Author Topic: [IC] ALPS ansi key cap set (07-25 update)  (Read 75313 times)
Offline DUENAH
Re: [IC] ALPS ansi key cap set (07-17 update)
« Reply #100 on: Sat, 20 July 2013, 04:58:55 »
Expectations.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #101 on: Sat, 20 July 2013, 09:55:02 »
I'd argue that we should target the Ducky XM boards, the Filco Zero, and possibly the Solidtek ASK-6600 and Matias boards
Why?  They're the "modern" boards.   They're most likely to be consistent and no surprises.  For example, I think the Focus 2001 comes in three layouts-- backslash in bottom row, backslash by right shift, and Winkey+backslash by right shift.
They're also the ones most likely available for people who want to pick up an ALPS board to play.  For them, a default board-- that the set is designed to work with-- is a desirable thing.
Also, do note that some of the newer ALPS boards-- the Ducky and the Solidtek-- use a different stabilization than older ALPS boards-- it's Costar-style stabilizers.
understand your reasoning- stems are all over the place and appreciate calavera taking the time to check [the stems]
just food for thought and "if" SP can do the "extra" stems...............i would think at least you open the door for a higher quantity of people getting in, placing an order by those who have an older board (to help bring the price down)-- be it a dell 101 or whatever.
i'm betting there are more of us who have older alps boards than those who have modern alps and then what percentage of those who own modern alps boards are wanting to spend the $ to get in on this GB?
if the general consensus is to stay modern, increased pricing than that is cool............it is what the majority and calavera want.
i'm in regardless based on the color schemes i have seen and are you kidding me..........finally an ALPS GB :eek:
am just hopeful if it is narrowed down to a modern layout, SP cannot do extra stems that there will be enough people who pay to bring the price in somewhat reasonable
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline alaricljs
  • I be WOT'ing all day...
« Reply #102 on: Sat, 20 July 2013, 10:10:46 »
It was my understanding that SP can't do Alps stabilizer stems.  So the only valid choices are for KBs that have Costar style stabs.
Filco w/ Imsto thick PBT
Offline Tarzan
  • formerly known as Greystoke
« Reply #103 on: Sat, 20 July 2013, 10:20:56 »
I'd like to have a set that will work on FK-2001 boards, both winkey and winkeyless.
I'm not really interested in newer Filcos or Matias boards, but vintage Focus/Magitronic boards are cheap enough to try several, it would be cool to have custom caps to update their looks.
Offline Hak Foo
  • Make America Clicky Again!
« Reply #104 on: Sun, 21 July 2013, 17:10:57 »
I suspect the WIRES might be reusable on a Costar-style stabilizer, but you'd have to supply it yourself.
Overton130, Box Pale Blues.
Offline calavera
« Reply #105 on: Mon, 22 July 2013, 11:18:04 »
I'm beginning to see why all past attempts have failed. When it comes to Alps, everything comes down to side stem locations.
It would help tremendously if I could gather info on the various boards and their stem locations.
Backspace, enter, left shift side stems are only 1/16"~1/8" off so my guess is most stabilizers will work fine.
Space bar and right shift is the most problematic.
So if you could post your keyboard, distance between side stem and center stem (center to center), kind of stabilizer..etc. It would help a lot.
Pics are even better.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #106 on: Mon, 22 July 2013, 11:33:55 »
i would be happy just to do my dell 101 :cool:
i thought i saw where you had the dimensions on it- if not let me know
my other alps boards (stems) are all over the place as Hak Foo says............
Offline calavera
« Reply #107 on: Mon, 22 July 2013, 11:56:59 »
I saw one with stem distances on desthority's wiki but I can't find it anymore. It had measurements in mm's from center to side stem. But they were also just MX I think.
Now's the time to contribute your info!
Offline Grimey
« Reply #108 on: Mon, 22 July 2013, 14:47:16 »
Is interested, many an alps switch sitting around with little to do.
