Author Topic: WTS: KMAC LE (Price drop!)  (Read 10883 times)
Offline nathairtras
  • Trade Count: (0)
Re: WTS: KMAC LE (Price drop!)
« Reply #50 on: Mon, 22 July 2013, 23:08:50 »
Ctrl+esc or just reprogram caps to be super if you really need it =).
Only barely related, but I do this on my computers just for comfort.  Winkey gets disabled, Caps gets set to Winkey.  Who uses capslock on a regular basis anyway?
CM QFR Green
Offline tadbitnerdy
  • Trade Count: (0)
« Reply #51 on: Tue, 23 July 2013, 00:26:18 »
I do actually, because there are many variable values that are all caps... I use it most when creating dummy data.
Offline slip84
  • Trade Count: (0)
  • GUYDUDE MAGICIAN
« Reply #52 on: Tue, 23 July 2013, 09:57:24 »
Gotta ask since I see so many Kmacs moving around on these forums: how do y'all deal with missing Windows keys? I can't do it. I have tried. I realize I use them like every ten or so seconds. I can't imagine AutoHotkey being a permanent solution.
Regardless, free bump!
GLWS
People use the windows key?
Sadly in my line of work, it's a necessity. About 60% of what I do involves some sort of shortcut in the OS and the OS at work is Windows of some flavor. Fact of life for me.
Offline nathairtras
  • Trade Count: (0)
« Reply #53 on: Tue, 23 July 2013, 11:41:24 »
Maybe my fingers are just sufficiently long to make it easy enough to not notice, but I do not get any discomfort or loss of speed from holding shift for such things.
Tools to "prettify" my code made me a little more lazy with this, but my shift gets heavy use.
Sent from my iPhone using Tapatalk 2
CM QFR Green
Offline audukent
  • Trade Count: (0)
« Reply #54 on: Tue, 23 July 2013, 22:21:21 »
PMing you now...
[LZ-GH - 62g mx greens and 62g mx clears]    [Ducky Shine - mx browns]    [RACE mxMini - mxreds]  [POKER II - mx Blacks]    [KPAD - 62g mx blacks]
Offline audukent
  • Trade Count: (0)
« Reply #55 on: Tue, 23 July 2013, 22:31:43 »
Hey man, could you post pictures of the back side of the pcb?  also, could you post a pic of the two halves of the case next to each other, I'm curious if the two different shades is very noticeable? :) you da best!
« Last Edit: Tue, 23 July 2013, 22:51:47 by audukent »
Offline nebo
  • Trade Count: (0)
« Reply #56 on: Wed, 24 July 2013, 17:36:08 »
Could you get a picture up of the KMAC to show how different the top and bottom finishes are?
Don't use SQL much? I can do it holding down shift but I slow down considerably.
« Last Edit: Wed, 24 July 2013, 17:38:24 by nebo »
Offline tadbitnerdy
  • Trade Count: (0)
« Reply #57 on: Wed, 24 July 2013, 18:38:42 »
Sorry for the wait!  I will get that pic up tonight.  If there is a difference, I can't tell.
