Author Topic: What Keyboard Are You Using Now?  (Read 5248454 times)
0 Members and 6 Guests are viewing this topic.
Offline z3r0_k00l75
Re: What Keyboard Are You Using Now?
« Reply #6000 on: Wed, 16 May 2018, 03:22:19 »
195740-0 [ Specified attachment is not available ]  Currently using a GH60Satan with cherry reds to try out a new keyset I got in the mail. For some odd reason I do like lasered PBT.
« Last Edit: Wed, 16 May 2018, 03:25:00 by z3r0_k00l75 »
Daily Drivers: GON NerD60 (PBT / Gateron Black / UV LED), GH60 Rev.C (PBT / Gateron Black), WASD Code VP3 (Stock / Cherry Clear / White LED), NPKC KC60 (DS PBT / Gateron Green / White LED), Adesso 625UB (White English-Russian Thick PBT/ Cherry Red), Quickfire Rapid (Vortex PBT / Cherry Black), Quickfire Rapid-I (Stock+o-rings / Cherry Red / Green LED), Leopold Otaku (Black Gray mixed Dolch Thick PBT / Cherry Red).
Offline menuhin
« Reply #6001 on: Wed, 16 May 2018, 05:05:42 »
pok3r with mx-clears
gmk dolch iso german
Very cute RGB set - which GB is that from?
I want one!
Edit: got that later in the thread. I missed that around the corner GB...
« Last Edit: Wed, 16 May 2018, 05:11:20 by menuhin »
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline menuhin
« Reply #6002 on: Wed, 16 May 2018, 05:20:05 »
Current daily driver (until my Mars 8.0 arrives and gets build): A g80-3000, cut down to 70% cuz I need to save some space on my desk again. Only thing that sucks: No layers currently.
Case will be sanded and painted at some point to cover the stitches.
And perhaps also sanded, sandblasted before painting if you want to maintain that texture.
IBM M13 black
HHKB Pro 2 HasuBT
Offline Mallowpuff
« Reply #6003 on: Wed, 16 May 2018, 12:49:15 »
Currently using a Ducky YoTR(Year of The Rooster) with MX Blacks. I'll get pictures up soon enough.
Soon to be swapping back and forth with an IBM Model F AT. Two awesome boards!!
Offline thokir
« Reply #6004 on: Wed, 16 May 2018, 13:41:41 »
FYI, you can paint on acetone and use it like glue on ABS. You can also melt down some of the case scraps in acetone till a goo and use it as filler, then sand smooth.
Thank you guys, will take a look on both options and decide for one (or better both combined?!)!
Offline idlemao
« Reply #6005 on: Wed, 16 May 2018, 14:04:39 »
MK Fission with MX Browns at work
Realforce 87u 45/55g at home.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #6006 on: Wed, 16 May 2018, 14:27:10 »
Current workspace consists of Matias Laptop Pro (Matias Quiet Click) and Avid KB-654 (Cherry MX Brown).
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #6007 on: Wed, 16 May 2018, 15:06:02 »
First I've read of an Avid KB-654. That board looks like a very useful piece of kit to have around.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #6008 on: Thu, 17 May 2018, 09:34:33 »
Avid does a lot of media composition and editing stuff, notably tools which are useful for post production, etc. A lot of their older keyboards are mechanical, I think the first I have seen was a clone of the Apple Extended Keyboard II (White Alps I think it had) with keycaps designed for their software. I own the Avid Mechanical User Interface that they designed which has Cherry M8 switches (which you can see here: https://deskthority.net/wiki/Avid_Mechanical_User_Interface). I bought the KB-654 a few years ago brand new for about $50. The keycaps are kind of cheap (laser engraved ABS) but they have a nice aesthetic to them anyways.
