Author Topic: HHKB Pro2 autoconfigured in Linux distribution  (Read 3506 times)
Offline Thanatermesis
« on: Tue, 16 September 2008, 11:15:24 »
I have just added the support (for the next build 1.8.9) of Happy Hacking Keyboard Pro 2 in Elive (a linux distribution), it is autodetected and directly configured to a better "more intuitive" keymap distribution (it can be disabled too), my configuration for the $HOME/.Xmodmap used is:
keycode 86 = less
keycode 82 = greater
keycode 63 = Left
keycode 112 = Down
keycode 97 = Up
keycode 98 = Prior
keycode 99 = Right
keycode 100 = Home
keycode 102 = End
keycode 104 = Next
keycode 103 = braceleft bracketleft
keycode 105 = braceright bracketright
Maybe you can enjoy about this configuration if you own one of these keyboards :)
On this way, the arrow default keys are now (with Fn) h,j,k,l  and they are now used by: Left = Home, Right = End, Up = PagUp, Down = PagDown.
Also, the bottom keys to these ones (i don't type his characters because it can change depending of the layout used) are used for { } [ ]
There's more than 1 week that i have it but with this remaping its a lot nicer to work now
Note: is required the 2º switcher set to ON, also I have these others switched to ON: 2,3,4,5
Offline bigpook
« Reply #1 on: Tue, 16 September 2008, 11:44:30 »
Nice. I am running ubuntu 8.04 and will give it a try. I was thinking of doing the same for hjkl but adjusted to the default layout. But since you did all of the heavy lifting I will give it a try and let you know how it works out.
Offline iMav
  • geekhack creator/founder
« Reply #2 on: Tue, 16 September 2008, 16:08:31 »
I actually love the default mapping for the arrow keys.  There is no way I can reach "h" with my right index finger while holding  the Fn key down with my right pinky.  The default mappings work much better for me.
Offline lowpoly
« Reply #3 on: Tue, 16 September 2008, 16:11:30 »
I guess that's to be used with left thumb Fn key.
Offline bigpook
« Reply #4 on: Tue, 16 September 2008, 17:04:33 »
no doubt, I was very happy when I determined that you could have a Fn key on the left hand side. It made the HHKB more usable for me.
« Reply #5 on: Wed, 17 September 2008, 05:17:33 »
Correct, with the Fn key of the left side
Btw, the new ISO is actually uploaded with this support
Re: HHKB Pro2 autoconfigured in Linux distribution
« Reply #6 on: Mon, 01 October 2012, 22:41:19 »
By the way i have MUCH MUCH improved my configuration, you can see the entire details (image of layout included) in:
https://github.com/Thanatermesis/thanakblayout