Erlang your pants off
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #109 on: Mon, 22 July 2013, 16:36:18 »
never have pulled the stabilizers out of a dell board that has ALPS.............good grief :eek:
did not see how they came out and took a while to figure which way (murphy's law) they go back
dell (at101) "back space" from center out.....stems are 13-14mm off center
can you see how that fares with what you are looking at before i go any farther?
Offline pasph
« Reply #110 on: Mon, 22 July 2013, 16:47:35 »
Make a pool and narrow down the old alps kbs interested
Or make a new SP standard alps stabilizers and feed old kbs with just the not stabilized Keys
Don't try to do what can't be done
Focus 2001, AEK, AT101, omnikey, SIIG just to name a few have at least different enter key or space bar stabilizers, then there are the compatibles like monterey, kpt or Omron, then the "new" duckys, Filco zero, Leopold lite, matias.
I have a number of those old kbs, even an IBM 5954339, and wish but really don't think anyone can cover all those variances
Veteran Alps experts discussing Clones (Credits to Webit)
« Last Edit: Mon, 22 July 2013, 21:16:18 by pasph »
Offline calavera
« Reply #111 on: Tue, 23 July 2013, 11:01:46 »
I'm still in the process of working out the details of stem locations with SP but it looks like vintage alps boards won't be 100% compatible. Best I can do is split the sets up accordingly so that everyone with an alps board can buy something.
Offline calavera
« Reply #112 on: Thu, 25 July 2013, 17:02:34 »
UPDATE 07-25
6.25x spacebar: stem positions are fixed. So chances are it won't fit your board in most cases. (If your alps spacebar uses stock cherry mount and positions it will. I've seen some old alps boards with big enter keys use these)
7x spacebar: Additional stems can be done for a one time tooling fee of $1000. Moving the stems will cost $500. The former would mean greater compatibility for various boards. (I've seen some old alps boards with big enter keys use stock cherry mount and positions)
For 2.75x shift, the stems can only be moved by a small amount but I think it's enough for the stab wires.
2x keycaps are fixed but stems are close enough so they should fit as well.
As you can see the spacebar is the biggest obstacle. I'll update the thread in a few to reflect final so we can move on to GB stage.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
Re: [IC] ALPS ansi key cap set (07-25 update)
« Reply #113 on: Fri, 26 July 2013, 09:33:49 »
worth a stab............ ;D
thanks for the hard work
like you and others have said for older boards will just try and place what will fit
will probably, eventually get a modern alps boards depending on how the caps, colors, options turn out.
to be honest..........i'm a bolt turner, not the best with wiring, soldering- so as much as i like the alps plate, board you are offering i doubt if i would try putting one together
if it was a big block chevy-- no problem :cool:
Offline calavera
« Reply #114 on: Fri, 26 July 2013, 13:35:18 »
I'm considering including big enter keys. If you have pictures of yours and stem locations that would help.
Otherwise I'm throwing this out and moving on with ANSI only.
Offline calavera
« Reply #115 on: Fri, 26 July 2013, 16:24:45 »
I need dimensions for 7x and 6.25x spacebar stab wires from alps boards please.
Offline alaricljs
« Reply #116 on: Fri, 26 July 2013, 16:37:17 »
Ducky 1087XM - identical to Cherry
Offline calavera
« Reply #117 on: Fri, 26 July 2013, 16:57:07 »
What kind of stabs, dimensions of the wires? I don't have cherry 6.25 to confirm.
Offline alaricljs
« Reply #118 on: Fri, 26 July 2013, 17:01:45 »
Costar ripoff, cherry stems, C-C stem distance is 3 15/16"
Offline calavera
« Reply #119 on: Fri, 26 July 2013, 17:31:08 »
Isn't costar thicker than regular alps wires? Does the stab wire bend in like or spread out and is the shorter side about 0.5"?
Offline alaricljs
« Reply #120 on: Fri, 26 July 2013, 18:50:36 »
I know nothing about "regular alps" anything.  outside-outside measurement of the bent end is 11/32" so nowhere near .5"
Offline calavera
« Reply #121 on: Fri, 26 July 2013, 18:53:01 »
So its like the one on top (except shorter)? The bottom is from a Dell 101 6.25x spacebar I think.
