Author Topic: QUME Keyboard  (Read 12275 times)
Offline nilpt
QUME Keyboard
« on: Fri, 05 July 2013, 13:32:26 »
Found this one attached to a QUME QVT 61 Terminal.
MX black on all keys.
DS key caps.
BIG space bar.
Painted/Engraved Numeric Pad block (telephone use?) on the DS caps...
Custom functions engraved in portuguese.
Label
P/N: 303686-11
Model: (empty)
S/N: XV006126
IBM 1391410 / Qume terminal keyboard (teensy 2++)
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
Re: QUME Keyboard
« Reply #1 on: Fri, 05 July 2013, 14:00:40 »
there is no escape! haha and holy space bar--i've heard of 10x space bars and now i know what they look like.
Offline oluf
  • formerly olaph
Re: QUME Keyboard
« Reply #2 on: Fri, 05 July 2013, 14:09:00 »
Wow! Cool find.. May I ask where you found it?
Offline nilpt
Re: QUME Keyboard
« Reply #3 on: Fri, 05 July 2013, 16:30:58 »
In storage at my job IT area.
I guess it is not in use for several years now.
In a quick search I could not find an adapter to get it to USB or PS/2, it uses a 4 pin connector, and maybe 12V (?).
Really like the DS caps  :)
Offline SeriouSSpotS
  • 60% is love, 60% is life
Re: QUME Keyboard
« Reply #4 on: Fri, 05 July 2013, 16:36:33 »
Cool find ;D
Re: QUME Keyboard
« Reply #5 on: Sat, 06 July 2013, 00:36:16 »
10x space bars are the way to go!
My Link terminal keyboard (MX blacks):
Offline bazemk1979
Re: QUME Keyboard
« Reply #6 on: Sat, 06 July 2013, 02:06:53 »
can I ride the dinosaur?
Offline nilpt
Re: QUME Keyboard
« Reply #7 on: Sat, 06 July 2013, 04:11:15 »
[PICTURE]
Very nice.
Can we see the NumPad block?
The QUME has a big coat of paint on top of those caps, I am curious as to the original layout.
What is the connector type?
The qume should be one of these, I guess:
http://www.kbdbabel.org/conn/kbd_connector_qvt1xx.png
http://www.kbdbabel.org/conn/kbd_connector_qvt2xx_qx15.png
Offline nilpt
Re: QUME Keyboard
« Reply #8 on: Sat, 06 July 2013, 10:47:21 »
Use it? Are you kidding???
 :rolleyes:
Offline bazemk1979
Re: QUME Keyboard
« Reply #9 on: Sat, 06 July 2013, 11:39:23 »
 :rolleyes:
already have the saddle for it  :))
Offline nilpt
Re: QUME Keyboard
« Reply #10 on: Sat, 06 July 2013, 13:14:38 »
 :rolleyes:
Sorry, not an option.  :)
Re: QUME Keyboard
« Reply #11 on: Sun, 07 July 2013, 00:45:24 »
[PICTURE]
Very nice.
The numpad of the Link?  (I assume so, as the Qume one is visible.
These keys I did not remove or clean (whereas the alpha nums spent some time on my QFR).
Offline nilpt
Re: QUME Keyboard
« Reply #12 on: Sun, 07 July 2013, 05:52:48 »
Thanks  ;)
Is the connector also 4 pin RJ ?
Do you have it working, as bazemk?
Re: QUME Keyboard
« Reply #13 on: Sun, 07 July 2013, 05:55:26 »
Yes and yes - although only when connected to the Link terminal screen.