Offline ptykozoon
« Reply #6009 on: Fri, 18 May 2018, 17:25:24 »
uniqey reppn
Offline fxsound
« Reply #6010 on: Mon, 21 May 2018, 14:20:28 »
Uniqey q100 with sprit gold spring:
CapsLock, NumLock -120
Esc, SpaceBar, Enter, Backspace - 100
Modifier  - 78
AlphaBetical, numpad and arrow - 62
Keycap:
GMK Sky Dolche
ESC, F12, Enter - Varmilo Revolution
196008-0196010-1
Offline ojrask
  • juuh elikkäs
« Reply #6011 on: Mon, 21 May 2018, 16:41:10 »
Currently running UK78 at work. At home, I picked my first mechanical keyboard again, Ducky Premier CCnG with MX Blues. It still rocks! I swapped the stock OEM PBT caps to GMK Blue on Black though.
Current:
Coming up:
IC/GB:
Offline Sup
« Reply #6012 on: Mon, 21 May 2018, 17:23:59 »
Tina-C
  • DZ60 QMK
    Cherry MX silent stems in gateron transparant top housing with default cherry bottom Lubed with Krytox.
    Genuine Cherry stabilizers clipped and bandaid modded and lubed with super lube.
I love how silent and smooth it is. I finally got some use for the Cherry mx silent switches from the group buy that had production faults with the spring weight and stem color.
current
Coming soon
Offline ojrask
  • juuh elikkäs
« Reply #6013 on: Tue, 22 May 2018, 05:18:55 »
My batch of those silents are waiting for a new keyboard. Swapped in some 100g springs.
Current:
Coming up:
IC/GB:
Offline Sup
« Reply #6014 on: Tue, 22 May 2018, 12:39:27 »
100 grams you have some muscle fingers. I swapped mine with regular mx black springs 60 grams.
current
Coming soon
Offline Pavilions
« Reply #6015 on: Tue, 22 May 2018, 13:29:21 »
Today I swapped my model M with a Poker II which has some issues with it and it's very light compared to the Model M. but I will use it for a while until I get used to it.
« Reply #6016 on: Tue, 22 May 2018, 13:33:30 »
Brought my "kustom" to work, which supplants my Realforce (or, as my co-workers liked to say, my "gamer" and "old-ass" keyboard).
First time using a non-Topre mechanical keyboard here. Haven't figured out how to turn off the RGB settings through Jigon; I clicked on the RGB Off setting but it doesn't seem to do what it claims.
I have lubed, 72g Tactile Gray switches, and, since this is the first time I'm using this at the office, I did not realize how much louder MX switches sound compared to Topre. I've been used to using Topre at work and MX at home that I never bothered comparing the difference in frequencies.
But so far no prolonged glances from passersby!  :thumb:
« Last Edit: Tue, 22 May 2018, 13:35:09 by romevi »
Offline Sup
« Reply #6017 on: Tue, 22 May 2018, 14:08:35 »
I don't get it why people think it looks old it looks modern to me. I guess everything has to be black to be considered to be modern in these days. Even my bright Blue VA68M with blue keycaps was considerd a old keyboard :l. Feel u some people don't know what they are missing out on.
current
Coming soon
« Reply #6018 on: Tue, 22 May 2018, 14:55:42 »
Oh, no; it's my Realforce that my office mates call a "gamer" or "old-ass" keyboard. After three+ years of using it here, it got only a handful of comments. So far I've been using my Jane about a week, so I'm preparing myself for at least one or two comments soon.
There's a guy who has a comment for everything; he's been out of the office for a week, but if it's one person who will mention something it's definitely him. And I'm sure the IT guys will have a comment next time they have to use my computer.
Offline Blackhawk
« Reply #6019 on: Tue, 22 May 2018, 14:59:02 »
I don't know if it has changed recently, but the last time i used Jigon the only way to turn of the rgb leds was to set their color to black
Lovely board!
Offline CustomerSupport
  • 🕸 developer
    • Discord
« Reply #6020 on: Tue, 22 May 2018, 15:58:32 »
Bought a Ducky One 2 Midnight so I was justified in joining the XDA Scrabble GB on Massdrop.
Still have stock doubleshot PBT caps on MX Blues, but should be getting DSA Starry Night in a few weeks' time.