Offline alaricljs
« Reply #122 on: Fri, 26 July 2013, 19:02:37 »
Yup, like the one on top, shorter lengthwise.  Also it has the multi-bend jog in the middle to go around the switch.  But really... why does the wire matter?  It should all be about stem position.
Offline calavera
« Reply #123 on: Fri, 26 July 2013, 19:22:23 »
I'm looking at custom wires as an alternative to moving stems and paying tooling costs.
A custom wire could mean a spacebar that fits not only filco zero and ducky, but also dell at101w.
For the 7x spacebar a universal custom wire would allow older alps (SGI, dell at101, chicony, northgate omnikey..etc) compatibility without having to move the stems at all.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #124 on: Fri, 26 July 2013, 21:49:25 »
sorry...........just checked in.
did you get dimensions?
Offline calavera
« Reply #125 on: Fri, 26 July 2013, 22:08:33 »
Not exact dimensions but I think the ducky one seems to be compatible as it is now.
You seem to have a few chicony alps, could you check your stabs and wire dimensions? Pictures would help. I'm also trying to cover big enter layouts as well so if you had pics of those that'd be great. I think the least I can do is include the extra 1x keys so the alphas are consistent at least on most older alps boards.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #126 on: Fri, 26 July 2013, 23:09:17 »
chicony 5181 big you know what.......
Offline calavera
« Reply #127 on: Fri, 26 July 2013, 23:12:38 »
Thanks. That looks like cherry stems for stabs? I actually need the shorter side length on the wires too.
Looks like this would pretty much cover most big enter key layouts:
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #128 on: Fri, 26 July 2013, 23:20:09 »
cherry stems :D
inside (short)on wire dimensions
28-29mm
15mm
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #129 on: Sat, 27 July 2013, 11:31:54 »
here are a couple more shots if it will help........
would be great if this is a possibility depending on cost?
did you get enough dimensions for a dell 101?
would be be awesome to grab a dell board, switch out with matias switches whenever they come out and the possibility, outfitting mostly with new caps
of course i hear and see many that want to keep modern- ducky, zero, ansi, etc. which i understand, but to be able in some form to have the opportunity to at least partially outfit some older boards you would have to think would get more people in the GB?
especially being this will be a first if it comes to form :cool:
if not then it is what it is..........
Offline calavera
« Reply #130 on: Sat, 27 July 2013, 13:14:00 »
So far all the alps boards I'm looking into are:
Dell 101, 101W, SGI Granite/Duck mini v2, Filco Zero, Ducky 1087XM, Chicony 5181, Wang724.
Right now I'm considering splitting set 1 into alpha and mods separately. This way ALL alps board owners can participate.
Offline WhiteFireDragon
    • youtube
« Reply #131 on: Sat, 27 July 2013, 14:04:45 »
terrpn, those two pictures of dimensions you posted, are those exact numbers from datasheets or are those your own measured numbers?
Offline calavera
« Reply #132 on: Sat, 27 July 2013, 14:21:08 »
I'm pretty sure he measured it himself. Why?
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #133 on: Sat, 27 July 2013, 19:21:31 »
 :eek:
those are what i one-eyed :eek:
i tried to provide something IAW what calavera was asking for
the metric is more accurate.
the stab wires are inside dimensions- not outside.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #134 on: Sat, 27 July 2013, 19:32:58 »
just to clarify......
i measured center out...........to the center of stab
not outside in
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #135 on: Sun, 28 July 2013, 01:58:25 »
calavera do you still need help with stabs?
I have a focus fk2001 and next week I'll get an sgi granite.
Offline calavera
« Reply #136 on: Sun, 28 July 2013, 11:55:24 »
Yes it would definitely help. The more people chip in the better.
Offline pasph
« Reply #137 on: Sun, 28 July 2013, 14:02:16 »
Ordered a digital caliper
Offline simkev
« Reply #138 on: Wed, 31 July 2013, 09:01:16 »
I will try to keep this as simple as possible.
This is an interest check for Alps DCS profile double shot keycaps to go hand in hand with my ALPS PCB/plate project.
