Author Topic: What Keyboard Are You Using Now?  (Read 5005064 times)
0 Members and 6 Guests are viewing this topic.
Offline bkrownd
Re: What Keyboard Are You Using Now?
« Reply #7350 on: Wed, 07 June 2023, 03:50:53 »
I'm going to put my Stargaze set on one of my GMMK TKL keyboards in the next few days.  :D
Offline GMKClassicRed
« Reply #7351 on: Thu, 08 June 2023, 17:00:13 »
Mc65. Wish hiney made H65 PCB extras.
Offline mathisart
« Reply #7352 on: Tue, 13 June 2023, 07:23:38 »
OLKB Prenic
Offline Snuckerpooks
« Reply #7353 on: Tue, 13 June 2023, 08:02:55 »
YUNZII KC68
Still figuring out what switches I like and this keyboard is so easy to take apart, mod, and then put back together.
« Reply #7354 on: Tue, 13 June 2023, 16:26:41 »
I'm a big fan of the Tester68. I currently have about 16 of them kicking around right now.
Offline kolektador
« Reply #7355 on: Wed, 14 June 2023, 04:21:35 »
Lenovo KB1021
« Last Edit: Wed, 14 June 2023, 04:24:08 by kolektador »
The true endgame keyboard is not a perfect keyboard but a keyboard that makes you feel satisfied and at peace while using it  :)
Offline ___Aihey___
« Reply #7356 on: Mon, 19 June 2023, 01:45:18 »
by aihey Studio
Offline henrix
« Reply #7357 on: Mon, 19 June 2023, 19:25:37 »
I've been using an RS60 for a while now, probably three months at this point. Have it with MX Blacks and PBT keycaps, and it feels great. The mods don't sound perfect, but getting hung up on stuff like that has always seemed a bit silly, especially when you rarely ever use them compared to the alphas. I definitely understand all the hype behind top-mounted blacks at this point, though - there's just something special about the combo even if it isn't realistically the "best" in any way.
My other daily-use board is an FC660c. I've been looking for a metal housing for it, but it just seems a bit overkill, especially when all the other mods I've done have specifically been to get the board as silent as possible. And there's just something special about a Topre board in the OEM plastic housing, anyways.
Offline Neoteknon
    • www.www.www
« Reply #7358 on: Wed, 21 June 2023, 20:04:29 »
Here is my pair of Bostons:
The upper is my first one, Hako True switches and MT3 Suswatari with some SA Row1 for the extra keys. This one lives at the office.
The lower one is my home board, Mil-Maxed, Kalih pale blue clickbar switches and /dev/tty MT3 keys (Base, Numpad and Extras kits)
OOOOOH boston posting time? Here's my ALU one ^^
And here it is in my dorm!
(That illumination is just from the lock lights btw)
It's got Zeal PC clickiez and DCS SolDark on it :)
Hi, fairly new in the keyboard geeks thing, but higly motivated. Can someone please tell me what are these `Boston` keyboards? cant find a brand online with that name, but they look just marvellous :D Thanks everybody
Sent from my SM-G991B using Tapatalk
Offline kolektador
« Reply #7359 on: Thu, 22 June 2023, 00:28:22 »
RAKK Lam-Ang Pro
Offline Rhienfo
  • GOTHETIGES
« Reply #7360 on: Thu, 22 June 2023, 07:08:28 »
Boston is a keyboard not a brand, it's an open source project, so you can get it anytime, it will be expensive though, so you should look into everything to do with getting a one of here before spending money (at least for an alu version, believe you can print it)
This vendor called rndkbd does sell a 3d printed version if you don't want to go your own route - https://rndkbd.com/products/boston-keyboard-kit?_pos=1&_psq=boston&_ss=e&_v=1.0
There is also a full alu version that will be run at group buy soon (but it's really expensive) - https://rndkbd.com/products/boston-keyboard-kit?_pos=1&_psq=boston&_ss=e&_v=1.0
Offline evidentLEE
« Reply #7361 on: Sat, 24 June 2023, 17:22:10 »
Just built one of my grail keyboards.