By June I should get my Leopold FC750R with MX Clears, which I'm stoked about.
Offline monkt
« Reply #6021 on: Tue, 22 May 2018, 18:37:06 »
Which caps are you getting with the Leo? I can't imagine nicer stock keyboards than Leopold makes, so I'm sure you'll be happy with the 750. To me they really feel premium.
  • 🕸 developer
    • Discord
« Reply #6022 on: Tue, 22 May 2018, 19:12:43 »
Wonderful. That's what I've heard too. I got the white and green set with the white case. Actually got it cheaper than the listed price with 3 day shipping thanks to some points racked up from the purchase of my first board.
Offline invariance
  • ...here with all the other boson's
« Reply #6023 on: Tue, 05 June 2018, 04:02:31 »
Put the Model M back in the cupboard and next in line is a Digital LK46W-A2.
One day I'll make a ps/2 to usb converter to remap especially the nav cluster, but to also use some of the keys that output a scancode that aren't recognised by Windows.
197117-0
« Last Edit: Tue, 05 June 2018, 05:10:25 by invariance »
The only BS I
want to hear is
from a Model M:
PN:1391401
DOB: 04FEB87
      Wyse 85      Mtek K104
SMK Blue: Chicony KB-5181; HyperX Aqua: HyperX Alloy Origins *Yet-to-rebuild: A 69 key C. P. Clare Foam & Foil assy *Rubber: Digital LK46W-A2; uSoft Natural Pro RT9401, Natural Multimedia 1.0A RT9470, Natural Ergonomic 4000 KU-0460; "Avid" Sejin SLKR2233; "Diamond Touch" Mitsubishi 6511-PB
Offline nyihtway81
« Reply #6024 on: Tue, 05 June 2018, 04:07:25 »
Current one is MagicForce Crystal 108 keys with CherryMX brown switches. But I'm planning to build a 62key kb
197119-0
Offline slk
« Reply #6025 on: Thu, 07 June 2018, 00:12:21 »
Currently using a Varmilo VA87M with Cherry Silent blacks. It's been my everyday use board after I got used to the weight.
Offline greenteei89
« Reply #6026 on: Thu, 07 June 2018, 01:19:04 »
TX1800 during the work week and an HHKB Type S during the weekends.
Offline Hongook
« Reply #6027 on: Thu, 07 June 2018, 09:26:29 »
Currently still using a Das professional from over 10 years ago. Looking forward to receiving some new keyboards this year such as the CTRL/ALT from Massdrop as well as the M60-A from Rama.
Offline nativejibroney22
  • I enjoy keyboards as well as making artisans
« Reply #6028 on: Thu, 07 June 2018, 09:59:36 »
A let's split with some cream damped alps! (if you know how to remedy some iffy switches that don't register half the time I would appreciate it haha)
Offline Kilgarah
« Reply #6029 on: Thu, 07 June 2018, 10:05:09 »
An AEK64 with SKCM Brown Alps! It's fantastically tactile and quite smooth. Took a while to get the stabilizer rattle fixed, but it feels great now.
Sent from my SM-G955U1 using Tapatalk
Offline jackcauliflower
« Reply #6030 on: Thu, 07 June 2018, 12:40:42 »
Work: Novatouch with SA Grade
Home: Novatouch with SA Hyperfuse
« Reply #6031 on: Thu, 07 June 2018, 12:51:36 »
Work: Jane with tactile grays (72g SPRiT springs).
Home: 2010 MBP.
Offline SmilingPolitely
« Reply #6032 on: Thu, 07 June 2018, 13:15:17 »
Current daily driver: RF87u 45g. Lubed & silenced w/ KBDFans rings.
Storage:
Leopold FC750r MX Silent Reds
IDFactory TKL MX Reds
Das Professional MX Browns
(Real daily driver: 2017 MBP butterfly switches... These are definitely not the best.)
Offline Nomcr
  • Hi I'm Cayde
« Reply #6033 on: Thu, 07 June 2018, 13:57:18 »
Leopold Fc750R with silent reds and dev/tty. I switch between this and my HHKB and am pretty happy with both!
