Author Topic: Blank DSA DSA caps $18/19 for base/modifier sets from SP  (Read 19295 times)
Offline Dubsgalore
Re: Blank DSA DSA caps $18/19 for base/modifier sets from SP
« Reply #50 on: Sat, 13 July 2013, 20:18:33 »
hmmmm all blacks
maybe i can pick some up if the deal is still there in a bit
Offline Xenderwind
« Reply #51 on: Sun, 14 July 2013, 01:57:53 »
Yeah just add some heat and bend it back.
I'll be trying to fix one sometime next week.  Do you recommend using cold water after I heat it?  I think I read something on here about using a pot of ice water and holding it at the bottom of that to make it flat as it cools.
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
« Reply #52 on: Sun, 14 July 2013, 10:18:12 »
I mean you're just lightly applying some heat to it... it doesn't get THAT hot, it'll cool to room temperature in like 5 minutes. I don't know.
Offline Kempher
« Reply #53 on: Sun, 14 July 2013, 13:14:30 »
Just got my full white set in and put them on my Filco...and then took all of the 1x1 keys off to double check the orientation and put them back on :|
Liking them so far, although I'm coming off of OEM profile, so it's quite a different feel...will need to spend more time with them though to see how DCS works out for me. Also, one of my scoops has some blue crap on it that doesn't really want to come off...
Tater:
This is sexy, the next goal imo would be to start mixing in some other colors throughout!
SQ-1800 /w Gateron Blacks
Offline Prelim
« Reply #54 on: Tue, 09 December 2014, 16:26:57 »
Oh wow, these look great. Reasonable shipping to UK too :D
Edit: Actually I take that back.
The cart system is retarded. If I add a base kit + modifier kit shipping comes up to $26.50 to UK, yet if I add individually:
1 x base kit - shipping $9.95
1 x mod kit - shipping $9.95
That is a total of $19.90 shipping instead of $26.50.
Hi guys,
Is this still available?
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps
