Author Topic: 4 pin mini DIN to PS/2?  (Read 2390 times)
Offline jabar
« on: Thu, 11 July 2013, 01:12:02 »
The Maltron keyboard I purchased recently didn't come with a cable but to my surprise (or chagrin) has two 4 pin mini DIN ports... like ADB ports. However the label states it's an IBM compatible keyboard and no other evidence of an Apple edition exists.
Anyone run into this before? All I need out of this is PS/2, so I guess a passive adapter / hack might be feasible. I have an email out to Maltron to get to the bottom of this.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline rootwyrm
  • The Hands of Steel
    • My Website!
Re: 4 pin mini DIN to PS/2?
« Reply #1 on: Thu, 11 July 2013, 01:24:15 »
PS/2 only actually uses four pins. DATA+, VCC+, CLK+ and GND. The two additional pins on the six pin are MDATA+ and MCLK+ (mouse) for PS/2 splitters.
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline jabar
« Reply #2 on: Thu, 11 July 2013, 19:27:26 »
OK, has anyone made a passive 4 pin to 6 pin PS/2 adapter?
Phantom 7bit
Offline rootwyrm
    • My Website!
« Reply #3 on: Thu, 11 July 2013, 19:50:04 »
The question you want to ask is: what is the Maltron pinout and where can I get their particular cable and/or connector?
You haven't provided enough information for anyone to answer that though. Maltron makes a variety of keyboards and accessories including foot switches, and yes, they connect to the keyboards.
Maltron can probably set you up with the correct cable and which port it goes to. For some reason, my Digikey-fu is failing me and I can't even find the male 4 pin MiniDIN.
Offline Soarer
« Reply #4 on: Thu, 11 July 2013, 20:16:51 »
Yeah, only Maltron would know, unless you want to open up the keyboard and trace wires etc!
Even if they've used the PS/2 pinout it could be normal or mirrored, requiring a crossover or a straight-through cable respectively.
Offline jabar
« Reply #5 on: Thu, 11 July 2013, 20:46:48 »
Yes, I already have an email out to Maltron, still waiting for a solution. Was mostly wondering if anyone else has run into this 4pin DIN on Maltrons or any other keyboard.
Phantom 7bit