Keycult No. 2/65 x GMK Dualshot 2
Gateron Oil Kings Lubed with 205G0
GMK QMX Stabs band aid mod, lubed with 3204 on wires and 205G0 on housing.
300062-0
300064-1300066-2
« Last Edit: Sat, 24 June 2023, 17:33:41 by evidentLEE »
Give a man a gun, he'll rob a bank. Give a man a bank, he'll rob the world.
Offline garynguyen
    • Tap hoa Phim
« Reply #7362 on: Mon, 10 July 2023, 00:39:31 »
I'm with Tofu65 and Glorious Panda now. Is GP out meta now?
AMD 5600X - RX 6600XT
Ducky One 2, Leopold 900RBT
Keychron Q2, Enter67, Tofu65, Sunset80, Wind Z75
Offline Cobertt
    • Control on Caps
« Reply #7363 on: Tue, 11 July 2023, 08:29:10 »
Glorious Pandas were never in meta. Drop's HPs were in meta when they came out since you didn't have to frankenswitch, but other hyper tactiles have come out that are really good as well.
HHKB Pro2 | Mira SE | FJELL | KARA HAZE | CW88 FNF WKL Wine | HHKB Prophet | Al.6 | Tengu | Prototype CW60 HHKB Skunkworxxx | Prototype K80 | Tokyo60 | Gingko65Midway LEKei | Frog TKL | Saturn60 | NRD Kaze | Panda Korn | Iron 165 FE | Caerdroia | Safa TKL
Offline Rhienfo
  • GOTHETIGES
« Reply #7364 on: Wed, 12 July 2023, 08:55:17 »
Yeah Glorious Pandas were made specifically to cash in on the holy pandas, they were like seen as a cheaper alternative, but they had a different stem and the leafs were worse for some reason (even though they had similar to identical moulds I'm pretty sure). The original name of them were the "Glorious Holy Pandas" which caused drama to the point where they had to change the name. There are so many large bump tactiles which are cheaper than the Glorious Pandas/Holy Pandas that feel similar that they aren't really worth it anymore.
Offline bkrownd
« Reply #7365 on: Wed, 12 July 2023, 17:21:58 »
Everybody is different, but "glorious pandas" fatigue my fingers.  It's unpaid work to press them.  I think you'd have to be slamming the keys like a plumber with sausage fingers to want to use them.  But hey, plumbers have to type too.
Offline HerrVoennchen
« Reply #7366 on: Sat, 04 November 2023, 14:30:53 »
After a while with my MX Keys Mini, I got back into the rabbit hole and got me a new Keychron K8 Pro for my new job. Sounds pretty good stock but I was baffled how much quieter and soft-tone the board got just with some silicone rings. The caps are ABS so, may this is the first thing I will change anyway.
303925-0
303927-1
« Last Edit: Sat, 04 November 2023, 14:33:07 by HerrVoennchen »
@work: Keychron K8 Pro w/ Gateron Ink Black v2
@home: CoolerMaster Masterkeys Pro S RGB (MX-Brown)
retired until fixed: Ducky One 2 SF (MX-Black, US-Layout)
Retired: Varmilo Miya Pro DualOS Custom (MX-Black, US-Layout)
Offline bkrownd
« Reply #7367 on: Sat, 04 November 2023, 17:53:01 »
  I'm really enjoying the vibrant SA Recall set I got recently.  GMMK TKL barebones.  Jelly Key "Cat Knights" Atom artisan.  I need to swap my deskmat to one of my Catpads designs.
Offline Exquite
  • GeekAnubis
« Reply #7368 on: Mon, 06 November 2023, 17:26:10 »
I'm sticking with TKL: QK80.
I'm a Color lover and a designer.
Offline mohawk1367
  • Typing on: HHKB Pro Hybrid Type-S
« Reply #7369 on: Thu, 09 November 2023, 08:05:55 »
HHKB Pro Hybrid Type-S with blue Esc and red Control keycaps from PFU + anti-vibration mat. almost perfect except for the stabilizers
someone needs to make an aussie keyboard community called QMƎɹ┴⅄. get it? haha :D
Offline phinix
« Reply #7370 on: Thu, 09 November 2023, 12:40:07 »
Lube them really nicely :)
Offline clay
  • No foams
« Reply #7371 on: Wed, 15 November 2023, 07:40:36 »
Realforce R2 TKL. Topres need more love
Offline mohawk1367
« Reply #7372 on: Wed, 15 November 2023, 07:41:39 »
true true
« Reply #7373 on: Wed, 15 November 2023, 18:10:12 »
I have a lot of custom keyboards,But if it's for work, I'll choose a mass-produced keyboard.Because I'm typing really hard HHHHHHHHHHHHH
304268-0" alt="" class="bbc_img" />
Offline funkmon
« Reply #7374 on: Wed, 15 November 2023, 21:23:25 »
I'm typing with a garage sale F XT I picked up. Honestly, these are great keyboards. I don't know why I use anything else.
Offline mohawk1367
« Reply #7375 on: Thu, 16 November 2023, 07:51:28 »
(Attachment Link) " alt="" class="bbc_img" />
this is why vintage keyboards are gr8. the quality of a custom with the durability of... a tank i guess
Offline Greywolf
« Reply #7376 on: Mon, 20 November 2023, 17:00:42 »
KeyChron V3 + EpoMaker EK21, with as close as I can get to a UNIX layout without split-backspace (removed BS stab).  Thank the gods for removable stabs.
Brown (but swappable) switches because I like tactile but I am up late nights and don't want to clackety my wife out of bed with an annoyed look on her face.
thumbnail is upside down; zooming in makes it right side up.  Go figure.
« Last Edit: Mon, 20 November 2023, 17:02:36 by Greywolf »
Offline Tseg
« Reply #7377 on: Mon, 20 November 2023, 22:09:36 »
My KBD8X MKIII is a couple hours old.   I am loving it.
Offline mohawk1367
« Reply #7378 on: Tue, 21 November 2023, 06:38:12 »
304367-0
« Reply #7379 on: Mon, 27 November 2023, 02:35:58 »
My modded Keychron K8 Pro. With PBT Keycaps (came with Double shot ABS) and Gateron Ink Black V2 (lubed).
Offline funkmon
« Reply #7380 on: Tue, 28 November 2023, 11:08:02 »
I have a similar scheme on my F77 I'm using...but much less artful.
Offline jingkunliu
« Reply #7381 on: Wed, 29 November 2023, 19:26:45 »
我正在使用的是leopold 980,我喜欢980这个配列,既压缩了空间,又能够满足我日常使用需要
Offline mohawk1367
« Reply #7382 on: Thu, 30 November 2023, 06:42:30 »
FC980C 还是 FC980M?
Offline Prince Valiant
« Reply #7383 on: Thu, 30 November 2023, 08:40:44 »
Why TKL and separate numpad versus a full board?
Offline mohawk1367
« Reply #7384 on: Thu, 30 November 2023, 10:12:00 »
maybe more options? tkls are much more popular and supported than full size boards id say
« Reply #7385 on: Sat, 02 December 2023, 10:00:01 »
Seems like it. I have a 75% split and ended up getting a standalone numpad but I don't have the desk space to keep it out all the time.
Offline russeree
  • Creator of NyanOS | Nyan Keys
« Reply #7386 on: Sun, 03 December 2023, 23:22:36 »
Typing on my Nyan Keys 0.8a Proto Right now!  ;D FPGA based keyboard with a USB 2.0HS interface with a few other neat little tricks to reduce latency to the absolute floor.