Color inspiration
Actual SP color: BFP/GC combo
Divided into the following three sets.
  • Set 1: 89 keys (TKL)
  • Set 2: 17 keys (Numpad)
  • Set 3: 11 keys (Mod kit)
  • Set 4: Vintage set (Mod kit)
  • May or may not be in the final order
Combo stems:
Side stems will be cherry mount only.
07-25 update
Looking into stem locations and stab wire options. Any help/pics of your alps board would be appreciated.
I think that you should swap the colors so that the base set would be grey and the modifiers blue.
Like this:
JAG ÄR LIVRÄDD FÖR ATT LEVA & JAG ÄR DÖDSRÄDD FÖR ATT DÖ
| Poker X - Ergo Clears & Red Alert 2.0 | Majestouch 2 TKL - Browns & Blue Cream Cheese |
Offline calavera
« Reply #139 on: Wed, 31 July 2013, 15:02:37 »
I thought about it but I think I'm gonna keep it the way it is.
Chances are the mods won't fit on most older alps boards and the only common keys are the alphas. So even with only swapping out the alphas you get similar effect of what the whole set looks like since most alps boards have grey mods already.
Quick dirty photoshop:
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #140 on: Wed, 31 July 2013, 16:05:34 »
no complaints here.........
did you say which font already?
Offline simkev
« Reply #141 on: Wed, 31 July 2013, 16:27:36 »
Ok, didn't know that about Alps.
Btw, how are you making the keycap mockups that are in your first post in this thread?
Offline Photoelectric
« Reply #142 on: Wed, 31 July 2013, 18:49:10 »
I like everything about this set.  Love that teal-ish blue.  I will most likely be getting one, as I'd love to build / modify an Alps keyboard in the future.
Offline calavera
« Reply #143 on: Wed, 07 August 2013, 21:27:33 »
Just posting to let people know I'm still on top of things, I've just been too busy to sort out stab wire situation yet.
Offline kaotikb
« Reply #144 on: Sun, 25 August 2013, 16:58:04 »
I like how this set looks. I was looking for a set for my ducky green alps board.
Ducky 1087 (Green ALPS) |  CM QFR Stealth (MX Brown) | Unicomp Ultra Classic |Poker II (MX Brown)  | IBM 1391401 1991 | IBM 1391401 1989 | Ducky Shine 3 White Edition (MX Brown) | G80-3700(MX Black) | Corsair K70 (MX Brown) | Varmillo VA87MR (Gateron Red)
Pointing Devices:  Microsoft Trackball Optical (Ceramic bearings Installed)  | Sanwa MA-TB39BK (Larger Ceramic Bearings Installed) | Elecom M-XT2URBK | Kensington Slimblade | Logitech Trackman Wheel | Logitech Trackman Marble Plus
Offline Nask
« Reply #145 on: Mon, 26 August 2013, 07:53:37 »
Yum, yum, yum, I will need some keycaps with the coming ALPS/MX mini keyboard.
Keyboards: IBM SSK | Noppoo Choc Mini MX-Blue | PLU ML-87 MX-Brown | CM QFR Mx-Red | CM Novatouch
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #146 on: Tue, 03 September 2013, 02:50:39 »
Definitely in.
« Reply #147 on: Tue, 03 September 2013, 04:32:05 »
The orange/grey is yummy.
Grey/green would also look amazing. In regardless.
« Reply #148 on: Wed, 04 September 2013, 08:01:08 »
We need some keycaps to go with this
http://geekhack.org/index.php?topic=48078.0
Offline calavera
« Reply #149 on: Wed, 04 September 2013, 10:41:08 »
The problem with the 1800 is that you don't have a plate for the alps stabilizer mounts. what people have done in the past is use a combination of both alps and cherry switches for it because of that. Alps in 1x size (alphas, numbers..etc) and cherry in other sizes (enter, backspace, spacebar..etc) This also solves having to source alps keycaps that fit since 1x sizes are easier to find.
Anyways, the three sets I organized already cover everything for the 1800 layout. Some keys might not be the right height (like page down, delete, end keys.) Spacebar is yet to be determined.