Offline Deephouse_jedi
« Reply #6034 on: Thu, 07 June 2018, 14:40:20 »
Varmilo and I am looking for a replacement. Love the layout but i have had so many problems with their PCB. I dont recommend it to anyone
Offline hideyourholes
« Reply #6035 on: Thu, 07 June 2018, 14:44:54 »
To my embarrassment, a 2015 Razer Blackwidow Chroma. Looking to get that replaced by a Noxary 280 in the coming months and I cannot wait.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #6036 on: Thu, 07 June 2018, 14:56:00 »
What's wrong with that?
Offline hyperlite218
« Reply #6037 on: Thu, 07 June 2018, 18:13:01 »
Using a nightfox with hako trues but am going to be swapping it to zealios shortly. At that point in time i'll probably swap back to my topre board for a 2-3 weeks.
Offline Astrasa
« Reply #6038 on: Thu, 07 June 2018, 18:43:38 »
Currently using a clueboard with silent blacks which aren't my favorite so my next board is gonna be back to a 40% with some mod m tactiles!
Kyuu Proto | Quasi Alice | Duck Viper | Tx87-Se
Offline carnagex9
« Reply #6039 on: Thu, 07 June 2018, 20:32:12 »
My first build was an iris with box navy switches and I am absolutely in love. Took a bit to get used to the layout, but I enjoy it a lot now.
Offline TheNamesTy45
« Reply #6040 on: Thu, 07 June 2018, 20:57:02 »
If you don't want them, and they're all still in tact after you're done desoldering, I could buy them off of you.
Offline LeoShi
« Reply #6041 on: Fri, 08 June 2018, 11:10:23 »
m65 now, but I'm waiting for my canoe :))
Offline giangtran19x
« Reply #6042 on: Fri, 08 June 2018, 13:42:35 »
a TKL custom with zeal 65g
Offline typo
« Reply #6043 on: Sat, 09 June 2018, 01:07:42 »
REalForce RGB on white with GMK keycaps. Prefer the light not shining through the legends. I love it. People are wrong IMO, It is actually better quality than say 104UB. It most certainly thwacks. I was a big fan of MX Clears and find the 45G to be heavy enough while easier of the fingers. I was also a big fan of the older Deck keyboards until 7 backups broke. TG3's soldering is terrible. Whereas with Topre everything is top notch. the case does shift like all RealForce but that does not bother me, I know it is quality. Also, Unlikely the SMD LED's solder fails and many less solder joints to begin with. I do have several 104UB but vastly prefer this setup. the lighting is on the lowest setting. Since it really bleeds out from under the GMK's. As of now, other than some Korean customs this is end game. At least until it fails, which I imagine will be a long time. LED's on low should last several hundred thousand hours. I have a bunch of keyboards but this has been daily driver for over a year now.
Offline ArchDill
« Reply #6044 on: Sat, 09 June 2018, 01:26:46 »
Revo RJ with lubed Tealios on a brass plate. MMmmmm like butter.
Offline sublyme
  • sublyme_keys
« Reply #6045 on: Sat, 09 June 2018, 11:31:18 »
Current daily driver: RF87u 55g.
Storage:
ducky mini w/ mx clears
ducky one w/ mx blacks
Offline NewbieOneKenobi
« Reply #6046 on: Sat, 09 June 2018, 11:52:51 »
This (Genesis RX85 with brown kailhs.)
Offline serec
« Reply #6047 on: Sat, 09 June 2018, 21:58:33 »
Rubber dome :(
Offline MrDongblaster
  • Dr. Pepper Zero Sugar Enthusiast
« Reply #6048 on: Sat, 09 June 2018, 22:26:34 »
XD84, Gateron silent blacks
« Last Edit: Sat, 09 June 2018, 22:30:57 by MrDongblaster »
Offline mypainishurt
« Reply #6049 on: Sat, 09 June 2018, 22:39:49 »
Filco Majestouch!