Open sourced the entire design too so if others want to build it they can!
https://github.com/russeree/nyan-keys-hardware
« Last Edit: Sun, 03 December 2023, 23:30:44 by russeree »
Nyan KeysMech keyboard
Nyan OSOperating System / Firmware
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #7387 on: Mon, 04 December 2023, 00:54:30 »
304616-0
Finally got this all built up after fighting the PCBs for the better part of 2 weeks.... :blank: It did come out really good though. I went HMX cloud switches, on a POM plate, without the chungus plate foam/silicone pad thing. The clouds are pole bottom out but still full travel, I went with them cause of the pole bottom out since the case is a more open sounding one. That plus the extra deepness the POM plate adds ends up with a pretty nice sound profile on it. I did have to force break the case & add a layer of shelf liner in the bottom to get the case ping under control & get rid of the little bit of hollowness it had. Overall though worth the work IMO!
Offline Tseg
« Reply #7388 on: Fri, 15 December 2023, 09:49:11 »
After a month or more (Edit: check that, I see my post above - less than a month) with my KBD8X MkIII I changed out my PBTfans Dolch Keycaps for the GMK Blue Samurai's and swapped out the Gateron Oil King linear switches for the DS White Jade tactiles... but ended up putting the Oil King back under the space bar.  This board now seems so complete for me.  Oh, and was able to go into Via and change the power-on led on the far end of the board to be a perfect matching yellow-gold to the <ESC> and <Enter> keys.  I do have a Neo 65 milky white showing up at the end of the month, but not sure it will get a lot of play time?
Offline Exquite
  • GeekAnubis
« Reply #7389 on: Sun, 17 December 2023, 10:31:41 »
I’m using QK80 right now. but since there are many more beautiful tkl coming out, I might change.
Offline Tactile
« Reply #7390 on: Mon, 18 December 2023, 10:28:19 »
Just an old HHKB Pro2 Type S
No mods
REΛLFORCE
Offline mohawk1367
« Reply #7391 on: Tue, 19 December 2023, 09:58:58 »
No mods
cant go wrong with stock
until your stabilizers start making you deaf... i need some krytox for christmas
Offline wjrii
« Reply #7392 on: Tue, 19 December 2023, 16:21:14 »
For those who don't venture over to Making Stuff Together very often, I've just pressed this cross-eyed little fella into service as my work board.  I have a lot to explore and learn about lasering a consistent set of legends, but overall it wasn't bad for my 6th hand-wire and first go at keycaps.
Offline Tseg
« Reply #7393 on: Wed, 20 December 2023, 10:55:41 »
My work is never done...
Offline transeurasian
« Reply #7394 on: Sat, 23 December 2023, 04:29:22 »
Using HHKB classic  :)
Offline Tseg
« Reply #7395 on: Wed, 27 December 2023, 20:50:11 »
My next-up just arrived.  Neo65 (because everybody's doin' it).  My smallest keyboard yet, with a bit of a retro theme and MT3 profile keycaps.  This should be my last until the Neson 810E arrives 2Q24.
Offline phinix
« Reply #7396 on: Thu, 28 December 2023, 07:47:31 »
NCR-80 with Gateron Oil Kings and SA Retro keycaps.
305178-0
« Reply #7397 on: Thu, 28 December 2023, 08:54:38 »
That is beautiful. Although I always use full size + that is the kind of small board that I would like.
If it were up to me, \| and `~ (and maybe even 1!) would be red ....
- Franklin Roosevelt 1933
Offline phinix
« Reply #7398 on: Thu, 28 December 2023, 09:12:56 »
Yeah, I was going to use red pipe, but this one has side legend with Pi sign, so went with that :)
Offline Subdromat
« Reply #7399 on: Sat, 30 December 2023, 11:05:18 »
I used PCB of 2013 Lioncast LK-20 TKL keyboard with Cherry MX black stock. Case is aliexpress as well keycaps . It was some kind hard using this specific very thick keycaps (also aliexpress), seems these are factory seconds and the board was not made for XDA keycaps, so I got to modify the wires of the stabs.The PCB well made, almost filco tolerances. Great thocky sound with underrated mx black switches !
