off of the case and put it on the plate. pretty cool
« Last Edit: Sat, 18 June 2016, 18:34:35 by Bucake »
Offline alienman82
« Reply #4496 on: Sat, 18 June 2016, 20:34:02 »
removed.
« Last Edit: Thu, 01 March 2018, 15:03:08 by alienman82 »
« Reply #4497 on: Sat, 18 June 2016, 23:51:01 »
Model M 51G8572 29-Nov-1995.
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #4498 on: Sun, 19 June 2016, 02:19:43 »
Nice Keyboard Rowdy!
Mine is 04-Oct-1994
« Reply #4499 on: Sun, 19 June 2016, 02:29:22 »
140109-0
